Module 1: From the box to the shell
In this first module, you will go through the process of unboxing your computer on module and carrier board, and assembling the hardware required to have video output, ethernet connection, access to the debug port through the debug UART interface and also install the operation system.
Note: In this training modules a host computer running the regular 64-bit installation of Ubuntu 16.04 LTS is used. It is highly recommend that you use the same setup, since possible issues with Virtual Machines or other Operating Systems are not discussed.
Warning: Observe precautions for handling electrostatic sensitive devices
Contents
