Installing the Operating System - Aster
Your progress
In this second how-to section, you will power on your system and use the Toradex Easy Installer to flash the latest Toradex pre-built image to your module.
In this module you will:
  • Power on your system.
  • Use the graphical interface to flash Linux.
Power-on your board and you should see the Toradex Easy Installer displayed on the monitor attached to the VGA port of the Aster. Images available for download are listed. If none are currently shown, check if the Ethernet cable is connected and press "r" to refresh.
  • Toradex Easy Installer
If your module don't have the Toradex Easy Installer
The Toradex Easy Installer will soon come pre-installed on all Colibri iMX6 modules. Please see the Colibri iMX6 revision history for more details.
If this is the case, you can follow the link below to deploy the Toradex Easy Installer to the module before proceeding:
Use the keyboard arrows to select the Toradex Embedded Linux Demo with LXDE and press "i" to install and enter to confirm:
  • Confirm the Embedded Linux installation
Step 3
  • Toradex image being downloaded and installed
Step 5
After the Image Installed message pops-up, use the on/off button or select the Power off option to shutdown the system.
  • Installation finished
