Installing the Operating System - Iris
Your progress
In this second how-to section, you will power on your system and use the Toradex Easy Installer to flash the latest Toradex pre-built image to your module.
In this module you will:
  • Power on your system.
  • Use the graphical interface to flash Linux.
Power-on your board and you should see the Toradex Easy Installer displayed on the monitor attached to the DVI port of the Iris. Images available for download are listed. If none are currently shown, check if the Ethernet cable is connected and press "r" to refresh.
  • Toradex Easy Installer
If your module don't have the Toradex Easy Installer
The Toradex Easy Installer is currently under revision and deployment, therefore you may have a module that comes with a Linux or Windows CE image from factory.
If this is the case, you can follow the link below to install the Toradex Easy Installer before proceeding:
Use the keyboard arrows to select the Toradex Embedded Linux Demo with LXDE and press "i" to install and enter to confirm:
  • Confirm the Embedded Linux installation
Step 3
  • oradex image being downloaded and installed
Step 5
After the Image Installed message pops-up, use the on/off button or select the Power off option to shutdown the system.
  • Installation finished
