Linux Terminal and Basic Usage - Colibri VFxx
Your progress
In this how-to section, you will access the serial terminal through the debug UART interface. In this module you will:
  • Power on your Computer on Module.
  • Use a serial terminal to communicate with the embedded system.
Note: We will access the module using the Serial Terminal, therefore the USB keyboard and video interface connected to the module will not be used in this section.
Open a terminal in the host machine:
  • Host terminal
    Host terminal
Install a serial terminal emulator application in your host computer:
sudo apt-get install minicom
Step 3
To find out what is the serial port device that you must use, you can execute the command below:
ls -l /dev/serial/by-id
  • Serial devices available to the user space
Alternatively, use the command below. If in doubt: unplug the USB-Serial adapter --> execute the command --> plug the USB-Serial adapter --> execute the command again and find the new device listed.
ls -l /dev/tty*
  • System serial devices listed
The new device listed, in this case /dev/ttyUSB0 is the USB-serial adapter. It will be required when you start the serial application.
Step 4
To start the serial application, the parameters must be correctly set. The table below presents them:
Parameter Value
Baud rate 115200
Data bits 8
Parity none
Stop bits 1
For instance, to use minicom you only need to adjust the serial port - the other parameters are correctly set by default. You might need to have administrator privilege to access the hardware. See the following steps to learn how to configure minicom.
Step 5
Start minicom configuration menu:
sudo minicom -s
You will see a menu such as in the figure below:
  • Serial terminal emulator configuration
Step 6
Press the "a" key from your keyboard to edit the Serial Device field. Use the device found in step 3 for your system:
Press "Enter" until you return to the previous menu.
Step 7
Save the setup as default:
  • Serial terminal emulator save setup
Step 8
Choose the "Exit" option and the terminal will be ready:
  • Serial terminal emulator configured
  • Serial terminal emulator ready
Note: To exit Minicom, press "ctrl+a" and then press "x".
Step 9
Power-on the embedded system. Messages will immediately start to be printed to the serial terminal. When the module finishes booting, you will have a terminal such as from the image below. This means that you have access to the serial terminal of the system, and that it has Windows CE pre-installed. In the next section, you will update the module OS to Linux.
  • Windows CE pre-installed
