Unboxing and Setup Cables - Apalis Evaluation Board
Your progress
  • System setup block diagram
Materials Required
Bill of materials
VGA display/monitor
Accessory kit :
  -VGA cable
  -Power supply 7-27VDC
  -USB B type to USB A type cable
  -Ethernet cable
USB keyboard
Remove the Evaluation Board and the Apalis iMX6 Computer on Module from the blisters. Insert the computer on module into the X1 connector of the Evaluation Board as tight as possible, with the module inclined ~30 to 45 degree in relation to the carrier board.
  • Connecting the computer on module to the Apalis Evaluation Board
Warning: Make sure that the computer on module is well connected to the board. The image below have some checkpoints highlighted.
  • Computer on module connected to the Apalis Evaluation Board
Connect an VGA monitor to X24 and an Ethernet cable to X12 of the Evaluation Board. Also connect a USB keyboard to X32, a 12V power supply to the barrel jack X17 or use a 7-27 V power supply to X15. Finally, plug the USB B type to USB A type cable to the X29.
Attention: Double check that your power supply is within the Evaluation Board limits (7-27V to X15 connector or 12V to X17 connector) and that the polarity is not inverted. Also, make sure that the current capability of the power supply is enough (>>1A), or the system will shutdown unexpectedly sometimes.
  • VGA, Ethernet, USB keyboard, Power supply and USB B type to A type connected to the Evaluation Board
Make sure that the jumpers JP10 and JP12 are setup to USB mode as the image below, once we will use UART-1 via the USB Type B connector X29.
  • Jumpers JP10 and JP12 - USB mode
