Unboxing and Setup Cables - Aster
Your progress
  • System setup block diagram
Materials Required
Bill of materials
VGA display/monitor
Accessory kit :
  -VGA cable
  -Power supply 7-27VDC
  -USB B type to USB A type cable
  -Ethernet cable
USB keyboard
Remove the Aster Carrier Board and the Colibri iMX6 Computer on Module from the blisters. Insert the computer on module into the X1 connector of the Aster Carrier Board on the bottom side, as tight as possible, with the module inclined ~30 to 45 degree in relation to the carrier board.
  • Connecting the computer on module to the Aster Carrier Board - Bottom side
Warning: Make sure that the module is well connected to the board. The image below have some checkpoints highlighted.
  • Computer on module connected to the Aster Carrier Board - Bottom Side
The Aster carrier board provides two ways to power-up the board: a standard 3.5mm power jack barrel connector using a external DC power supply and a USB micro B type, connector X4. In our case, we will use the power via micro USB connector, therefore it is necessary to close the jumper JP1, as shown in the image.
  • Jumper JP1 closed - USB power
Attention: The total power consumption of the system depends on the module/peripheral/accessories used. Please note that power available via Micro USB connector may not be sufficient for the modules or applications with high power requirements, since this configuration is not fully USB compliant. In such cases, it is recommended to use an external power supply to power-up the system.
Step 3
  • Connect an VGA monitor to the Aster X13
  • Connect a USB keyboard to the Aster X9.
  • Connect the Ethernet cable to the Aster X8. Note: The Ethernet cable must provide DHCP and Internet to the module.
  • Connect a USB micro B type to USB type cable to X4
  • VGA, Ethernet, USB keyboard, USB micro B type to USB A type connected to the Carrier Board
