Unboxing and Setup Cables - Iris
Your progress
  • System setup block diagram
Materials Required
Bill of materials
DVI display/monitor or HDMI display/monitor and DVI-HDMI adapter
Accessory kit :
  - Power supply 7-27VDC
  - USB-Serial converter
  - IDC to DB9 adapter cable
  - Ethernet cable
USB keyboard
Remove the Iris Carrier Board and the Colibri iMX6 Computer on Module from the blisters. Insert the computer on module into the X1 connector of the Carrier Board as tight as possible, with the module inclined ~30 to 45 degree in relation to the carrier board.
  • Connecting the computer on module to the Iris Carrier Board
Warning: Make sure that the module is well connected to the carrier board. The image below have some checkpoints highlighted.
  • Computer on module connected to the Iris Carrier Board
Connect the DB9 to IDC adapter cable to the X22 connector from the Iris.
Note: The adapter is included in the Toradex Cable Kit, the standard we used is normally called DTK or Intel standard.
  • IDC header connected to the Irisa Carrier Board
Step 3
Connect a USB-Serial converter to both the adapter cable and your host machine.
  • Serial setup for the Iris Carrier Board
Step 4
  • Connect a DVI display to X4 or if you have an HDMI display/monitor, use an DVI-HDMI adapter.
  • Connect an Ethernet cable to X15. Note: The Ethernet cable must provide DHCP and Internet to the module.
  • Connect a USB keyboard to X11.
  • Connect a power supply to the barrel jack X8. Attention: Double check that your power supply is within the Iris Carrier Board limits (7-27V) and that the polarity is not inverted. Also, make sure that the current capability of the power supply is enough (>>1A), or the system will shutdown unexpectedly sometimes.
  • DVI, Ethernet, USB keyboard and Power supply connected to the Iris Carrier Board
