Update the Linux Image - Iris Carrier Board - Colibri VFxx
Your progress
In this module you will:
  • Format an SD card.
  • Use an SD card to flash the new image to the module.
  • Access the Eboot bootloader and replace it with the U-Boot bootloader.
  • Flash a new Linux image to the module.
Materials Required
Bill of materials
Micro SD card with more than 2GB
Note: The following steps are meant to be run in the development workstation, and not on the target module, unless otherwise stated. Note: Whenever there is a reference to SD card, it means the micro SD card plus an adapter connected to the host machine, unless otherwise noted.
sudo apt-get update
sudo apt-get install zlib1g:i386 liblzo2-2:i386 libuuid1:i386 libusb-1.0-0:i386
sudo apt-get install gparted
user@host:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 0 3,9G 0% /dev
tmpfs 792M 50M 743M 7% /run
/dev/sda7 42G 30G 10G 75% /
tmpfs 3,9G 145M 3,8G 4% /dev/shm
tmpfs 5,0M 8,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/sda5 922M 340M 520M 40% /boot
/dev/sda8 178G 28G 141G 17% /usr/local
/dev/sdb5 620G 558G 31G 95% /home
tmpfs 792M 92K 792M 1% /run/user/1000
Step 3
  • Select *do nothing* after SD card insertion
Step 4
user@host:~$ df -h
/dev/mmcblk0p1 7,5G 296M 7,2G 4% /media/<user>/3E18-AADE
Step 5
Note: The following steps assume the SD card is listed as /dev/mmcblk0. Please adjust the instructions accordingly.
Warning: Backup your SD card data. The SD card will be formatted and all data will be lost.
sudo gparted /dev/mmcblk0
  • Gparted GUI
    Gparted GUI
Step 6
  • Unmount the SD card
    Unmount the SD card
Step 7
  • Delete the current SD card partitions
Step 8
  • Create new partition
Step 9
  • Select FAT32 file system
Step 10
  • Apply all operations
  • Acknowledge warning message
  • Formatting SD card
    Formatting SD card
  • SD card successfully formatted
Step 11
  • Mount the SD card
    Mount the SD card
Step 12
Step 13
sudo tar xjvf Colibri-VF_LXDE-Image_<bsp-version>-<date>.tar.bz2
Step 14
cd Colibri-VF_LXDE-Image_<bsp-version>
./update.sh -o /media/<user>/<partition_label>/
Step 15
Step 16
Insert the micro SD card in the SD/MMC connector, as illustrated. Notice that for this step, the SD/USB adapter is not required:
  • Micro SD card slot highlighted
Step 17
Make sure that you have a working serial terminal application on your host machine.
Note: You can go back to the last section if there are any doubts regarding the serial terminal application and its configuration.
Simultaneously apply power to the embedded system and press the SPACE key in your keyboard a few times, while focused in the serial terminal. If you are successful, this procedure will stop the bootloader and you will have a terminal with the following prompt:
Toradex Bootloader 1.1 BETA 2 for Colibri Built Apr 28 2015
CPU: MVF61 500 Mhz
Flash: 512 MB
RAM: 256 MB
Using ECC Type: 7
Booting from fuses.
Colibri VF61 module version 1.2A
Initiating image launch in 1 seconds.
BootLoader Configuration:
C) Clear Flash Registry
X) Enter CommandPrompt Mode
D) Download image to RAM now
Enter your selection:
Note: If you press the SPACE key too late, the system will start booting. Power-off and try again.
Step 18
Press X to enter the CommandPrompt mode, then enter flashloader colibri_vf/u-boot-nand.imx to flash U-Boot:
Enter your selection: x
Bootloader image size: 424728 bytes.
Loading done.
Flashing bootloader.
Writing 208 sector(s) of bootloader code from sector 64.
Erasing block 1
Erasing block 2
Erasing block 3
Erasing block 4
Flashing completed.
Step 19
Enter reboot or power-cycle the board, immediately pressing any key to prevent the system from booting.
>reboot
Note: If you press any key too late, the system will start booting. Power-off and try again.
Step 20
To finish updating the system, run the commands:
nand erase.part ubi
run setupdate
run update
  • Updating the module
    Updating the module
After a while, the system will boot with the updated Linux image and you will see the login message:
  • Login to the Linux terminal
Step 21
If you are new to Linux or the command-line interface and want to learn some basic commands, please read this article
