Build from Command-line
Your progress
In this section, you will build a simple hello-world using the previously configured Software Development Kit (SDK).
In this module you will:
  • Write a hello-world
  • Cross-compile from command-line
  • Deploy to the target through the network
Change Ubuntu shell from dash to bash:
sudo update-alternatives --install /bin/sh sh /bin/bash 100
Skipping this step might break instructions ahead. Still you can have both dash and bash installed if you wish. To do so, please run the following commands to install dash as an alternative and select bash as the current shell:
sudo update-alternatives --install /bin/sh sh /bin/dash 50
sudo update-alternatives --config sh
Create a file named hello-world.c with the following contents:
hello-world.c
#include <stdio.h> int main(int argc, char *argv[]){ printf("Hello world!\n"); return 0; }
Step 3
Cross-compile the code. Make sure that you exported the required variables in the last how-to section.
Note: The Toradex SDK must be installed in the system and the correct variables exported. If you have any doubts, please go back to the last how-to section "Configure Toolchain".
Warning: If you open a new terminal window, you must export the variables again. To check if a variable is set, use the echo command, for instance: "echo ${CC}".
${CC} -Wall hello-world.c -o hello-world
Step 4
Log in to the board using picocom. Find the target IP address. Search for the inet addr from the eth0 interface:
root@computer-on-module:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:14:2D:49:E8:8E
          inet addr:192.168.0.21  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::214:2dff:fe49:e88e/64 Scope:Link
          inet6 addr: 2804:14d:ac82:116c:214:2dff:fe49:e88e/64 Scope:Global
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:699 errors:0 dropped:0 overruns:0 frame:0
          TX packets:562 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:86400 (84.3 KiB)  TX bytes:56325 (55.0 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:330 errors:0 dropped:0 overruns:0 frame:0
          TX packets:330 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:30218 (29.5 KiB)  TX bytes:30218 (29.5 KiB)
usb0      Link encap:Ethernet  HWaddr 00:14:2D:FF:FF:FF
          inet addr:192.168.11.1  Bcast:192.168.11.255  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
In this example, the target IP address is 192.168.0.21.
Step 5
Back to the host computer, copy the application to the target using SCP. You may be prompted to continue during the first connection. If this is the case, just type yes and press Enter:
user@host:~$ scp hello-world root@192.168.0.21:/home/root
The authenticity of host '192.168.0.21 (192.168.0.21)' can't be established.
ECDSA key fingerprint is SHA256:+N5WCsnEtQXEnYWyMXxswZLf4hEVgmHPOR2pZgJRdrg.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.0.21' (ECDSA) to the list of known hosts.
Step 6
In the target terminal, run the application:
root@computer-on-module:~# ./hello-world
Hello world!
