Configure Eclipse
Your progress
In this section, you will configure the Eclipse IDE for cross-compilation and learn how to use it to deploy your application to the target.
In this module you will:
  • Download and install the latest Eclipse IDE for C/C++ developers
  • Configure a C project for cross-compilation using the provided Software Development Kit (SDK)
  • Cross-compile a hello-world application
Go to the Eclipse packages page and download the Eclipse installer (or the Eclipse IDE for C/C++ developers. We will use the installer):
  • Download Eclipse Installer
Note: Although a version of Java comes installed with Ubuntu, some issues have been reported regarding the Eclipse installation due to the lack of Java. If facing problems, you may try to install java with the command "sudo apt-get update; sudo apt-get install default-jre".
Extract the contents of the downloaded file and start the installer. You will see a window such as the presented below. Select the Eclipse IDE for C/C++ Developers, as highlighted:
  • Available Eclipse IDEs - select the C/C++ IDE
Step 3
Choose the installation folder and click the install button.
Attention: Remember the installation folder path. It will be required later.
  • Installation setup
    Installation setup
Step 4
Accept the license:
  • License agreement
    License agreement
Step 5
A progress bar will display the installation status:
  • Installation in progress
Step 6
Before finishing the installation, you will be prompted regarding some Eclipse certificates. Select all and click ok:
  • Eclipse trusted certificates
Step 7
Close the installation. Do not launch the Eclipse IDE for C/C++ Developers:
  • Start the Eclipse IDE
Instead of clicking the launch button, open a new terminal and:
  • Go to the Eclipse installation folder. By default, for the Eclipse Neon, it is a directory named cpp-neon/eclipse under the home folder. E.g.: ~/cpp-neon/eclipse
cd ~/cpp-neon/eclipse
Attention: If you close Eclipse and the terminal, you need to export the variables again before starting Eclipse.
  • Export the Toradex SDK variables and run eclipse:
./eclipse
Warning: In the first command above, notice that there is a dot and a space before the path to the script.
Step 8
You will be asked to choose a workspace to keep your projects and configurations:
  • Default workspace
    Default workspace
Step 9
In the welcome page, select:
  • Create a new C project
  • Default workspace
    Default workspace
Step 10
Give a name to the project. Select:
  • Project type as Executable --> Hello World ANSI C Project
  • Toolchain as Cross GCC
  • Project setup part 1
Step 11
Type your name and proceed:
  • Project setup part 2
Step 12
Select the debug and release configurations and click the next button:
  • Project setup part 3
Step 13
Leave the cross compiler prefix and path empty:
  • Project setup part 4
Click the finish button.
Step 14
In the toolbar, click Project and select Properties from the drop down menu:
  • Project Properties
    Project Properties
Step 15
Go to the tab:
  • C/C++ Build --> Settings
Choose the option:
  • Cross GCC Compiler
From the Configuration dropdown menu:
  • Select [ All configurations ]
In the Command field, replace the contents with the Cross Compiler variable "${CC}", as presented below:
${CC}
See the image for reference:
  • Setting the Command variable
Step 16
Go to the tab:
Choose the option:
  • Cross GCC Compiler --> Miscellaneous
In the Other flags field, replace the contents with the variable "${CFLAGS} -c", as presented below:
${CFLAGS} -c
  • Setting the Other Flags to use variable from Cross Compiler Enviroment
Note: The current level of compiler optimization set in CFLAGS (-O2) might impair debug to some extent. If you have trouble debugging applications of your own, you may try substituting '${CFLAGS} -c' to '-Og -pipe -g -feliminate-unused-debug-types -c'
Step 17
Go to the tab:
Choose the option:
  • Cross GCC Linker
In the Command field, replace the content with the Cross Compiler variable "${CXX}", as presented below:
${CXX}
Step 18
Go to the tab:
Choose the option:
  • Cross GCC Linker --> Miscellaneous
In the Linker flags field, replace the content with the variable "${LDFLAGS}", as presented below:
${LDFLAGS}
  • Setting the Other Flags to use variable from Cross Linker Enviroment
Step 19
Go to the tab:
Choose the option:
  • Cross GCC Assembler
In the Command field, replace the content with the Cross Compiler variable "${AS}", as presented below:
${AS}
After you are done:
  • Click the OK button
You will return to the previous menu:
  • Click next to proceed
Step 20
Press Ctrl+B or click the build all button to build the project. A build log will tell if you succeeded:
  • Build button and log
