Debug Using Eclipse
Your progress
This section of the Module 2 will help you to configure the debug environment, in order to deploy the code to the target and debug it.
In this module you will:
  • Use the Remote System Explorer perspective
  • Configure the IDE for debugging
  • Deploy and debug the hello world application
In the top-right corner of the window:
  • Click the Open Perspective button
  • Open a new perspective
From the Open Perspective list:
-Select Remote System Explorer
  • Select the Remote System Explorer perspective
Step 3
The IDE will open a different set of tabs, i.e. a new perspective, meant for accessing a remote device. We are interested in the Remote Systems tab to left:
  • Click the Define a connection to remote system button
  • Remote System Explorer perspective
Step 4
A window will open. From the list:
  • Select SSH Only
  • Create an SSH connection
Step 5
Fill the fields:
  • Host Name is the board IP
  • Connection Name is the connection label
  • Description might be left blank
Note: If your network allows, it might be practical to set the board IP as static. Please consult this article for more information.
  • Configure the SSH connection
Step 6
The new connection will be listed in the Remote Systems tab. Right-click it and:
  • Select the Connect option
  • Connect to the recently created device
Step 7
In the Enter Password pop-up window:
  • User ID: root
  • Password (optional): (must be left blank)
  • Login request
    Login request
Step 8
You may be prompted to accept the host authentication. Click yes:
  • Accept the authentication
Step 9
Use the Remote Systems tab to navigate through the target filesystem:
  • Target filesystem
    Target filesystem
Step 10
Switch back to the C/C++ perspective using the button in the top-right corner. Right-click the project in the Project Explorer tab:
  • Select Debug as --> Debug Configurations...:
  • Configure the debug options
Step 11
Maximize the C/C++ Remote Application options and select hello-world Debug. If there are no options to select, right-click the C/C++ Remote Application and select the new option. In the Main tab:
  • Give a name such as hello-world Debug to this debug option
  • Fill the C/C++ Application field with Debug/hello-world
  • Select Debug from the Build Configuration dropdown menu
  • Fill the Remote Absolute File Path for C/C++ Application field with the full path to where the application should be deployed on the target plus the binary name, e.g. /home/root/hello-world-debug
  • Last, create a new connection by clicking the New.. button
  • Main debug configuration tab
Step 12
From the dropdown menu in the Create a New Connection pop-up window:
  • Select SSH and click OK
  • SSH connection
    SSH connection
Step 13
In the Edit Connection pop-up window, fill the fields:
  • Connection name can be left as default (Remote Host)
  • Host is the target IP
  • User is root
  • SSH connection configuration
Step 14
Switch to the Debugger tab. Replace the GDB Debugger field to the "${GDB}" environment variable, such as illustrated in the figure below:
${GDB}
  • Using GDB envoriment variable
Click the Close button.
Step 15
  • Select Run as --> Run Configurations...:
  • Configure the run options
Step 16
Maximize the C/C++ Remote Application options and select hello-world Release. If there are no options to select, right-click the C/C++ Remote Application and select the new option. In the Main tab:
  • Give a name such as hello-world Release to this debug option
  • Fill the C/C++ Application field with Release/hello-world
  • Select Release from the Build Configuration dropdown menu
  • Fill the Remote Absolute File Path for C/C++ Application field with the full path to where the application should be deployed on the target plus the binary name, e.g. /home/root/hello-world-release
  • Last, select the previously configured option Remote Host from the Connection dropdown menu.
Click the close button.
Step 17
Edit the source-code to add a loop, therefore you can debug it in the next steps:
#include <stdio.h>
#include <stdlib.h>
int main(void) {
    int mul = 1, i;
    puts("Hello World!"); /* prints Hello World! */
    for(i = 0; i < 5; i++){
        mul = 2*mul;
        printf("Loop %d - mul=%d", i, mul);
    return EXIT_SUCCESS;
Step 18
Back to the C/C++ perspective, you will find two buttons in the top-left corner of the window. Both of them are used to build the application. The buttons are highlighted in the picture below:
  • Build buttons
    Build buttons
  • Click the arrow between them
  • Select the Debug option
  • Click the Build All button, or just press Ctrl+B
Step 19
There are two buttons to debug or run the application. They are highlighted in the picture below:
  • Debug and Run buttons
  • Click the arrow to the right of the Debug button.
  • Select the previously configured hello-world Debug option, as presented in the picture above.
  • If nothing happens, just click the debug button.
Warning: Sometimes, mostly after restarting Eclipse, the debug may fail for the first time you try to run it. Just try again and it might work.
Step 20
A pop-up window will tell you that the perspective will be switched to the debug perspective.
  • Click yes to acknowledge.
Note: You can always switch perspectives through the buttons in the top-right corner.
  • Warn about perspective switch to the debug mode
Step 21
The debug perspective provides information and useful features in many different places:
  • There are buttons in a play/pause fashion in the top of the window. They are responsible for controlling the flow of the code, along with the breakpoints.
  • The Debug tab displays the application status - running or suspended and in which line of the source-code it is, for instance. You can easily verify and run the disassembled code, instruction by instruction, by clicking the Instruction Stepping Mode.
  • In the Console tab, everything printed to the stdout, such as when using functions like printf, will be displayed.
  • The Variables tab displays the application variables and their current status.
  • The Breakpoints tab lists all the breakpoints added and allows for quickly enabling/disabling them.
The picture below presents the debug perspective when it is started. The program will be halted in the first line of the main function. Take some time to get used to this perspective:
  • The debug perspective
Step 22
Add a breakpoint to the line 20:
  • Either right-click the number of the line you want to introduce the breakpoint and select Toggle Breakpoint from the options menu;
  • Or click anywhere in the desired line and press Crtl+Shift+B.
  • Adding a breakpoint by right-clicking the line number
  • Breakpoint added - the areas of interest are highlighted
Step 23
Run the program:
  • Either click the Resume (play) button
  • Or press the F8 key
Step 24
Run step-by-step:
  • Either click the Step into button
  • Or press the F5 key
Keep pressing F5 while looking at the Variables tab. The values of i and mul will change as the for loop is executed. The last line to be executed is the return EXIT_SUCCESS;. By then, the Variables tab should look like this:
  • Variables updated as the code is executed
