Apalis Family Specification
This document is a specification which defines the Apalis Computer-on-Module (referred to hereafter as “module”). It defines the interfaces in terms of functional and electrical characteristics, signal definitions and pin assignments. It also defines the mechanical form factor, including key dimensions.
A PDF version of this document can be downloaded using the link below:
Motivations
The following motivations are central to the definition of the new Apalis module specification. It should be clearly noted that the Apalis computer module family is not a replacement for the Colibri computer module family. Both are very complementary to one another, and whilst may overlap in terms of suitability for some specific applications, they differ significantly in a variety of areas including, but not limited to, size, features and cost.
  1. As ARM based SoC (System-on-Chip) technology continues to evolve, support for a wider range of interfaces is being added, such as PCI-express, Gigabit Ethernet, HDMI, etc. The Apalis module will enable customers to benefit from these evolutions. It should also be noted that nothing in the module specification restricts any Apalis based products from using non-ARM architectures. In this respect, the specification is very architecture independent.
  2. With the recent advancements in ARM based SoC technology, including but not limited to the addition of a wider variety of high speed interfaces and the huge advancement in graphics capability, such as 2D/3D hardware acceleration, full HD rendering and multiple display support, it is possible to access markets previously reserved for higher power, x86 based technologies, such as the Intel Atom. The Apalis module will provide a platform with which to enable this technology to compete in these application areas and address the shortcomings of existing x86 based products.
  3. As the pace in performance advancement is accelerating faster than the increase in performance efficiency, we are seeing an increasing trend in power consumption in high performance ARM based SoCs. Whilst passive cooling is still perfectly viable in many applications, this increase in power consumption means that allowances for additional cooling solutions, such as heat spreaders for conduction cooling, must be made. The Apalis module provides a robust, rigid mounting mechanism to support such thermal solutions.
  4. The Apalis module has been developed from in depth research into different technologies, rather than a specific SoC. This will help to future proof the Apalis module architecture whilst making it suitable for supporting a wide range of SoCs.
  5. The Apalis module encapsulates the complexity associated with modern day electronic design, such as high speed impedance controlled layouts with high component density utilising blind and buried via technology. This allows the customer to create a carrier board which implements the application specific electronics which is generally much less complicated. The Apalis module takes this one step further and implements an interface pin out which allows direct connection of real world I/O ports without needing to cross traces or traverse layers, referred to as Direct Breakout™. This becomes increasingly important for customers as more interfaces move toward high speed, serial technologies that use impedance controlled differential pairs, as it allows them to easily route such interfaces to common connectors in a simple, robust fashion.
Module Overview
Architecture
The block diagram below shows the basic architecture of the Apalis module, depicting the standard interfaces and some examples of type specific interfaces.
Apalis Architecture Block Diagram
Features
Features of the Apalis module are split into two distinct groups: standard and type specific.
Standard features are features that are allocated for use on every Apalis module. Although they may not be fully supported or implemented on every module, pins are reserved specifically for them and shall not be used for any other purpose in the future. This guarantees electrical compatibility between designs which only make use of standard features, helping to ensure carrier board design longevity and support for future module designs.
A type specific feature is a feature which is not guaranteed to be functionality or electrically compatible between modules. If a carrier board design uses such features, then it is possible that other modules in the Apalis module family do not provide these features and instead provide other features on the associated pins. In this case, Apalis modules which are suitable for use in the carrier board design may be restricted.
Interface Summary
This section provides a list of interfaces that are defined as standard, and some examples of those interfaces which may be type specific.
Standard Interfaces
By dedicating specific pins for specific functions, the Apalis module family is able to ensure electrical and functional compatibility between module family members, helping future proof designs against advances in technology and providing an upgrade path for products, decoupling the product from reliance on a specific device or device family. Every effort shall be taken to maintain functional compatibility between module family members where it commercially and technically viable.
The table below shows the standard interfaces that are provided by an Apalis module. The “GPIO Capable” column indicates whether, for a specific interface, the assigned pins can be used as GPIOs. Yes and No are self-explanatory, Optional indicates that it may be possible for some modules, but not all. The “Standard” column indicates the number of interfaces that the specification allows for in the standard pin out. Customers should consult the datasheet for specific Apalis module variants to check which interfaces are available for that module.
Description
Standard
Note
GPIO Capable
4/5 Wire Resistive Touch
1
Touch wiper shared with analogue input 4
No
Analogue Inputs
4
Minimum 8 bit resolution, 0-3.3V nominal range
No
Analogue Audio
1
Line in L&R, Microphone in, Headphone out L&R
No
CAN
2
Optional
Digital Audio
1
HDA
Yes
Dual Channel LVDS Display
1
1x or 2x single channel or 1x dual channel mode
No
Gigabit Ethernet
1
No
GPIO
8
Yes
HDMI (TDMS)
1
No
I2C
3
Including DDC
Yes
Parallel Camera
1
8 bit YUV
Optional
Parallel LCD
1
24 bit resolution
Optional
PCI-Express (lane count)
1
Single lane and clock
No
PWM
4
Yes
SATA
1
No
SDIO
1
4 bit
Yes
SDMMC
1
8 bit
Yes
S/PDIF
1
1 input, 1 output
Optional
SPI
2
Yes
UART
4
1 Full Function, 1 CTS/RTS, 2 RXD/TXD only
Yes
USB
4
2 x USB 3.0, 2 x USB 2.0, 1 x shared host/client USB 2.0
No
VGA
1
No
Type specific interfaces allow for the possibility of including interfaces which may not yet exist or be widely adopted, or interfaces which may be specific to a particular device or groups of devices. They also offer a mechanism of extending features which are present on the standard interfaces, such as providing additional PCI-Express lanes. This provides the Apalis module with the flexibility of being able to reconfigure a subset of pins for different uses between different modules.
It should be noted that type specific interfaces will be kept common across modules that share such interfaces where possible. For example, if both module A and module B have three additional PCI-Express lanes which are available in the same configurations as a type specific interface, then they shall be assigned to the same pins in the type specific area of the connector. Hence, both module A and module B shall share compatibility between these parts of the type specific interface.
Interfaces: Apalis T30
The table below shows the interfaces that are supported on the Apalis T30 module, and whether an interface is provided on standard or type specific pins. The PCI-Express interface is an example of an interface that makes use of standard and type specific pins – 1 lane is provided as part of the standard interface pin out and the additional 4 lanes are type specific.
Feature
Apalis™ T30
Standard
Type Specific
4 Wire Resistive Touch
1
1
Analogue Inputs
4
4
Analogue Audio
1
1
CAN
2
2
CSI (Dual Lane)
2
2
DSI
2*
1
1 (2x Single or 1x Dual)
1
Gigabit Ethernet
1
1
GPIO
129*
8
6
HDA
1
1
HDMI (TDMS)
1
1
I2C
4*
3
I2S (multiplexed with HDA)
1
1
Parallel Camera
1 (12 bit)
1 (8 bit)
1 (additional bit)
Parallel LCD
1 (24 bit)
1
5
1(1 Post)
4 (1 Port)
PWM
4
4
SATA
1
1
SDIO/SDMMC
3
2 (1x 8 bit, 1x 4 bit )
1
S/PDIF
1
1
SPI
4*
2
UART
5*
4
USB OTG
1 (USB 2.0)
1
USB Host
2 (USB 2.0)
2
VGA
1
1
  * Some of the interfaces are available as alternative functions. Please refer to the Apalis T30 datasheet.
Interfaces: Apalis iMX6
The table below shows the interfaces that are supported on the Apalis iMX6 module, and whether an interface is provided on standard or type specific pins. On Apalis iMX6, the type specific provides interface like MIPI-CSI-2, MIPI-DSI, Media Local Bus, USB, GPIOs and few control signals.
Feature
Apalis™ iMX6
Standard
Type Specific
1
1
Analogue Inputs
4
4
Analogue Audio
1
1
CAN
2
2
CSI (Quad Lane)
1
1
DSI (Dual Lane)
1
1
1
Gigabit Ethernet
1
1
GPIO
134*
8
 11
AC97/I2S
2*
1
HDMI (TDMS)
1
1
I2C
3
3
Parallel Camera
1
1
Parallel LCD
1 (24 bit)
1
1
1
PWM
4
4
SATA
1
1
SDIO /SDMMC
3*
2 (1 x 8bit, 1x 4 bit)
S/PDIF
1
1
SPI
3*
2
UART
5*
4
USB OTG (host/device)
1 (USB 2.0)
1
USB Host
4 (USB 2.0)
3
1
VGA
1
1
MLB
1
1
 * Some of the interfaces are available as alternative functions. Please refer to the Apalis iMX6 datasheet.
Module and Carrier Board Compatibility
To ensure any carrier board design is 100% compatible with all Apalis modules, only the standard interfaces should be used.
If a custom carrier board design uses any type-specific interfaces, then it may not be 100% compatible with all Apalis modules. Where type specific interfaces are common between different Apalis modules, they shall be provided on the same pins where possible. Therefore, designs that make use of the type specific interfaces of a specific Apalis module may be compatible with other Apalis modules – please check the interface specifications of individual Apalis modules carefully.
Connector
The Apalis module is based around the MXM3 (Mobile PCI-Express Module) edge connector. This connector has been adopted by various manufacturers for use in the embedded CoM market and, based on the range of connectors available on the market at the current time, is the only suitable connector based on the Apalis module requirements.
A picture of the MXM3 connection can be found below.
MXM3 Connector
The connector provides a total of 310 usable contacts. A large proportion of the contacts are reserved for the standard interfaces, whilst a smaller subset is reserved for type specific interfaces.
The recommended connector for the Apalis module is the JAE MM70-314-310B1, which has a board height of 3.0mm.
MXM SnapLock™
The Apalis module can be fixed easily to the carrier board using either M3 screws or a unique connector mechanism called MXM SnapLock™. MXM SnapLock™ uses an edge retention connector which is mounted on the carrier board and retains the Apalis module in place using two metal retaining clips and locating pips. For many applications and during development, this provides a simple retention mechanism.
For applications where the system is likely to experience a high level of vibration or harshness, a set of M3 bolts combined with SMT aluminium stand-offs mounted in the carrier board can be used.
Interface Specifications
Signal Naming Convention
Where there are multiple signals of the same type which are part of a group and are identified by a suffix index (e.g. PWM1, PWM2, etc.), then the index always starts with a one (as opposed to a zero). For signals which are named after a standard or follow a widely acknowledged common naming convention (such as the Ethernet or LVDS interfaces), they may use a zero based index.
Differential pair signal components are suffixed with either a “+” or “-“. Active low signals are suffixed with a “#”. The underscore (“_”) is used as a separator to split component parts of the signal name (such as signal group, channel and signal descriptor components) to make the signal name easy to read and interpret.
Signal Definition
This section contains detailed information on the signals provided by the Apalis module, such as signal class and voltage domains. Please refer to the key in figure 5 for the various voltage domain definitions.
Only those voltage domains marked in green are required to be supplied externally for module operation, and those in orange are optional. The domains that are not marked in green or orange are not required to be supplied to the module.
Some of the voltage domains specified are used purely to indicate power supply tolerances on pins which are specified to operate on that domain. Hence, they are not necessarily power supplies that are generated by the module nor required by the module.
Voltage Domain
Nominal Value
Absolute Maximum Value
Definition
VCC
3.3V
3.5V
Main system power supply from carrier board.
VCC_IO
3.3V
3.5V
Multi-purpose I/O.
VCC_BACKUP
3.3V
3.5V
Backup supply for features such as Real-Time Clock (RTC)
VCC_ETH
TBD
TBD
Ethernet centre tap power supply. Controller dependent and output only.
VCC_USB
5.0V
5.5V
USB bus power supply.
VCC_HDMI
5.0V
5.5V
Hot plug detected voltage from connector display.
AVCC
3.3V
3.5V
Analogue power supply from carrier board.
AVCC_IO
3.3V
3.5V
Analogue I/O.
Check carefully in individual signal definitions to determine the voltage domain to which a signal belongs. Do not assume that a signal which shares a group or class name with a voltage domain is automatically on that voltage domain. For instance, the VCC_HDMI voltage domain is applicable for supply voltage and control signals, but not for the differential mode signals.
JTAG and Generic Test Point Interfaces
Every Apalis module provides a series of 20 test points; 10 along the left side and 10 along the right side of the bottom of the module PCB.
Each set of test points is symmetrical about the centered Y-axis (the Y plane is orthogonal to the connector edge). These test points shall provide access to any JTAG interface that is supported by the module (this is normally the JTAG interface as provided by the SoC) as well as module specific signals, generally for the purposes of measurement.
The JTAG interface pins are always the topmost 7 pins on the left edge of the module when the module is viewed from the top side. These test points are always reserved for the JTAG interface and will never provide any other signals. They are depicted by green primitives in figure 7. The remaining 13 test points are module specific pins. The signals connected to these test points are defined in the datasheet for each individual Apalis module. They are depicted by orange primitives in figure 7.
Apalis JTAG Pads
Parallel LCD
The parallel LCD interface is a 24 bit interface. The signals are defined in groups of pins assigned to the Red, Green and Blue, with R7, G7 and B7 being the Most Significant Bits (MSBs) and R0, G0 and B0 being the Least Significant Bits (LSBs) for the respective colours. To ensure compatibility between modules, the display interface should always be used in 24 bit mode.
To use displays which require fewer bits (e.g. 18 or 16 bit displays), simply do not connect the bottom n LSBs for each colour, where n is the number of signals that are not required for a specific colour. For instance, to connect an 18 bit display, R0, R1, G0, G1, B0 and B1 will remain unused, and R2, G2 and B2 become the LSBs for this configuration. More detailed information regarding configuration shall be provided in the reference design guide.
Parallel Camera
For compatibility between modules, the parallel camera interface shall normally be configured by default to operate in 8 bit YUV mode. Modules may support other modes with greater bit depths; in such cases, additional pins will be made available as type specific interfaces as necessary, and compatibility between different modules for such modes cannot be guaranteed.
Physical Pin Definition and Location
Signal definitions in terms of physical pins and their locations on the Apalis module can be found in the appendix. The table in appendix C defines the physical pins and their location on the Apalis module. This definition also includes missing pins (marked with a grey cell) to represent the physical space on the connector where these pins are missing.
The total number of usable pins on the module is 310. The ground pin count is 41 (~13%). The main power supply (VCC) power pin count is 10.
Direct Breakout™
Direct Breakout™ aims to reduce complexity of carrier board routing from the module connector to the real world I/O ports by making it possible to route signals without requiring any trace gathering or cross over for critical signals. This is achieved by taking care of the complexity of routing high speed, impedance critical signals from the source IC to the edge connector on the Apalis module. I/O is generally gathered into functional “rooms” on the connector so that all signals associated with a specific interface are in one place, reducing routing complexity.
Direct Breakout
The above image shows the concept of direct breakout by illustrating how complex routing and layout is encapsulated on the Apalis module, providing the potential for simple routing on the carrier board.
Mechanical Specifications
The Apalis module form factor mechanical dimensions have been specified based on careful analysis of required board space for typical device packages (e.g. 23mm x 23mm 0.8mm pitch SoC, 4 x16 memory ICs, power ICs and peripheral ICs) and certain key features (e.g. as dual channel [2 x 32bit] memory bus). This has been balanced with the requirement to keep the form factor as small as is reasonably possible. A single mechanical size has been defined.
Mounting and Fixation
MXM SnapLock™ or M3 screws in combination with threaded standoffs shall be used to fasten the module to the carrier board. A keep out area on the bottom side of the module located in the centre is reserved to allow a mechanical standoff on the carrier board to come into contact with the PCB when the module is fully inserted. This will allow pressure to be placed on the top side of the module which may be required for thermal cooling solutions without exerting a bending moment on the PCB. Carrier board design requirements shall be detailed in a separate carrier board design guide application note.
Module Size
Width, Length, Height and Key Primitives
The below image shows a mechanical drawing of the outline of the Apalis module together with key dimensions.
Apalis Mechanical Dimensions - Top
The Apalis module extends in the Y plane (the plane which is orthogonal to the connector edge) for 45mm from one PCB edge to the other. The thickness of the Apalis module PCB is 1.2mm.
Pin Numbering
The diagrams in figures 10 and 11 show the pin numbering schema on both sides of the module. The schema deviates from the unrelated MXM3 standard pin numbering schema. Pins on the top side of the module have an even number and pins on the bottom side have an odd number.
Apalis Pin Positions - Top
Apalis Pin Positions - Bottom
The pin number increases linearly as a multiple of the pitch – that is, pins which are not assembled in the connector (between pins 18 and 23) are also accounted for in the numbering (pins 19 through 22 do not exist). Similarly, pins which do not exist due to the connector notch are also accounted for (pins 166 through 172).
Electrical Specifications
Power Supplies
All Apalis modules are capable of being powered with a single main power supply powering VCC and AVCC, and if required, a low current backup power supply for purposes such as Real Time Clock (RTC) support. To minimise the impact of noise on the sensitive analogue parts of the system, it is highly recommended that VCC and AVCC be supplied through independent power supplies (for instance, AVCC can be generated via an LDO due to its low current requirements). Based on the power supply rating of the connector pins and the number of pins assigned as main (VCC) power supply pins, the maximum current draw from VCC is 5 amps.
Further carrier board power supply requirements in terms of power rating, isolation and decoupling, bulk capacitance and characteristics such as ramp up rate, etc. will be detailed in a separate carrier board design guide application note.
Power Control
There are no power control features built into the module from the power on/power off perspective. If a specific implementation requires a power on button, then it shall be the responsibility of the carrier board to implement this functionality.
VCC and AVCC are the two minimum power supplies which are required to be present for the module to become operational. Once VCC is present and is within specification, then the module will power up and start normal operation automatically.
VCC_BACKUP is not required for the module to start normal operation, however, it is permanently required if the application requires features which rely on this supply being always on, such as the Real-Time Clock (RTC).
Back Feed Protection
Protection from back feeding from devices on the carrier board can be achieved using the signal “POWER_ENABLE_MOCI”. This signal will be asserted by the module to indicate that the carrier board can power up any external devices (such as signal transceivers, converters, level shifters, secondary MPUs, etc.) which may otherwise cause undesired back feeding prior to and during the module power up process. Detailed information on the use of this signal shall be provided in a separate carrier board design guide application note.
Appendix A – Module Top Side Signal Definition
Pin Number
Signal Group
Signal Name
Signal Class
Voltage Domain
2
PWM
PWM1
Output
VCC_IO
4
PWM2
Output
VCC_IO
6
PWM3
Output
VCC_IO
8
PWM4
Output
VCC_IO
10
CAN
VCC
Power
VCC
12
CAN1_RX
Input
VCC_IO
14
CAN1_TX
Output
VCC_IO
16
CAN2_RX
Input
VCC_IO
18
CAN2_TX
Output
VCC_IO
24
System Control
POWER_ENABLE_MOCI
Output
VCC_IO
26
RESET_MOCI#
Output
VCC_IO
28
RESET_MICO#
Input
VCC_IO
30
Gigabit Ethernet
VCC
Power
VCC
32
ETH1_MDI2+
Differential Pair
N/A
34
ETH1_MDI2-
Differential Pair
N/A
36
VCC
Power
VCC
38
ETH1_MDI3+
Differential Pair
N/A
40
ETH1_MDI3-
Differential Pair
N/A
42
ETH1_ACT
Output
VCC_IO
44
ETH1_LINK
Output
VCC_IO
46
ETH1_CTREF
Analogue Output
VCC_ETH
48
ETH1_MDI0-
Differential Pair
N/A
50
ETH1_MDI0+
Differential Pair
N/A
52
VCC
Power
VCC
54
ETH1_MDI1-
Differential Pair
N/A
56
ETH1_MDI1+
Differential Pair
N/A
58
USB*
VCC
Power
VCC
60
USBO1_VBUS
Input
VCC_USB
62
USBO1_SSRX+
Differential Pair
N/A
64
USBO1_SSRX-
Differential Pair
N/A
66
VCC
Power
VCC
68
USBO1_SSTX+
Differential Pair
N/A
70
USBO1_SSTX-
Differential Pair
N/A
72
USBO1_ID
Input
VCC_IO
74
USBO1_D+
Differential Pair
N/A
76
USBO1_D-
Differential Pair
N/A
78
VCC
Power
VCC
80
USBH2_D+
Differential Pair
N/A
82
USBH2_D-
Differential Pair
N/A
84
USBH_EN
Output
VCC_IO
86
USBH3_D+
Differential Pair
N/A
88
USBH3_D-
Differential Pair
N/A
90
VCC
Power
VCC
92
USBH4_SSRX-
Differential Pair
N/A
94
USBH4_SSRX+
Differential Pair
N/A
96
USBH_OC#
Input
VCC_IO
98
USBH4_D+
Differential Pair
N/A
100
USBH4_D-
Differential Pair
N/A
102
VCC
Power
VCC
104
USBH4_SSTX-
Differential Pair
N/A
106
USBH4_SSTX+
Differential Pair
N/A
108
UART
VCC
Power
VCC
110
UART1_DTR
Output
VCC_IO
112
UART1_TXD
Output
VCC_IO
114
UART1_RTS
Output
VCC_IO
116
UART1_CTS
Input
VCC_IO
118
UART1_RXD
Input
VCC_IO
120
UART1_DSR
Input
VCC_IO
122
UART1_RI
Input
VCC_IO
124
UART1_DCD
Input
VCC_IO
126
UART2_TXD
Output
VCC_IO
128
UART2_RTS
Output
VCC_IO
130
UART2_CTS
Input
VCC_IO
132
UART2_RXD
Input
VCC_IO
134
UART3_TXD
Output
VCC_IO
136
UART3_RXD
Input
VCC_IO
138
UART4_TXD
Output
VCC_IO
140
UART4_RXD
Input
VCC_IO
142
MMC
GND
Power
GND
144
MMC1_D2
Bidirectional
VCC_IO
146
MMC1_D3
Bidirectional
VCC_IO
148
MMC1_D4
Bidirectional
VCC_IO
150
MMC1_CMD
Bidirectional
VCC_IO
152
MMC1_D5
Bidirectional
VCC_IO
154
MMC1_CLK
Output
VCC_IO
156
MMC1_D6
Bidirectional
VCC_IO
158
MMC1_D7
Bidirectional
VCC_IO
160
MMC1_D0
Bidirectional
VCC_IO
162
MMC1_D1
Bidirectional
VCC_IO
164
MMC1_CD#
Input
VCC_IO
174
SDIO
VCC_BACKUP
Power
VCC_BACKUP
176
SD1_D2
Bidirectional
VCC_IO
178
SD1_D3
Bidirectional
VCC_IO
180
SD1_CMD
Bidirectional
VCC_IO
182
GND
Power
GND
184
SD1_CLK
Output
VCC_IO
186
SD1_D0
Bidirectional
VCC_IO
188
SD1_D1
Bidirectional
VCC_IO
190
SD1_CD#
Input
VCC_IO
192
Digital Audio
GND
Power
GND
194
DAP1_MCLK
Output
VCC_IO
196
DAP1_D_OUT
Output
VCC_IO
198
DAP1_RESET#
Output
VCC_IO
200
DAP1_BIT_CLK
Output
VCC_IO
202
DAP1_D_IN
Input
VCC_IO
204
DAP1_SYNC
Output
VCC_IO
206
VGA
GND
Power
GND
208
VGA1_R
Output
N/A
210
VGA1_G
Output
N/A
212
VGA1_B
Output
N/A
214
VGA1_HSYNC
Output
VCC_IO
216
VGA1_VSYNC
Output
VCC_IO
218
HDMI
GND
Power
GND
220
HDMI1_CEC
Bidirectional
VCC_IO
222
HDMI1_TXD2+
Differential Pair
N/A
224
HDMI1_TXD2-
Differential Pair
N/A
226
GND
Power
GND
228
HDMI1_TXD1+
Differential Pair
N/A
230
HDMI1_TXD1-
Differential Pair
N/A
232
HDMI1_HPD
Input
VCC_HDMI
234
HDMI1_TXD0+
Differential Pair
N/A
236
HDMI1_TXD0-
Differential Pair
N/A
238
GND
Power
GND
240
HDMI1_TXC+
Differential Pair
N/A
242
HDMI1_TXC-
Differential Pair
N/A
244
Dual Channel LVDS
GND
Power
GND
246
LVDS1_A_CLK-
Differential Pair
N/A
248
LVDS1_A_CLK+
Differential Pair
N/A
250
GND
Power
GND
252
LVDS1_A_TX0-
Differential Pair
N/A
254
LVDS1_A_TX0+
Differential Pair
N/A
256
GND
Power
GND
258
LVDS1_A_TX1-
Differential Pair
N/A
260
LVDS1_A_TX1+
Differential Pair
N/A
262
USBO1_OC#
Input
VCC_IO
264
LVDS1_A_TX2-
Differential Pair
N/A
266
LVDS1_A_TX2+
Differential Pair
N/A
268
GND
Power
GND
270
LVDS1_A_TX3-
Differential Pair
N/A
272
LVDS1_A_TX3+
Differential Pair
N/A
274
USBO1_EN
Output
VCC_IO
276
LVDS1_B_CLK-
Differential Pair
N/A
278
LVDS1_B_CLK+
Differential Pair
N/A
280
GND
Power
GND
282
LVDS1_B_TX0-
Differential Pair
N/A
284
LVDS1_B_TX0+
Differential Pair
N/A
286
BKL1_ON
Output
VCC_IO
288
LVDS1_B_TX1-
Differential Pair
N/A
290
LVDS1_B_TX1+
Differential Pair
N/A
292
GND
Power
GND
294
LVDS1_B_TX2-
Differential Pair
N/A
296
LVDS1_B_TX2+
Differential Pair
N/A
298
GND
Power
VCC
300
LVDS1_B_TX3-
Differential Pair
N/A
302
LVDS1_B_TX3+
Differential Pair
N/A
304
Analogue Audio
AGND
Power
AGND
306
AAP1_MICIN
Analogue Input
N/A
308
AGND
Power
AGND
310
AAP1_LIN_L
Analogue Input
N/A
312
AAP1_LIN_R
Analogue Input
N/A
314
AVCC
Power
AVCC
316
AAP1_HP_L
Analogue Output
N/A
318
AAP1_HP_R
Analogue Output
N/A
320
AVCC
Power
AVCC
Appendix B – Module Bottom Side Signal Definition
Pin Number
Signal Group
Signal Name
Signal Class
Voltage Domain
1
GPIO
GPIO1
Bidirectional
VCC_IO
3
GPIO2
Bidirectional
VCC_IO
5
GPIO3
Bidirectional
VCC_IO
7
GPIO4
Bidirectional
VCC_IO
9
GND
Power
GND
11
GPIO5
Bidirectional
VCC_IO
13
GPIO6
Bidirectional
VCC_IO
15
GPIO7
Bidirectional
VCC_IO
17
GPIO8
Bidirectional
VCC_IO
23
SATA
GND
Power
GND
25
SATA1_RX+
Differential Pair
N/A
27
SATA1_RX-
Differential Pair
N/A
29
GND
Power
GND
31
SATA1_TX-
Differential Pair
N/A
33
SATA1_TX+
Differential Pair
N/A
35
SATA1_ACT#
Output
VCC_IO
37
PCI-Express
WAKE1_MICO
Input
VCC_IO
39
GND
Power
GND
41
PCIE1_RX-
Differential Pair
N/A
43
PCIE1_RX+
Differential Pair
N/A
45
GND
Power
GND
47
PCIE1_TX-
Differential Pair
N/A
49
PCIE1_TX+
Differential Pair
N/A
51
GND
Power
GND
53
PCIE1_CLK-
Differential Pair
N/A
55
PCIE1_CLK+
Differential Pair
N/A
57
Reserved for type specific features
GND
Power
GND
59
TS_DIFF1-
Undefined
Undefined
61
TS_DIFF1+
Undefined
Undefined
63
TS_1
Undefined
Undefined
65
TS_DIFF2-
Undefined
Undefined
67
TS_DIFF2+
Undefined
Undefined
69
GND
Power
GND
71
TS_DIFF3-
Undefined
Undefined
73
TS_DIFF3+
Undefined
Undefined
75
GND
Power
GND
77
TS_DIFF4-
Undefined
Undefined
79
TS_DIFF4+
Undefined
Undefined
81
GND
Power
GND
83
TS_DIFF5-
Undefined
Undefined
85
TS_DIFF5+
Undefined
Undefined
87
TS_2
Undefined
Undefined
89
TS_DIFF6-
Undefined
Undefined
91
TS_DIFF6+
Undefined
Undefined
93
GND
Power
GND
95
TS_DIFF7-
Undefined
Undefined
97
TS_DIFF7+
Undefined
Undefined
99
TS_3
Undefined
Undefined
101
TS_DIFF8-
Undefined
Undefined
103
TS_DIFF8+
Undefined
Undefined
105
GND
Power
GND
107
TS_DIFF9-
Undefined
Undefined
109
TS_DIFF9+
Undefined
Undefined
111
GND
Power
GND
113
TS_DIFF10-
Undefined
Undefined
115
TS_DIFF10+
Undefined
Undefined
117
GND
Power
GND
119
TS_DIFF11-
Undefined
Undefined
121
TS_DIFF11+
Undefined
Undefined
123
TS_4
Undefined
Undefined
125
TS_DIFF12-
Undefined
Undefined
127
TS_DIFF12+
Undefined
Undefined
129
GND
Power
GND
131
TS_DIFF13-
Undefined
Undefined
133
TS_DIFF13+
Undefined
Undefined
135
TS_5
Undefined
Undefined
137
TS_DIFF14-
Undefined
Undefined
139
TS_DIFF14+
Undefined
Undefined
141
GND
Power
GND
143
TS_DIFF15-
Undefined
Undefined
145
TS_DIFF15+
Undefined
Undefined
147
GND
Power
GND
149
TS_DIFF16-
Undefined
Undefined
151
TS_DIFF16+
Undefined
Undefined
153
GND
Power
GND
155
TS_DIFF17-
Undefined
Undefined
157
TS_DIFF17+
Undefined
Undefined
159
TS_6
Undefined
Undefined
161
TS_DIFF18-
Undefined
Undefined
163
TS_DIFF18+
Undefined
Undefined
165
GND
Power
GND
173
Parallel Camera
CAM1_D7
Input
VCC_IO
175
CAM1_D6
Input
VCC_IO
177
CAM1_D5
Input
VCC_IO
179
CAM1_D4
Input
VCC_IO
181
CAM1_D3
Input
VCC_IO
183
CAM1_D2
Input
VCC_IO
185
CAM1_D1
Input
VCC_IO
187
CAM1_D0
Input
VCC_IO
189
GND
Power
GND
191
CAM1_PCLK
Input
VCC_IO
193
CAM1_MCLK
Output
VCC_IO
195
CAM1_VSYNC
Input
VCC_IO
197
CAM1_HSYNC
Input
VCC_IO
199
I2C
GND
Power
GND
201
I2C3_SDA
Bidirectional
VCC_IO
203
I2C3_SCL
Output
VCC_IO
205
I2C2_SDA
Bidirectional
VCC_IO
207
I2C2_SCL
Output
VCC_IO
209
I2C1_SDA
Bidirectional
VCC_IO
211
I2C1_SCL
Output
VCC_IO
213
SPDIF
GND
Power
GND
215
SPDIF1_OUT
Output
VCC_IO
217
SPDIF1_IN
Input
VCC_IO
219
SPI
GND
Power
GND
221
SPI1_CLK
Output
VCC_IO
223
SPI1_MISO
Input
VCC_IO
225
SPI1_MOSI
Output
VCC_IO
227
SPI1_CS
Output
VCC_IO
229
SPI2_MISO
Input
VCC_IO
231
SPI2_MOSI
Output
VCC_IO
233
SPI2_CS
Output
VCC_IO
235
SPI2_CLK
Output
VCC_IO
237
Digital RGB
GND
Power
GND
239
BKL1_PWM
Output
VCC_IO
241
GND
Power
GND
243
LCD1_PCLK
Output
VCC_IO
245
LCD1_VSYNC
Output
VCC_IO
247
LCD1_HSYNC
Output
VCC_IO
249
LCD1_DE
Output
VCC_IO
251
LCD1_R0
Output
VCC_IO
253
LCD1_R1
Output
VCC_IO
255
LCD1_R2
Output
VCC_IO
257
LCD1_R3
Output
VCC_IO
259
LCD1_R4
Output
VCC_IO
261
LCD1_R5
Output
VCC_IO
263
LCD1_R6
Output
VCC_IO
265
LCD1_R7
Output
VCC_IO
267
GND
Power
GND
269
LCD1_G0
Output
VCC_IO
271
LCD1_G1
Output
VCC_IO
273
LCD1_G2
Output
VCC_IO
275
LCD1_G3
Output
VCC_IO
277
LCD1_G4
Output
VCC_IO
279
LCD1_G5
Output
VCC_IO
281
LCD1_G6
Output
VCC_IO
283
LCD1_G7
Output
VCC_IO
285
GND
Power
GND
287
LCD1_B0
Output
VCC_IO
289
LCD1_B1
Output
VCC_IO
291
LCD1_B2
Output
VCC_IO
293
LCD1_B3
Output
VCC_IO
295
LCD1_B4
Output
VCC_IO
297
LCD1_B5
Output
VCC_IO
299
LCD1_B6
Output
VCC_IO
301
LCD1_B7
Output
VCC_IO
303
Analogue and Touch
AGND
Power
AGND
305
AN1_ADC0
Analogue Input
AVCC_IO
307
AN1_ADC1
Analogue Input
AVCC_IO
309
AN1_ADC2
Analogue Input
AVCC_IO
311
AN1_TSWIP_ADC3
Analogue Input
AVCC_IO
313
AGND
Power
AGND
315
AN1_TSPX
Analogue Input
N/A
317
AN1_TSMX
Analogue Input
N/A
319
AN1_TSPY
Analogue Input
N/A
321
AN1_TSMY
Analogue Input
N/A
Appendix C – Physical Pin Definition and Location
Signal Group
Module Bottom Side
MXM3 Pins
Module Top Side
Signal Group
GPIO
GPIO1
1
2
PWM1
PWM
GPIO2
3
4
PWM2
GPIO3
5
6
PWM3
GPIO4
7
8
PWM4
GND
9
10
VCC
CAN
GPIO5
11
12
CAN1_RX
GPIO6
13
14
CAN1_TX
GPIO7
15
16
CAN2_RX
GPIO8
17
18
CAN2_TX
SATA
GND
23
24
POWER_ENABLE_MOCI
System Control
SATA1_RX+
25
26
RESET_MOCI#
SATA1_RX-
27
28
RESET_MICO#
GND
29
30
VCC
Gigabit Ethernet
SATA1_TX-
31
32
ETH1_MDI2+
SATA1_TX+
33
34
ETH1_MDI2-
SATA1_ACT#
35
36
VCC
WAKE1_MICO
37
38
ETH1_MDI3+
PCI-Express
GND
39
40
ETH1_MDI3-
PCIE1_RX-
41
42
ETH1_ACT
PCIE1_RX+
43
44
ETH1_LINK
GND
45
46
ETH1_CTREF
PCIE1_TX-
47
48
ETH1_MDI0-
PCIE1_TX+
49
50
ETH1_MDI0+
GND
51
52
VCC
PCIE1_CLK-
53
54
ETH1_MDI1-
PCIE1_CLK+
55
56
ETH1_MDI1+
GND
57
58
VCC
USB
TS_DIFF1-
59
60
USBO1_VBUS
TS_DIFF1+
61
62
USBO1_SSRX+
TS_1
63
64
USBO1_SSRX-
TS_DIFF2-
65
66
VCC
TS_DIFF2+
67
68
USBO1_SSTX+
GND
69
70
USBO1_SSTX-
TS_DIFF3-
71
72
USBO1_ID
TS_DIFF3+
73
74
USBO1_D+
GND
75
76
USBO1_D-
TS_DIFF4-
77
78
VCC
TS_DIFF4+
79
80
USBH2_D+
GND
81
82
USBH2_D-
TS_DIFF5-
83
84
USBH_EN
TS_DIFF5+
85
86
USBH3_D+
TS_2
87
88
USBH3_D-
TS_DIFF6-
89
90
VCC
TS_DIFF6+
91
92
USBH4_SSRX-
GND
93
94
USBH4_SSRX+
TS_DIFF7-
95
96
USBH_OC#
TS_DIFF7+
97
98
USBH4_D+
TS_3
99
100
USBH4_D-
TS_DIFF8-
101
102
VCC
TS_DIFF8+
103
104
USBH4_SSTX-
GND
105
106
USBH4_SSTX+
TS_DIFF9-
107
108
VCC
UART
TS_DIFF9+
109
110
UART1_DTR
GND
111
112
UART1_TXD
TS_DIFF10-
113
114
UART1_RTS
TS_DIFF10+
115
116
UART1_CTS
GND
117
118
UART1_RXD
TS_DIFF11-
119
120
UART1_DSR
TS_DIFF11+
121
122
UART1_RI
TS_4
123
124
UART1_DCD
TS_DIFF12-
125
126
UART2_TXD
TS_DIFF12+
127
128
UART2_RTS
GND
129
130
UART2_CTS
TS_DIFF13-
131
132
UART2_RXD
TS_DIFF13+
133
134
UART3_TXD
TS_5
135
136
UART3_RXD
TS_DIFF14-
137
138
UART4_TXD
TS_DIFF14+
139
140
UART4_RXD
GND
141
142
GND
MMC
TS_DIFF15-
143
144
MMC1_D2
TS_DIFF15+
145
146
MMC1_D3
GND
147
148
MMC1_D4
TS_DIFF16-
149
150
MMC1_CMD
TS_DIFF16+
151
152
MMC1_D5
GND
153
154
MMC1_CLK
TS_DIFF17-
155
156
MMC1_D6
TS_DIFF17+
157
158
MMC1_D7
TS_6
159
160
MMC1_D0
TS_DIFF18-
161
162
MMC1_D1
TS_DIFF18+
163
164
MMC1_CD#
GND
165
Parallel Camera
CAM1_D7
173
174
VCC_BACKUP
SDIO
CAM1_D6
175
176
SD1_D2
CAM1_D5
177
178
SD1_D3
CAM1_D4
179
180
SD1_CMD
CAM1_D3
181
182
GND
CAM1_D2
183
184
SD1_CLK
CAM1_D1
185
186
SD1_D0
CAM1_D0
187
188
SD1_D1
GND
189
190
SD1_CD#
CAM1_PCLK
191
192
GND
Digital Audio
CAM1_MCLK
193
194
DAP1_MCLK
CAM1_VSYNC
195
196
DAP1_D_OUT
CAM1_HSYNC
197
198
DAP1_RESET#
I2C
GND
199
200
DAP1_BIT_CLK
I2C3_SDA
201
202
DAP1_D_IN
I2C3_SCL
203
204
DAP1_SYNC
I2C2_SDA
205
206
GND
VGA
I2C2_SCL
207
208
VGA1_R
I2C1_SDA
209
210
VGA1_G
I2C1_SCL
211
212
VGA1_B
SPDIF
GND
213
214
VGA1_HSYNC
SPDIF1_OUT
215
216
VGA1_VSYNC
SPDIF1_IN
217
218
GND
HDMI
SPI
GND
219
220
HDMI1_CEC
SPI1_CLK
221
222
HDMI1_TXD2+
SPI1_MISO
223
224
HDMI1_TXD2-
SPI1_MOSI
225
226
GND
SPI1_CS
227
228
HDMI1_TXD1+
SPI2_MISO
229
230
HDMI1_TXD1-
SPI2_MOSI
231
232
HDMI1_HPD
SPI2_CS
233
234
HDMI1_TXD0+
SPI2_CLK
235
236
HDMI1_TXD0-
Digital RGB
GND
237
238
GND
BKL1_PWM
239
240
HDMI1_TXC+
GND
241
242
HDMI1_TXC-
LCD1_PCLK
243
244
GND
Dual Channel LVDS
LCD1_VSYNC
245
246
LVDS1_A_CLK-
LCD1_HSYNC
247
248
LVDS1_A_CLK+
LCD1_DE
249
250
GND
LCD1_R0
251
252
LVDS1_A_TX0-
LCD1_R1
253
254
LVDS1_A_TX0+
LCD1_R2
255
256
GND
LCD1_R3
257
258
LVDS1_A_TX1-
LCD1_R4
259
260
LVDS1_A_TX1+
LCD1_R5
261
262
USBO1_OC#
LCD1_R6
263
264
LVDS1_A_TX2-
LCD1_R7
265
266
LVDS1_A_TX2+
GND
267
268
GND
LCD1_G0
269
270
LVDS1_A_TX3-
LCD1_G1
271
272
LVDS1_A_TX3+
LCD1_G2
273
274
USBO1_EN
LCD1_G3
275
276
LVDS1_B_CLK-
LCD1_G4
277
278
LVDS1_B_CLK+
LCD1_G5
279
280
GND
LCD1_G6
281
282
LVDS1_B_TX0-
LCD1_G7
283
284
LVDS1_B_TX0+
GND
285
286
BKL1_ON
LCD1_B0
287
288
LVDS1_B_TX1-
LCD1_B1
289
290
LVDS1_B_TX1+
LCD1_B2
291
292
GND
LCD1_B3
293
294
LVDS1_B_TX2-
LCD1_B4
295
296
LVDS1_B_TX2+
LCD1_B5
297
298
GND
LCD1_B6
299
300
LVDS1_B_TX3-
LCD1_B7
301
302
LVDS1_B_TX3+
Analogue and Touch
AGND
303
304
AGND
Analogue Audio
AN1_ADC0
305
306
AAP1_MICIN
AN1_ADC1
307
308
AGND
AN1_ADC2
309
310
AAP1_LIN_L
AN1_TSWIP_ADC3
311
312
AAP1_LIN_R
AGND
313
314
AVCC
AN1_TSPX
315
316
AAP1_HP_L
AN1_TSMX
317
318
AAP1_HP_R
AN1_TSPY
319
320
AVCC
AN1_TSMY
321
Disclaimer:
Copyright © Toradex AG. All rights reserved. All data is for information purposes only and not guaranteed for legal purposes. Information has been carefully checked and is believed to be accurate; however, no responsibility is assumed for inaccuracies. Brand and product names are trademarks or registered trademarks of their respective owners. Specifications are subject to change without notice.
