.NET Compact Framework Flash Installer
The .NET Compact Framework Flash Installer is a .cab file which installs the .NET Compact Framework to the Colibri's Flash Disk of the Colibri module.
Versions
At the moment, installer for the following versions are available:
For the .NET compact Framework 3.5 there are additional string resources available, mainly to convert error numbers to readable string messages:
