3D CAD models
Apalis Modules
General Apalis 3D Mechanical Models:
The basic Apalis 3D model contains the PCB and the maximum component height on top and bottom of the module.
This is a SolidWorks CAD model. You can download the free eDrawings model viewer from SolidWorks here.
This is a generic STEP model that can be opened and modified in any 3D CAD.
This is a generic 3D pdf model that can be opened in Adobe Reader.
Apalis T30 3D Mechanical Models:
The Apalis T30 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the generic Apalis mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Apalis iMX6 3D Mechanical Models:
The Apalis iMX6 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the generic Apalis mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Apalis TK1 3D Mechanical Models:
The Apalis TK1 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the generic Apalis mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Apalis Heatsink
Apalis Heatsink Mechanical Models:
It is a generic STEP model that can be opened and modified in any 3D CAD. It includes Type 1, 2 and 3.
Apalis Carrier Boards
Ixora Carrier Board Mechanical Models:
A basic 3D model for the Ixora carrier board can be downloaded here:
It is a generic 3D pdf model that can be opened in Adobe Reader.
Colibri Modules
General Colibri 3D Mechanical Models:
The basic Colibri 3D model contains the PCB and the maximum component height on top and bottom of the module.
Colibri iMX6 3D Mechanical Models:
The Colibri iMX6 3D model contains the PCB and all components. Depending on the module variant, some components may be not assembled. The component heights are typical values. Due to production tolerances, the actual height of the assembled components can be different. Please use the generic Colibri mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
This is a generic STEP models that can be opened and modified in any 3D CAD.
Colibri VFxx 3D Mechanical Models:
The Colibri VFxx 3D model contains the PCB and all components. Depending on the module variant, some components may be not assembled. The component heights are typical values. Due to production tolerances, the actual height of the assembled components can be different. Please use the generic Colibri mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
These are a generic STEP models that can be opened and modified in any 3D CAD. The second model does not contain any copper pads and therefore less complex.
Colibri Carrier Boards
Colibri Evaluation Board Mechanical Models:
A basic 3D model for the Colibri Evaluation Board can be downloaded here:
  • Colibri Evaluation Board 3D EASM model (Coming Soon)
Iris Carrier Board Mechanical Models:
A basic 3D model for the Iris carrier board can be downloaded here:
