ADC (Linux)
Depending on the module type the analogue inputs are connected via different ADCs (see ADC) therefore ADC read-out is supported by various drivers. Most drivers provide file access through sysfs. Access through sysfs is easy to implement since it only involves reading a regular file. Keep in mind that opening and closing a file for every ADC read-out is relatively slow and rather resource intensive. However the internal ADCs are anyway not meant to be used for high speed applications.
Colibri T20
On the Colibri T20 the WM9715 supports ADC read-out through the battery driver. Currently only AD0 and AD1 are supported.
root@colibri_t20:~# cat /sys/class/power_supply/colibri_t20-analog_inputs/voltage_now
4095
root@colibri_t20:~# cat /sys/class/power_supply/colibri_t20-analog_inputs/temp
1044
Apalis iMX6/Apalis T30/Colibri iMX6/Colibri T30
The STMPE-ADC driver makes use of the Industrial Input/Output (IIO) framework. The driver will be included in BSP V2.1 beta 2.
The STMPE811 supports up to 8 analogue inputs, however, input 1-4 are used for the resistive touchscreen interface. The inputs are 0 indexed, so the usable inputs are 4-7.
SODIMM/MXM3 STMPE811 Input IIO device IIO channel
AD0 IN0 iio:device0 in_voltage4_raw
AD1 IN1 iio:device0 in_voltage5_raw
AD2 IN2 iio:device0 in_voltage6_raw
AD3 IN3 iio:device0 in_voltage7_raw
Note that the STMPE811 pin name IN0 goes to the ADC channel 4.
The IIO framework exposes those inputs through the sysfs interface:
# cd /sys/bus/iio/devices/device0/
# ls in*
in4_raw   in5_raw   in6_raw   in7_raw   in_scale
# cat /sys/bus/iio/devices/device0/in4_raw
755
Note: On newer kernels the IIO framework changed its file naming scheme slightly:
root@colibri-imx6:~# cd /sys/bus/iio/devices/iio\:device0/
root@colibri-imx6:/sys/bus/iio/devices/iio:device0# ls in*
in_temp8_raw      in_voltage4_raw   in_voltage5_raw   in_voltage6_raw   in_voltage7_raw   in_voltage_scale
root@colibri-imx6:/sys/bus/iio/devices/iio:device0# cat /sys/bus/iio/devices/iio\:device0/in_voltage4_raw
1089
Note: Since the ADC is shared with the touchscreen its not recommended to change the ADC characteristics such as sample time.
More information about the IIO framework:
  • https://wiki.analog.com/software/linux/docs/iio/iio
Colibri VFxx
On the Colibri VFxx modules the AD functionality is making use of the two integrated 12-Bit ADC peripherals of the Vybrid SoC.
SODIMM Vybrid ADC IIO device IIO channel
AD0 ADC0, Channel 8 iio:device0 in_voltage8_raw
AD1 ADC1, Channel 8 iio:device1 in_voltage8_raw
AD2 ADC0, Channel 9 iio:device0 in_voltage9_raw
AD3 ADC1, Channel 9 iio:device1 in_voltage9_raw
These four analogue inputs are compatible within the Colibri family and are dedicated ADC inputs. Additional some of the GPIO capable pins on the SODIMM connector feature with alternative function ADC capability. The ADC function of these pins are not compatible with other Colibri modules. It should be noted, that the noise level on these pins might be higher than on the dedicated ADC input signals, as these are routed as digital signals on the module.
For BSP versions 2.3 Beta3 and earlier, the driver is called mvf-adc and supports access through a character device only. We created a test program to show how the driver can be used, see adc-test.c.
Starting with BSP versions 2.3 Beta5, the vf610_adc driver makes use of the Industrial Input/Output (IIO) framework. The IIO framework exposes the ADC channels through the sysfs interface. The inputs are indexed through 0 to 15 with the channels 8 and 9 for ADC0 and ADC1 being usable by default. The ADC peripherals also include an internal temperature sensor. The readout of them is given by in_temp_input in degree celsius times 1000.
root@colibri-vf:~# cd /sys/bus/iio/devices/iio\:device0
root@colibri-vf:/sys/bus/iio/devices/iio:device0# ls
dev                            in_voltage5_raw
in_temp_input                  in_voltage6_raw
in_voltage0_raw                in_voltage7_raw
in_voltage10_raw               in_voltage8_raw
in_voltage11_raw               in_voltage9_raw
in_voltage12_raw               in_voltage_sampling_frequency
in_voltage13_raw               in_voltage_scale
in_voltage14_raw               name
in_voltage15_raw               power
in_voltage1_raw                sampling_frequency_available
in_voltage2_raw                subsystem
in_voltage3_raw                uevent
in_voltage4_raw
root@colibri-vf:/sys/bus/iio/devices/iio:device0# cat in_temp_input
41304
root@colibri-vf:/sys/bus/iio/devices/iio:device0# cat in_voltage8_raw
1377
root@colibri-vf:~# cd /sys/bus/iio/devices/iio\:device1
root@colibri-vf:/sys/bus/iio/devices/iio:device1# cat in_temp_input
40760
root@colibri-vf:/sys/bus/iio/devices/iio:device1# cat in_voltage9_raw
4035
Continuous Sampling
Vybrid provides support for continuous sampling with its ADC peripheral. Currently only software triggers are supported, they are accessible through sysfs. The necessary driver support is available with version 2.6 Beta1 and above. The 2.6 Beta1 release image is missing the sysfs trigger configuration option (CONFIG_IIO_SYSFS_TRIGGER) and hence requires a custom kernel build.
root@colibri-vf:/sys/bus/iio/devices# ls
iio:device0        iio:device1        iio_sysfs_trigger
root@colibri-vf:/sys/bus/iio/devices# cd iio:device0
buffer                         in_voltage13_raw               in_voltage6_raw                power
dev                            in_voltage14_raw               in_voltage7_raw                sampling_frequency_available
in_conversion_mode             in_voltage15_raw               in_voltage8_raw                scan_elements
in_temp_input                  in_voltage1_raw                in_voltage9_raw                subsystem
in_voltage0_raw                in_voltage2_raw                in_voltage_sampling_frequency  trigger
in_voltage10_raw               in_voltage3_raw                in_voltage_scale               uevent
in_voltage11_raw               in_voltage4_raw                name
in_voltage12_raw               in_voltage5_raw                of_node
The generic buffer code present in Linux kernel source tree can be used to test the continuous sampling functionality.
root@colibri-vf:~# echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_temp_en
root@colibri-vf:~# echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_timestamp_en
root@colibri-vf:~# echo 0 > /sys/bus/iio/devices/iio_sysfs_trigger/add_trigger
root@colibri-vf:~# ./generic_buffer -n 4003b000.adc -t sysfstrig0 -l 512 -c 1
iio device number being used is 0
iio trigger number being used is 0
/sys/bus/iio/devices/iio:device0 sysfstrig0
835.000000 1463058211407519734
835.000000 1463058211407532489
834.000000 1463058211407542708
835.000000 1463058211407556933
835.000000 1463058211407572004
835.000000 1463058211407587044
836.000000 1463058211407601449
835.000000 1463058211407615464
835.000000 1463058211407629923
835.000000 1463058211407644663
835.000000 1463058211407659362
835.000000 1463058211407674031
836.000000 1463058211407688639
835.000000 1463058211407703164
835.000000 1463058211407717683
834.000000 1463058211407731968
root@colibri-vf:~# echo 0 > /sys/bus/iio/devices/iio:device0/scan_elements/in_timestamp_en
root@colibri-vf:~# echo 0 > /sys/bus/iio/devices/iio:device0/scan_elements/in_temp_en
root@colibri-vf:~# echo 0 > /sys/bus/iio/devices/iio_sysfs_trigger/remove_trigger
Colibri iMX7
On the Colibri iMX7 modules the AD functionality is making use of the integrated 12-Bit ADC peripheral of the i.MX 7 SoC.
SODIMM i.MX 7 ADC IIO device IIO channel
AD0 ADC1_IN0 iio:device0 in_voltage0_raw
AD1 ADC1_IN1 iio:device0 in_voltage1_raw
AD2 ADC1_IN2 iio:device0 in_voltage2_raw
AD3 ADC1_IN3 iio:device0 in_voltage3_raw
Note: The ADC channels are only 1.8V capable! This is a limitation of the i.MX 7 SoC.
The Linux IIO driver for the i.MX 7 ADC is called AD2802A and by default enabled. The IIO framework exposes the ADC channels through the sysfs interface.
root@colibri-imx7:~# cd /sys/bus/iio/devices/iio\:device0/
root@colibriimx7:/sys/bus/iio/devices/iio:device0# ls
dev               in_voltage12_raw  in_voltage1_raw  in_voltage5_raw  in_voltage9_raw                of_node
in_voltage0_raw   in_voltage13_raw  in_voltage2_raw  in_voltage6_raw  in_voltage_sampling_frequency  power
in_voltage10_raw  in_voltage14_raw  in_voltage3_raw  in_voltage7_raw  in_voltage_scale               subsystem
in_voltage11_raw  in_voltage15_raw  in_voltage4_raw  in_voltage8_raw  name                           uevent
root@colibriimx7:/sys/bus/iio/devices/iio:device0# cat in_voltage[0-3]_raw
1860
3057
3050
3735
