ADC Lib API
Library to support ADC interfacing. More...
Macros
#define CODEC_UNKNOWN  0 #define CODEC_UCB1400  1 #define CODEC_WM9713  2 #define CODEC_WM9715  3 #define CODEC_SGTL5000  4 #define ADC_VER_MAJ  2 Version Info. More...
#define ADC_VER_MIN  3 #define ADC_VER_BUILD  0
Functions
BOOL  Ac97Init (void)
BOOL  Ac97DeInit (void)
void  ADCGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
DWORD  getCodecType (void)
BOOL  ReadADCChannel (BYTE channel, DWORD *value, DWORD samples)
DWORD  MicrovoltsPerLsb (BYTE channel)
DWORD  ReadTouch (BYTE mode, DWORD filter)
BOOL  Ac97Write (UINT16 offset, UINT16 data)
BOOL  Ac97Read (UINT16 offset, UINT16 *pdata)
Detailed Description
Author
samuel.bissig
Rev
2688
Date
2015-03-09 13:36:34 +0100 (Mo, 09 Mrz 2015)
Target Platforms:
PXAxxx, T20
Version Info.
Function Documentation
BOOL Ac97DeInit ( void  )
Deinitializes the AC97 interface.
Return values
TRUE Success.
FALSE Error.
BOOL Ac97Init ( void  )
Initializes the AC97 interface.
Return values
TRUE Success.
FALSE Error.
BOOL Ac97Read ( UINT16  offset,
UINT16 *  pdata
Directly reads an AC97 register.
Parameters
[in] offset Register address.
[out] pdata 16-bit value read from the register.
Return values
TRUE Success.
FALSE Error.
BOOL Ac97Write ( UINT16  offset,
UINT16  data
Directly writes to an AC97 register
Parameters
[in] data 16-bit value to write into the register.
Return values
TRUE Success.
FALSE Error.
void ADCGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Reads the library Version.
Parameters
[out] pVerMaj Major version number.
[out] pVerMin Minor version number.
[out] pBuild Build number.
DWORD getCodecType ( void  )
Reads which codec is installed on the current Colibri module.
Return values
0 Codec unknown.
1 UCB1400.
2 WM9713.
3 WM9715.
4 SGTL5000
DWORD MicrovoltsPerLsb ( BYTE  channel )
Gets Converstion constant Microvolts per LSB. This can be different for each ADC and even for each channel.
Parameters
[in] channel ADC channel number (0..3)
Return values
(7500000/1024) Conversion constant Microvolts per ADC LSB.
(3300000*3/4096) Conversion constant Microvolts per ADC LSB.
(3300000 /4096) Conversion constant Microvolts per ADC LSB.
0 Error.
BOOL ReadADCChannel ( BYTE  channel,
DWORD *  value,
DWORD  samples
Reads one ADC channel from Colibri's audio codec.
Parameters
[in] samples number of samples that should be taken, they will be summed up
[out] value raw ADC value, if sampels>1, value is the SUM of all measurements.
Return values
TRUE Success.
FALSE Error.
DWORD ReadTouch ( BYTE  mode,
DWORD  filter
Reads one value from the touch controller
Parameters
[in] mode X or Y axis measurement.
[in] samples Number of samples required.
Return values
value Position value.
FALSE No access.
-1 Error.
Remarks: Only the UCB1400 codec is currently supported.
