AGT Touch Diplays 4", 7" and 10" (Linux)
This article describes how to add Linux Kernel support for AGT Touch Diplays 4", 7" and 10" .
Hardware
AGT Diplays use the Unified Display Interface. Check the Installing AGT Touch Display article for information on the display connection.
Kernel Patch
To make the AGT display work on Linux, it will be necessary to add the display struct into the Kernel code or the device-tree.
Colibri Vybrid
Apply the changes according to the patch below:
diff --git a/drivers/gpu/drm/panel/panel-simple.c b/drivers/gpu/drm/panel/panel-simple.c
index 0f0981f..b2a9a8b 100644
--- a/drivers/gpu/drm/panel/panel-simple.c
+++ b/drivers/gpu/drm/panel/panel-simple.c
@@ -662,6 +662,79 @@ static const struct panel_desc edt_etm0700g0dh6 = {
+static const struct drm_display_mode edt_agt0470_mode = {
+   .clock = 9000,
+   .hdisplay = 480,
+   .hsync_start = 480 + 30,
+   .hsync_end = 480 + 30 + 1,
+   .htotal = 480 + 30 + 1 + 5,
+   .vdisplay = 272,
+   .vsync_start = 272 + 8,
+   .vsync_end = 272 + 8 + 1,
+   .vtotal = 272 + 8 + 1 + 7,
+   .vrefresh = 60,
+   .flags = DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC,
+static const struct panel_desc edt_agt0470 = {
+   .modes = &edt_agt0470_mode,
+   .num_modes = 1,
+   .bpc = 6,
+   .size = {
+       .width = 152,
+       .height = 91,
+       .bus_format = MEDIA_BUS_FMT_RGB666_1X18,
+       .bus_flags = DRM_BUS_FLAG_PIXDATA_POSEDGE,
+static const struct drm_display_mode edt_agt0700_mode = {
+   .clock = 33300,
+   .hdisplay = 800,
+   .hsync_start = 800 + 210,
+   .hsync_end = 800 + 210 + 20,
+   .htotal = 800 + 210 + 20 + 26,
+   .vdisplay = 480,
+   .vsync_start = 480 + 22,
+   .vsync_end = 480 + 22 + 10,
+   .vtotal = 480 + 22 + 10 + 13,
+   .vrefresh = 60,
+static const struct panel_desc edt_agt0700 = {
+   .modes = &edt_agt0700_mode,
+   .num_modes = 1,
+   .bpc = 6,
+   .size = {
+       .width = 152,
+       .height = 91,
+static const struct drm_display_mode edt_agt1000_mode = {
+        .clock = 51200,
+        .hdisplay = 1024,
+        .hsync_start = 1024 + 160,
+        .hsync_end = 1024 + 160 + 70,
+        .htotal = 1024 + 160 + 70 + 90,
+        .vdisplay = 600,
+        .vsync_start = 600 + 12,
+        .vsync_end = 600 + 12 + 10,
+        .vtotal = 600 + 12 + 10 + 13,
+        .vrefresh = 60,
+static const struct panel_desc edt_agt1000 = {
+        .modes = &edt_agt1000_mode,
+        .num_modes = 1,
+        .bpc = 6,
+        .size = {
+                .width = 152,
+                .height = 91,
 static const struct drm_display_mode foxlink_fl500wvr00_a0t_mode = {
    .clock = 32260,
    .hdisplay = 800,
@@ -1186,6 +1259,15 @@ static const struct of_device_id platform_of_match[] = {
        .compatible = "edt,etm0700g0dh6",
        .data = &edt_etm0700g0dh6,
+       .compatible = "edt,agt0470",
+       .data = &edt_agt0470,
+       .compatible = "edt,agt0700",
+       .data = &edt_agt0700,
+      .compatible = "edt,agt1000",
+     .data = &edt_agt1000,
        .compatible = "foxlink,fl500wvr00-a0t",
        .data = &foxlink_fl500wvr00_a0t,
2.7.4
Re-compile the kernel and device-tree and replace the binary.
After that, set the u-boot environment as following:
For the 4" display:
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /panel compatible "edt,agt0470"'
For the 7" display:
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /panel compatible "edt,agt0700"'
For the 10" display:
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /panel compatible "edt,agt1000"'
Apalis and Colibri iMX6
diff --git a/drivers/video/fbdev/mxc/mxc_lcdif.c b/drivers/video/fbdev/mxc/mxc_lcdif.c
index 1636bae..6ba86f0 100644
--- a/drivers/video/fbdev/mxc/mxc_lcdif.c
+++ b/drivers/video/fbdev/mxc/mxc_lcdif.c
@@ -49,6 +49,30 @@ static struct fb_videomode lcdif_modedb[] = {
     .vmode = FB_VMODE_NONINTERLACED,
     .flag = 0,},
+   /* 1024x600 @ 60 Hz , pixel clk @ 51.2 MHz */ /* 19531 ps*/
+   "AGT10", 60, 1024, 600, 19531,
+    .left_margin = 90,
+    .right_margin = 160,
+    .hsync_len = 70,
+    .upper_margin = 13,
+    .lower_margin = 2,
+    .vsync_len = 10,
+    .sync = FB_SYNC_CLK_LAT_FALL,
+    .vmode = FB_VMODE_NONINTERLACED,
+    .flag = 0,},
+   /* 800x480 @ 60 Hz , pixel clk @ 33.3 MHz */ /* 30030 ps*/
+   "AGT07", 60, 800, 480, 30030,
+    .left_margin = 26,
+    .right_margin = 210,
+    .hsync_len = 20,
+    .lower_margin = 22,
+    .vsync_len = 10,
+    .flag = 0,},
+   /* 320x240 @ 60 Hz , pixel clk @ 9 MHz */ /* 111000 ps*/
+   "AGT04", 60, 480, 272, 111000,
+    .left_margin = 5,
+    .right_margin = 39,
+    .hsync_len = 1,
+    .upper_margin = 8,
+    .lower_margin = 7,
+    .vsync_len = 1,
+    .flag = 0,},
    /* 800x480 @ 60 Hz , pixel clk @ 33.26MHz */
    "FusionF07A", 60, 800, 480, 30066,
     .left_margin = 88,
2.9.3
Re-compile the kernel and replace the binary correctly.
After that, set the u-boot environment vidargs as following:
For the 4" display:
setenv vidargs 'video=mxcfb0:dev=lcd,AGT04,if=RGB666,  video=mxcfb1:off fbmem=8M'
For the 7" display:
setenv vidargs 'video=mxcfb0:dev=lcd,AGT07,if=RGB666,  video=mxcfb1:off fbmem=8M'
setenv vidargs 'video=mxcfb0:dev=lcd,AGT10,if=RGB666,  video=mxcfb1:off fbmem=8M'
Colibri iMX7
Set the u-boot environment vidargs as following:
For the 4" display:
setenv vidargs 'video=mxsfb:480x272M-16@60,pixclockpol=1'
For the 7" display:
setenv vidargs 'video=mxsfb:800x480M-16@60,pixclockpol=1'
setenv vidargs 'video=mxsfb:1024x600M-16@60,pixclockpol=1'
Modules tested
Colibri VF61 (V1.2A)
Colibri VF50 (V1.2A)
Colibri IMX6DL (V1.0A)
Colibri IMX7S (V1.1B)
