Apalis TK1 Mainline Kernel with Nouveau Driver and Arch Linux Distro
This document describes how to build the mainline Linux kernel and Nouveau driver from scratch for Apalis TK1.
Fedora 23/24:
sudo dnf install python glib2-devel autoconf automake libtool libffi-devel expat-devel libxml2-devel uboot-tools libtalloc-devel xorg-x11-util-macros
mkdir ~/bin
export PATH=~/bin:$PATH
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
git clone https://github.com/proot-me/PRoot.git
cd PRoot/src
make
cp proot ~/bin/
Ubuntu 14.04:
sudo apt-get install git build-essential wget proot phablet-tools autoconf automake libtool libc6-i386 lib32stdc++6 lib32z1 pkg-config libwayland-dev
sudo apt-get install bison flex bc u-boot-tools glib-2.0 libffi-dev xutils-dev python-mako intltool libxml2-dev
Scripts use sudo, your user needs to be a sudoer.
Syncing
All the required projects are synced using Google's repo tool:
mkdir tegra-nouveau-rootfs
cd tegra-nouveau-rootfs
repo init -u https://github.com/NVIDIA/tegra-nouveau-rootfs.git -m tegra-nouveau.xml
Sync all the sources:
repo sync -j4 -c
Once all the sources are downloaded, set the TOP environment variable:
export TOP=$PWD
Then download the cross-compilation toolchain that we will use:
./scripts/download-gcc
Rootfs
By default the scripts included in the NVIDIA repo generate an Arch rootfs. You can prepare an Arch based rootfs by using a simple set of commands:
./scripts/download-rootfs
./scripts/prepare-rootfs
In case you'd like to use the kernel and kernel modules with a different rootfs you can skip downloading and unpacking Arch and just create appropriate folders needed by the kernel scripts:
mkdir -p $TOP/out/target/arm/ArchLinuxArm/boot/
mkdir -p $TOP/out/target/arm/ArchLinuxArm/lib/modules
Kernel Compilation
The GPU device node is disabled by default:
vi $TOP/linux/arch/arm/boot/dts/tegra124-apalis.dtsi
Find and edit:
     gpu@0,57000000 {
          * Node left disabled on purpose - the bootloader will enable
          * it after having set the VPR up
         vdd-supply = <&vdd_gpu>;
+         status = "okay";
Modify the build script to build an uImage instead of a zImage:
vi $TOP/scripts/build-linux
Change:
 case $ARCH in
     arm)
         KCONFIG="tegra_defconfig"
-         KIMAGE=zImage
+         KIMAGE=uImage
         KARCH=arm
     aarch64)
And:
 # Build all that we need
- run_make_kernel -j$NPROC oldconfig dtbs $KIMAGE modules
+ run_make_kernel -j$NPROC oldconfig dtbs $KIMAGE modules LOADADDR=0x80008000
Arch requires extra options to work properly:
CONFIG_SECCOMP=y
It can be simply appended to the defconfig file:
echo CONFIG_SECCOMP=y >> $TOP/linux/arch/arm/configs/tegra_defconfig
To make gigabit Ethernet work apply the following patch:
curl https://docs.toradex.com/103530-apalis-t30-tk1-mainline-gigabit-ethernet.patch > linux/ethernet.patch
patch -d linux -p1 < linux/ethernet.patch
If you need any special kernel configuration now it's time to edit defconfig:
vi $TOP/linux/arch/arm/configs/tegra_defconfig
Now you can build the Kernel:
./scripts/build-linux
And the Nouveau driver:
./scripts/build-nouveau
Afterwards you should have a kernel and several kernel modules (including the Nouveau driver) ready and included in your rootfs.
Extra Packages
To use the GPU in applications you'll need to rebuild libdrm with some extra options. These scripts will do it for you:
./scripts/build-pthread-stubs
./scripts/build-drm
Installing Generated Arch Image on Apalis TK1
UMS Mode
While on the U-Boot prompt enter:
ums 0 mmc 0
Connect the board to the PC, two partitions should show up (boot & rootfs). Mount both of them.
Erase all files on mounted partitions. Then copy rootfs files to rootfs partition:
sudo rsync -aAXv $TOP/out/target/arm/ArchLinuxArm/* /path/to/rootfs/mountpoint/
As well as kernel and device tree to boot partition:
sudo cp $TOP/out/target/arm/ArchLinuxArm/boot/uImage-nouveau-arm /path/to/boot/mountpoint/uImage
sudo cp $TOP/out/target/arm/ArchLinuxArm/boot/dtb-nouveau/tegra124-apalis-eval.dtb /path/to/boot/mountpoint/
U-Boot Configuration
You need to clear the vidargs used with the BSP demo image to avoid any problems with displays. Enter U-Boot prompt and enter this commands:
setenv vidargs
saveenv
Installing Xorg Server
Initially Arch will not have any Xorg server installed. Proceed as follows to install one after having logged in as root/root:
pacman -S xorg-server xorg-xrandr
And then it may be started as follows:
X &
export DISPLAY=:0.0
xrandr
glxgears
To install a full blown desktop environment have a look at the following article on the Arch wiki:
Arch Linux Desktop Environments
E.g. LXDE worked fine for me:
pacman -S lxde
systemctl enable lxdm
reboot
GPU Speed
Since there is no dynamic frequency scaling in Nouveau yet. You can check and change the GPU frequency via sysfs:
    cat /sys/kernel/debug/dri/128/pstate
    01: core 72 MHz *
    02: core 108 MHz
    03: core 180 MHz
    04: core 252 MHz
    05: core 324 MHz
    06: core 396 MHz
    07: core 468 MHz
    08: core 540 MHz
    09: core 612 MHz
    0a: core 648 MHz
    0b: core 684 MHz
    0c: core 708 MHz
    0d: core 756 MHz
    0e: core 804 MHz
    0f: core 852 MHz
    DC: core 72 MHz
echo 0f > /sys/kernel/debug/dri/128/pstate
Known Issues
The following Nouveau kernel boot messages are not to be worried about. The 0 Mib VRAM message is due to the K1 SoC using unified memory rather than separate GPU VRAM. And the ce channel error -22 is due to the GPU being integrated directly on the K1 SoC and not having to pass via PCIe:
[   11.367215] nouveau: loading out-of-tree module taints kernel.
[   11.400352] nouveau 57000000.gpu: NVIDIA GK20A (0ea000a1)
[   11.406127] nouveau 57000000.gpu: imem: using IOMMU
[   11.483058] [TTM] Zone  kernel: Available graphics memory: 378360 kiB
[   11.489737] [TTM] Zone highmem: Available graphics memory: 1033718 kiB
[   11.496474] [TTM] Initializing pool allocator
[   11.501044] [TTM] Initializing DMA pool allocator
[   11.506112] nouveau 57000000.gpu: DRM: VRAM: 0 MiB
[   11.511076] nouveau 57000000.gpu: DRM: GART: 1048576 MiB
[   11.521936] nouveau 57000000.gpu: DRM: failed to create ce channel, -22
[   11.637449] nouveau 57000000.gpu: DRM: MM: using GRCE for buffer copies
