Audio (Linux)
Our Embedded Linux BSPs use the regular Linux audio subsystem Advanced Linux Sound Architecture (ALSA). The ALSA subsystem can be configured using amixer or alsamixer whereas playing and recording is possible using the ALSA utilities aplay and arecord. Higher level frameworks such as GStreamer allow to convert audio streams (e.g. sample rate) and play/record encoded audio streams such as MP3, FLAC or Ogg/Vorbis file formats. This article provides some example commands showing how to control and use audio with a Toradex Embedded Linux BSP.
The easiest way to test audio playback running any of our embedded Linux BSP demo images is using the built-in speaker-test as follows:
speaker-test --device hw:0,0 --rate 48000 --channels 2 --format S16_LE --test wav
Using hw:0,0 should output audio on the regular primary head phone jack available on any of our carrier boards.
NXP/Freescale i.MX6 based Modules
All modules based on the NXP/Freescale i.MX 6 SoC provide an on-module NXP/Freescale SGTL5000 audio codec, SPDIF signals and Audio through HDMI. HW accelerated decoding and encoding is provided by GStreamer plugins.
Note that the HDMI sound card is only available if the video output is configured for HDMI and a monitor is attached.
root@apalis-imx6:~# cat /proc/asound/cards
 0 [imx6qapalissgtl]: imx6q-apalis-sg - imx6q-apalis-sgtl5000
 1 [imxspdif       ]: imx-spdif - imx-spdif
                      imx-spdif
 2 [imxhdmisoc     ]: imx-hdmi-soc - imx-hdmi-soc
                      imx-hdmi-soc
root@apalis-imx6:~# aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=imx6qapalissgtl
    imx6q-apalis-sgtl5000,
    Default Audio Device
sysdefault:CARD=imxspdif
    imx-spdif,
sysdefault:CARD=imxhdmisoc
    imx-hdmi-soc,
surround40:CARD=imxhdmisoc,DEV=0
    imx-hdmi-soc,
    4.0 Surround output to Front and Rear speakers
SGTL5000 Playback
The SGTL5000 is the default sound device, thus one does not need to specify it explicitly on the command line.
Playback of a wave file:
root@apalis-imx6:~# aplay Gong.wav
Playing WAVE 'Gong.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
root@apalis-imx6:~# aplay -D sysdefault:CARD=imx6qapalissgtl Gong.wav
SGTL5000 Capture from Line-in
Stereo capture can be achieved using Line-in functionality. First, the "Capture Select" needs to be selected correctly in ALSA mixer:
root@apalis-imx6:~# amixer set 'Capture Mux' 'LINE_IN'
Simple mixer control 'Capture Mux',0
  Capabilities: enum
  Items: 'MIC_IN' 'LINE_IN'
  Item0: 'LINE_IN'
Then recording in various sample rates is natively possible:
root@apalis-imx6:~# arecord -r 48000 -f S16_LE -c 2 Capture48kHz.wav
Recording WAVE 'Capture48kHz.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
^C
root@apalis-imx6:~# arecord -r 8000 -f S16_LE -c 2 Capture8kHz.wav
Recording WAVE 'Capture8kHz.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
^C
SGTL5000 Capture from Microphone
Change the input channel to MIC_IN:
root@apalis-imx6:~# amixer set 'Capture Mux' 'MIC_IN'
In contrast to Line-in, Microphone capture is mono anyway, hence we can save some space by only recording one channel. The argument -V offers a VU meter which helps to see whether there is any input and if the volume of it is at a reasonable level.
root@apalis-imx6:~# arecord  -V mono -r 8000 -f S16_LE -c 1 Capture8kHz.wav
Recording WAVE 'Capture8kHz.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
###                                             +  | 94%
^C
SPDIF Playback
Apalis features dedicated SPDIF pins and the Apalis Evaluation board provides an Optical Transmitter. Thus the Apalis iMX6 image has the SPDIF feature enabled in our default device tree, while for the Colibri iMX6 it is not enabled.
root@apalis-imx6:~# aplay -D sysdefault:CARD=imxspdif Gong.wav
HDMI Playback
In addition to the video data stream HDMI is able to carry audio data as well. Note that depending on the used video resolution/framerate that feature might not be available.
root@apalis-imx6:~# aplay -D sysdefault:CARD=imxhdmisoc Gong.wav
MP3 Playback
The following example shows how to play back MP3 audio via GStreamer using hardware accelerated MP3 decoding. Please note that the two numbers at the end specify which ALSA card and device to use for audio (e.g. alsasink device=hw:0,0 for SGTL5000, alsasink device=hw:1,0 for SPDIF and, alsasink device=hw:2,0 for audio through HDMI, compare with /proc/asound/cards).
Additional GStreamer pipelines can be found on the Fresscale community website here. .
gst-launch filesrc location=Gong.mp3 typefind=true ! beepdec ! alsasink device=hw:0,0
Using alternatively the playbin2 plugin which sets up the pipeline automatically:
root@apalis-imx6:~# gst-launch playbin2 uri=file:///home/root/Gong.mp3
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
WARNING: from element /GstPlayBin2:playbin20/GstPlaySink:playsink0: No volume control found
Additional debug info:
/build/linuxdev/oe-core/build/out-glibc/work/armv7at2hf-vfp-neon-mx6qdl-angstrom-linux-gnueabi/gst-plugins-base/0.10.36-r8/gst-plugins-base-0.10.36/gst/playback/gstplaysink.c(1869): gen_audio_chain (): /GstPlayBin2:playbin20/GstPlaySink:playsink0:
Volume/mute is not available
Beep: 3.0.11
Core: MP3 decoder Wrapper  build on Mar 21 2014 15:04:50
  mime: audio/mpeg, mpegversion = (int)1
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_MP3D_ARM_02.13.00_CORTEX-A8  build on Apr 10 2014 15:26:15.
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstAudioSinkClock
Got EOS from element "playbin20".
Execution ended after 9596381667 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Recording MP3
To record and encode to MP3, the following GStreamer command can be used:
root@apalis-imx6:~# gst-launch alsasrc ! mfw_mp3encoder ! filesink location= audio.mp3
^C
NXP/Freescale Vybrid based Modules
Within the Vybrid module family only Colibri VF61 supports analogue audio. Audio is handled by the on-board Wolfson WM9715L audio codec connected via a AC97 audio link to the Vybrid SoC. The audio codec driver is called wm9712-codec, since it was initially created for the almost identical WM9712L codec.
WM9715L AC97 Playback
Playback of a WAVE file:
root@colibri-vf:~# aplay Test48kHz.wav
Playing WAVE 'Test48kHz.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
root@colibri-vf:~# aplay Test44.1kHz.wav
Playing WAVE 'Test44.1kHz.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Note: Some parts of the AC97 protocol are realized in software. To make Software AC97 efficient, a rather large buffer is used to prepare several AC97 frames in a batch. However, using buffering does not allow to use the variable sample rate (VRA) feature of the AC97 link during playback, since that would require a response which depends on the request flag of the last received frame. Therefore, the hardware is only able to transfer 48kHz sample rate PCM streams. The ALSA audio stack is able to re-sample the sample rate dynamically, the only difference is that a file with a sample rate other than 48kHz requires somewhat more CPU resources while playback (<1% vs ~3%). Implementing the AC97 protocol without buffering would lead to much higher CPU load than relying on ALSA's re-sampling feature.
The hardware parameter of the PCM stream during playback can be seen via the proc file system:
root@colibri-vf:~# cat /proc/asound/card0/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 48000 (48000/1)
period_size: 1024
buffer_size: 4096
Playback of encoded audio formats can be achieved using GStreamer. The Colibri VF61 root filesystem does not provide GStreamer by default, however it is installable via Angstrom feeds:
root@colibri-vf:~# opkg install gst-plugins-base-playbin gst-plugins-base-alsa gst-plugins-base-audioconvert gst-plugins-base-audioresample gst-plugins-base-vorbis gst-plugins-base-ogg gst-plugins-good-wavenc
The following GStreamer pipeline allows to playback Ogg Vorbis encoded audio files:
root@colibri-vf:~# gst-launch filesrc location=./vorbis.ogg ! oggdemux ! vorbisdec ! audioconvert ! alsasink
WM9715L AC97 Capture
The WM9715L has two audio ADCs hence allows for stereo audio capture. Through the ALSA Capture Select controls the input to those capture ADCs can be individually selected. The capture volume and boost is handled after the channel selection, hence the volume applies for the Microphone as well as for Line-In capturing.
Two record volume modes can be selected, a standard AC97 1.5dB gain steps and am extended mode using 0.75dB gain steps. The extended mode (0.75dB gain steps) has also a larger gain range (-17.25-+30db), hence we recommend to use the extended mode.
root@colibri-vf:~# amixer set 'Capture Volume Steps' '+0.75dB Steps'
The record volume can then set to a value between 0-63 (which mappings linearly to the gain ranges above).
root@colibri-vf:~# amixer set 'Capture' 50
Depending on the input (e.g. microphones) a boost might be necessary to increase the ADC signal by +20dB.
root@colibri-vf:~# amixer set 'Capture Boost' unmute
Line-in
root@colibri-vf:~# amixer set 'Left Capture Select' 'Line'
Simple mixer control 'Left Capture Select',0
  Capabilities: enum
  Items: 'Mic' 'NC' 'NC' 'Speaker Mixer' 'Line' 'Headphone Mixer' 'Phone Mixer' 'Phone'
  Item0: 'Line'
root@colibri-vf:~# amixer set 'Right Capture Select' 'Line'
root@colibri-vf:~# arecord -r 48000  -V mono -f S16_LE -c 2 Capture48kHz.wav
^C
root@colibri-vf:~# arecord -r 8000 -f S16_LE -c 2 Capture8kHz.wav
^C
To record the Ogg Vorbis audio format, the following GStreamer command can be used
root@colibri-vf:~# gst-launch alsasrc do-timestamp=true ! audioconvert ! vorbisenc quality=0.4 ! oggmux ! filesink location=vorbis.ogg
Microphone
root@colibri-vf:~# amixer set 'Left Capture Select' 'Mic'
root@colibri-vf:~# amixer set 'Right Capture Select' 'Mic'
The Colibri standard has only one microphone input, which is connected to Mic 1 of the audio codec. The codec internally samples the same signal with both ADCs, hence the ALSA stack receives a stereo signal. However, since the signals are the same, we can save some space by only recording one channel. The argument -V offers a VU meter which helps to see whether there is any input and if the volume of it is on a reasonable level.
root@colibri-vf:~# arecord  -V mono -r 8000 -f S16_LE -c 1 Capture8kHz.wav
#######             +                              | 38%
^C
Note: The volume controls "Mic 1" and "Mic 2" do not change the volume when capturing from microphone. Those volume controls are only active if the sidetone path is enabled (e.g. direct path from microphone to headphone). Use the main capture volume to control the microphone volume.
NVIDIA Tegra based Modules
The Colibri T20 modules have a Wolfson WM9715L audio codec on board. To find pin assignment refer to the Hardware reference.
The Apalis T30, Apalis TK1 and Colibri T30 modules feature a on-module SGTL5000 audio codec:
root@apalis-t30:~# cat /proc/asound/cards
 0 [apalist30sgtl50]: apalis_t30-sgtl - apalis_t30-sgtl5000
                      apalis_t30-sgtl5000
 1 [Tegra          ]: HDA-Intel - HDA NVIDIA Tegra
                      HDA NVIDIA Tegra at 0x70038000 irq 113
root@apalis-t30:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: apalist30sgtl50 [apalis_t30-sgtl5000], device 0: SGTL5000 PCM sgtl5000-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: apalist30sgtl50 [apalis_t30-sgtl5000], device 1: SPDIF PCM dit-hifi-1 []
  Subdevices: 1/1
card 1: Tegra [HDA NVIDIA Tegra], device 0: ALC898 Analog [ALC898 Analog]
  Subdevices: 1/1
card 1: Tegra [HDA NVIDIA Tegra], device 1: ALC898 Digital [ALC898 Digital]
  Subdevices: 1/1
card 1: Tegra [HDA NVIDIA Tegra], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
root@apalis-t30:~# aplay -L
null
default:CARD=apalist30sgtl50
    apalis_t30-sgtl5000,
sysdefault:CARD=apalist30sgtl50
default:CARD=Tegra
    HDA NVIDIA Tegra, ALC898 Analog
sysdefault:CARD=Tegra
front:CARD=Tegra,DEV=0
    Front speakers
surround21:CARD=Tegra,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Tegra,DEV=0
surround41:CARD=Tegra,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Tegra,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Tegra,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Tegra,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Tegra,DEV=0
    HDA NVIDIA Tegra, ALC898 Digital
    IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=Tegra,DEV=0
    HDA NVIDIA Tegra, HDMI 0
    HDMI Audio Output
HDA through HDMI
root@apalis-t30:~# speaker-test --device hw:1,3 --rate 48000 --channels 2 --format S16_LE --test wav
speaker-test 1.0.29
Playback device is hw:1,3
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 16384
Period size range from 32 to 8192
Using max buffer size 16384
Periods = 4
was set period_size = 4096
was set buffer_size = 16384
 0 - Front Left
 1 - Front Right
Time per period = 2.745482
^CTransfer failed: Bad address
Please note that not all pixel clock frequencies allow for HDA being streamed through HDMI. E.g. at VESA VGA resolution you may get an error reported as follows:
[   16.245677] tegradc tegradc.1: hdmi: can't set audio to 44100 at 25175000 pix_clock
Plus the number of available channels depends on the resp. HDMI device being connected to.
SGTL5000 Capture from Line-In
root@apalis-t30:~# amixer set 'Capture' 12
Simple mixer control 'Capture',0
  Capabilities: cvolume
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 15
  Front Left: Capture 12 [80%]
  Front Right: Capture 12 [80%]
root@apalis-t30:~# amixer set 'Capture Mux' 'LINE_IN'
  Capabilities: enum
  Item0: 'LINE_IN'
root@apalis-t30:~# arecord -D hw:0,0 -V stereo -c 2 -f S16_LE -r 48000 -t wav linein.wav
Recording WAVE 'linein.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
                                  +00%|00%+                                   ^CAborted by signal Interrupt...
root@apalis-t30:~# amixer set 'Mic' 1
Simple mixer control 'Mic',0
  Capabilities: volume volume-joined
  Playback channels: Mono
  Capture channels: Mono
  Limits: 0 - 3
  Mono: 1 [33%] [20.00dB]
root@apalis-t30:~# amixer set 'Capture Mux' 'MIC_IN'
  Capabilities: enum
  Item0: 'MIC_IN'
root@apalis-t30:~# arecord -D hw:0,0 -V mono -c 2 -f S16_LE -r 48000 -t wav mic.wav
Recording WAVE 'mic.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
#                             +                    | 59%^CAborted by signal Interrupt...
SGTL5000 Playback through Headphone
root@apalis-t30:~# amixer set 'Headphone' 113
Simple mixer control 'Headphone',0
  Capabilities: pvolume
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 113 [89%] [5.00dB]
  Front Right: Playback 113 [89%] [5.00dB]
root@apalis-t30:~# amixer set 'Headphone Mux' 'DAC'
Simple mixer control 'Headphone Mux',0
  Capabilities: enum
  Items: 'DAC' 'LINE_IN'
  Item0: 'DAC'
root@apalis-t30:~# amixer set 'PCM' 144
Simple mixer control 'PCM',0
  Limits: Playback 0 - 192
  Mono:
  Front Left: Playback 144 [75%]
  Front Right: Playback 144 [75%]
root@apalis-t30:~# aplay -D hw:0,0 linein.wav
Playing WAVE 'linein.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
SPDIF through HDMI
The Colibri T20 provides SPDIF signals and Audio through HDMI.
root@colibri-t20:~# speaker-test --device hw:0,1 --rate 48000 --channels 2 --format S16_LE --test wav
Please note that not all pixel clock frequencies allow for SPDIF being streamed through HDMI. E.g. at VESA VGA resolution you may get an error reported as follows:
WM9715L AC97 Capture from Line-in
  • Colibri SODIMM pin 5 & 7 (LINEIN_L/R)
  • Iris: Audio header X9 pin 3 & 4 (Line IN R/L)
  • Colibri Evaluation Board: Audio jack X26 top blue
  • Orchid: Audio jack X11 top blue line in
  • MECS Tellurium: Audio jack X11 pin 1 & 2 (LINEIN_L/R)
First ALSA needs to be configured correctly using amixer.
root@colibri_t20:~# amixer set 'Left Capture Select' 'Line'
  Capabilities: enum
  Item0: 'Line'
root@colibri_t20:~# amixer set 'Right Capture Select' 'Line'
Simple mixer control 'Right Capture Select',0
  Capabilities: enum
  Item0: 'Line'
root@colibri_t20:~# amixer set 'Capture ADC' on
Simple mixer control 'Capture ADC',0
  Capabilities: pswitch pswitch-joined penum
  Mono: Playback [on]
root@colibri_t20:~# amixer set 'Left HP Mixer Line Bypass' on
Simple mixer control 'Left HP Mixer Line Bypass',0
  Mono: Playback [on]
root@colibri_t20:~# amixer set 'Right HP Mixer Line Bypass' on
Simple mixer control 'Right HP Mixer Line Bypass',0
  Mono: Playback [on]
Recording can then be done easily using GStreamer.
root@colibri_t20:~# gst-launch alsasrc device=hw:0,0 num-buffers=1000 ! audioconvert ! audio/x-raw-int,channels=2,width=16,depth=16 ! audioresample ! wavenc ! filesink location=linein.wav
[ 1954.087441] i2s_set_channel_bit_count: enabling non-symmetric mode
Pipeline is live and does not need PREROLL ...
New clock: GstAudioSrcClock
Got EOS from element "pipeline0".
Execution ended after 11613432000 ns.
ALC898 HDA Capture from Line-in
  • Apalis Evaluation Board: HDA Audio jack X27 top blue
root@apalis_t30:~# amixer -c 1 set 'Capture' 100 on
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
root@apalis_t30:~# amixer -c 1 set 'Input Source' 'Line'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Rear Mic' 'Front Mic' 'Line' 'CD'
  Item0: 'Line'
root@apalis_t30:~# amixer -c 1 set 'Line' 100 on
Simple mixer control 'Line',0
  Capabilities: pvolume pswitch
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 31 [100%] [12.00dB] [on]
  Front Right: Playback 31 [100%] [12.00dB] [on]
root@apalis_t30:~# gst-launch alsasrc device=hw:1,0 num-buffers=1000 ! audioconvert ! audio/x-raw-int,channels=2,width=16,depth=16 ! audioresample ! wavenc ! filesink location=linein.wav
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 3256371004 ns.
WM9715L AC97 Capture from Microphone
  • Colibri SODIMM pin 1 (MIC_IN)
  • Iris: Audio header X9 pin 2 (requires biasing)
  • Colibri Evaluation Board: Audio jack X26 bottom pink
  • Orchid: Audio jack X11 bottom pink MIC in
root@colibri_t20:~# amixer set 'Left Capture Select' 'Mic'
  Capabilities: enum
  Item0: 'Mic'
root@colibri_t20:~# amixer set 'Right Capture Select' 'Mic'
  Capabilities: enum
  Item0: 'Mic'
  Mono: Playback [on]
root@colibri_t20:~# amixer set 'Left HP Mixer Mic Sidetone' on
Simple mixer control 'Left HP Mixer Mic Sidetone',0
  Mono: Playback [on]
root@colibri_t20:~# amixer set 'Right HP Mixer Mic Sidetone' on
Simple mixer control 'Right HP Mixer Mic Sidetone',0
  Mono: Playback [on]
root@colibri_t20:~# gst-launch alsasrc device=hw:0,0 num-buffers=1000 ! audioconvert ! audio/x-raw-int,channels=2,width=16,depth=16 ! audioresample ! wavenc ! filesink location=mic.wav
[ 2037.976550] i2s_set_channel_bit_count: enabling non-symmetric mode
Execution ended after 11613453000 ns.
ALC898 HDA Capture from Microphone
  • Apalis Evaluation Board: Audio jack X27 bottom pink
    root@apalis_t30:~# amixer -c 1 set 'Input Source' 'Rear Mic'
      Capabilities: cenum
      Item0: 'Rear Mic'
    root@apalis_t30:~# amixer -c 1 set 'Rear Mic' 100 on
    Simple mixer control 'Rear Mic',0
      Mono:
    root@apalis_t30:~# amixer -c 1 set 'Rear Mic Boost' 100 on
    Simple mixer control 'Rear Mic Boost',0
      Limits: 0 - 3
      Front Left: 3 [100%] [30.00dB]
      Front Right: 3 [100%] [30.00dB]
    root@apalis_t30:~# gst-launch alsasrc device=hw:1,0 num-buffers=1000 ! audioconvert ! audio/x-raw-int,channels=2,width=16,depth=16 ! audioresample ! wavenc ! filesink location=mic.wav
WM9715L AC97 Playback through Headphone
  • Colibri SODIMM pin 15 & 17 (HEADPHONE_L/R)
  • Iris: Audio jack X8
  • Colibri Evaluation Board: Audio jack X26 middle green
  • Orchid: Audio jack X11 middle green line out
  • Protea: Audio jack X53 line out
  • MECS Tellurium: Audio jack X11 pin 4 & 5 (HEADPHONE_LF/RF)
    root@colibri_t20:~# amixer set 'Headphone' 8 on
      Capabilities: pvolume pswitch pswitch-joined penum
      Mono:
      Front Left: Playback 8 [26%] [on]
      Front Right: Playback 8 [26%] [on]
    root@colibri_t20:~# amixer set 'Left HP Mixer PCM' on
    Simple mixer control 'Left HP Mixer PCM',0
      Mono: Playback [on]
    root@colibri_t20:~# amixer set 'Right HP Mixer PCM' on
    Simple mixer control 'Right HP Mixer PCM',0
      Mono: Playback [on]
    root@colibri_t20:~# aplay bach.au
    [ 2924.023213] i2s_set_channel_bit_count: enabling non-symmetric mode
    Playing Sparc Audio 'bach.au' : Mu-Law, Rate 8000 Hz, Mono
    root@colibri_t20:~# gst-launch filesrc location=mic.wav ! wavparse ! audioconvert ! alsasink device=hw:0,0
    [ 2459.620319] i2s_set_channel_bit_count: enabling non-symmetric mode
    Execution ended after 11611505001 ns.
ALC898 HDA Playback through Headphone
  • Apalis Evaluation Board: Audio jack X27 middle green
    root@apalis_t30:~# amixer -c 1 set 'Front' 100 on
    Simple mixer control 'Front',0
      Limits: Playback 0 - 87
      Mono:
      Front Left: Playback 87 [100%] [0.00dB] [on]
      Front Right: Playback 87 [100%] [0.00dB] [on]
    root@apalis_t30:~# gst-launch filesrc location=mic.wav ! wavparse ! audioconvert ! alsasink device=hw:1,0
    Execution ended after 3258022000 ns.
MP3 Playback
The following example shows how to play back MP3 audio via GStreamer using hardware accelerated MP3 decoding. Please note that the two numbers at the end specify which ALSA card and device to use for audio (e.g. alsasink device=hw:0,0 for WM9715L AC97 through headphone and alsasink device=hw:1,0 for SPDIF through HDMI).
root@colibri-t20:~# gst-launch filesrc location=/home/root/03_Scar_Tissue.mp3 ! mpegaudioparse ! nv_omx_mp3dec ! alsasink device=hw:0,0
[26776.345823] avp_init: Using AVP MMU to relocate AVP kernel
[26776.428892] avp_init: Reading firmware from 'nvrm_avp.bin' (46612 bytes)
[26776.441076] avp_init: Loading AVP kernel at vaddr=d7a00000 paddr=18100000
[26776.488814] avp_reset: Resetting AVP: reset_addr=100000
[26776.506561] process_connect_locked: got connect (111794)
[26776.506746] avp_node_try_connect: trying connect from RPC_AVP_PORT
[26776.518587] avp_svc_thread: got remote peer
[26776.523229] [AVP]: AVP kernel (Nov  2 2012 16:47:31)
[26776.537301] avp_node_try_connect: got conn ack 'RPC_AVP_PORT' (cd049b60 <-> 111758)
[26776.545378] avp_init: avp init done
[26776.548917] avp_lib: loading library 'nvmm_manager.axf'
[26776.596783] avp_lib: Successfully loaded library nvmm_manager.axf (lib_id=118960)
[26776.605064] avp_node_try_connect: trying connect from NVMM_MANAGER_SRV
[26776.621815] avp_node_try_connect: got conn ack 'NVMM_MANAGER_SRV' (cdb48f80 <-> 119c00)
[26776.714101] tegra20_ac97_hw_params(): dai->id=0, play
[26776.803786] tegra20_ac97_trigger()
[26776.807247] tegra20_ac97_start_playback()
[26776.811295] ac97_fifo_set_attention_level()
[26776.815502] ac97_slot_enable()
Execution ended after 236898907001 ns.
[27013.681352] tegra20_ac97_trigger()
[27013.684795] tegra20_ac97_stop_playback()
[27013.688743] ac97_fifo_set_attention_level()
[27013.693968] ac97_slot_enable()
[27013.719878] process_disconnect_locked: got disconnect (cdb48f80)
[27013.741936] avp_lib: Successfully unloaded 'nvmm_manager.axf'
[27013.748859] avp_lib: unloaded 'nvmm_manager.axf'
[27013.754949] avp_svc_thread: AVP seems to be down; wait for kthread_stop
[27013.762933] avp_svc_thread: exiting
[27013.767639] avp_uninit: avp teardown done
USB Audio Hardware
CONFIG_SND_USB_AUDIO is enabled so you may use USB audio hardware.
If you get the following error when recording from USB enable the CONFIG_USB_EHCI_TT_NEWSCHED kernel configuration.
root@colibri_t20:~# arecord -D hw:3,0 -c 2 -f S16_LE -r 44100 -t wav usbin.wav
Recording WAVE 'usbin.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
[ 3187.734697] cannot submit datapipe for urb 0, error -28: not enough bandwidth
