Audio Playback (WinCE)
This article demonstrates how audio can be played using program in C and C#.
Audio Playback in C
Using Waveform Audio Functions
  • Waveform Audio Functions (WAF) can only play waveform (or uncompressed) files. For more information see MSDN.
  • Demo project can be downloaded here.
  • To build the project, navigate to Build menu in Visual studio and click Build Solution.
  • Click Deploy solution in the Build menu to deploy the application. A sample WAV clip will also be deployed along with the executable demo file.
  • Goto My Device > Program Files > vcpp_audio_playback_waf. Double click on the vcpp_audio_playback_waf.exe to run the application.
Using DirectShow
  • DirectShow libraries can be used to play files with extensions .wav, .mp3, .wma, .ogg etc. For more information see MSDN.
  • Click Deploy solution in the Build menu to deploy the application. A sample MP3 clip will also be deployed along with the executable demo file.
  • Goto My Device > Program Files > vcpp_audio_playback_ds. Double click on the vcpp_audio_playback_ds.exe to run the application.
Image shows the output window for both vcpp_audio_playback_waf and vcpp_audio_playback_ds demo applications.
Audio Playback in CSharp
Using DirectShow
  • Go to My Device > Program Files > vcsharp_audio_playback_demo and run the application vcsharp_audio_playback_demo.exe.
Following GUI will open with different controls.
Note: vcsharp_audio_plyback_demo uses DirectShow.net library functions from DirectShowLib-2005.dll from a third party. Microsoft does not provide a managed API for DirectShow. Documentation related to this library and its licence is given here.
