Audio Recording (WinCE)
This article demonstrates how audio can be recorded and played using C and C#.
Waveform Audio Functions (WAF) can be used to record and play audio files in wave (.wav) format. For more information see MSDN.
Audio Recording in C
Download the demo application:
  • To build the project, navigate to Build menu in Visual studio and click Build Solution.
  • Click Deploy solution in the Build menu to deploy the application.
  • Goto My Device > Program Files > vcpp_audio_record_demo. Double click on the vcpp_audio_record_demo.exe to run the application.
Following image shows the output window.
Audio Recording in CSharp
  • Go to My Device > Program Files > vcsharp_audio_record_demo and run the application vcsharp_audio_record_demo.exe.
Following window will open.
