Audio/Video over RTP (Linux)
Tags
UDP/RTP Audio
Install prequisites (only necessary on BSP V1.x, the packages are already pre-installed on BSP V2.x)
root@colibri_t20:~# opkg install gst-plugin-audioconvert gst-plugin-audiotestsrc gst-plugin-rtp
Installing gst-plugin-audioconvert (0.10.31-r11.0.9) to root...
Downloading http://www.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a-vfp/gstreamer/gst-plugin-audioconvert_0.10.31-r11.0.9_armv7a-vfp.ipk.
Installing gst-plugin-audiotestsrc (0.10.31-r11.0.9) to root...
Downloading http://www.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a-vfp/gstreamer/gst-plugin-audiotestsrc_0.10.31-r11.0.9_armv7a-vfp.ipk.
Installing gst-plugin-rtp (0.10.26-r11.0.9) to root...
Downloading http://www.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a-vfp/gstreamer/gst-plugin-rtp_0.10.26-r11.0.9_armv7a-vfp.ipk.
Configuring gst-plugin-rtp.
Configuring gst-plugin-audiotestsrc.
Configuring gst-plugin-audioconvert.
root@colibri_t20:~# opkg --nodeps install gst-plugin-udp libgstnetbuffer-0.10-0
Installing gst-plugin-udp (0.10.26-r11.0.9) to root...
Downloading http://www.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a-vfp/gstreamer/gst-plugin-udp_0.10.26-r11.0.9_armv7a-vfp.ipk.
Installing libgstnetbuffer-0.10-0 (0.10.32-r11.1.9) to root...
Downloading http://www.angstrom-distribution.org/feeds/next/ipk/eglibc/armv5te/base/libgstnetbuffer-0.10-0_0.10.32-r11.1.9_armv5te.ipk.
Configuring libgstnetbuffer-0.10-0.
Configuring gst-plugin-udp.
Setting up receiver and sender.
root@colibri_t20:~# gst-launch -v udpsrc port=5000 ! "application/x-rtp,media=(string)audio, clock-rate=(int)44100, width=16, height=16, encoding-name=(string)L16, encoding-params=(string)1, channels=(int)1, channel-positions=(int)1, payload=(int)96" ! rtpL16depay ! audioconvert ! alsasink device=hw:2,0 sync=false &
Setting pipeline to PAUSED ...
[ 4450.608338] i2s_set_channel_bit_count: enabling non-symmetric mode
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
root@colibri_t20:~# gst-launch audiotestsrc ! audioconvert ! audio/x-raw-int,channels=1,depth=16,width=16,rate=44100 ! rtpL16pay ! udpsink host=localhost port=5000
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, media=(string)audio, clock-rate=(int)44100, width=(int)16, height=(int)16, encoding-name=(string)L16, encoding-params=(string)1, channels=(int)1, channel-positions=(int)1, payload=(int)96
/GstPipeline:pipeline0/GstRtpL16Depay:rtpl16depay0.GstPad:src: caps = audio/x-raw-int, endianness=(int)4321, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)1, channel-positions=(GstAudioChannelPosition)< GST_AUDIO_CHANNEL_POSITION_FRONT_MONO >
/GstPipeline:pipeline0/GstRtpL16Depay:rtpl16depay0.GstPad:sink: caps = application/x-rtp, media=(string)audio, clock-rate=(int)44100, width=(int)16, height=(int)16, encoding-name=(string)L16, encoding-params=string)1, channels=(int)1, channel-positions=(int)1, payload=(int)96
/GstPipeline:pipeline0/GstAudioConvert:audioconvert0.GstPad:src: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstAudioConvert:audioconvert0.GstPad:sink: caps = audio/x-raw-int, endianness=(int)4321, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)1, channel-positions=(GstAudioChannelPosition)< GST_AUDIO_CHANNEL_POSITION_FRONT_MONO >
/GstPipeline:pipeline0/GstAlsaSink:alsasink0.GstPad:sink: caps = audio/x-raw-int, endianness=(int)1234, signed=(boolean)true, width=(int)16, depth=(int)16, rate=(int)44100, channels=(int)2
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 3755851999 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
UDP/RTP Audio & Video
First, one has to analyse the stream capabilities at the sender in order to be able to use them at the receiving end (press CTRL-C when status info has appeared):
root@colibri_t20:~# gst-launch -v filesrc location=/home/root/nv_medusa_h264_720_6M_cbr_2p_key60_q90_aac128_44.mp4 ! qtdemux name=demux demux.video_00 ! queue ! rtph264pay pt=96 ! udpsink host=localhost port=5000 demux.audio_00 ! queue ! rtpmp4apay pt=97 ! udpsink host=localhost port=5001
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-h264, level=(string)3.2, profile=(string)constrained-baseline, codec_data=(buffer)0142c020ffe100226742c020967402802dd80a0400002edc000afc80d18002dc8000b71d7bdf0784423501000468de3c80, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-h264, level=(string)3.2, profile=(string)constrained-baseline, codec_data=(buffer)0142c020ffe100226742c020967402802dd80a0400002edc000afc80d18002dc8000b71d7bdf0784423501000468de3c80, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z0LAIJZ0AoAt2AoEAAAu3AAK/IDRgALcgAC3HXvfB4RCNQ\\=\\=\\,aN48gA\\=\\=\", payload=(int)96, ssrc=(uint)3857927412, clock-base=(uint)3864708562, seqnum-base=(uint)43861
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, level=(string)3.2, profile=(string)constrained-baseline, codec_data=(buffer)0142c020ffe100226742c020967402802dd80a0400002edc000afc80d18002dc8000b71d7bdf0784423501000468de3c80, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 3864708562
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 43861
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z0LAIJZ0AoAt2AoEAAAu3AAK/IDRgALcgAC3HXvfB4RCNQ\\=\\=\\,aN48gA\\=\\=\", payload=(int)96, ssrc=(uint)3857927412, clock-base=(uint)3864708562, seqnum-base=(uint)43861
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)121056e500, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)121056e500, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstRtpMP4APay:rtpmp4apay0.GstPad:src: caps = application/x-rtp, media=(string)audio, clock-rate=(int)44100, encoding-name=(string)MP4A-LATM, cpresent=(string)0, config=(string)40002420adca00, payload=(int)97, ssrc=(uint)2324768575, clock-base=(uint)2616710116, seqnum-base=(uint)26397
/GstPipeline:pipeline0/GstRtpMP4APay:rtpmp4apay0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)121056e500, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstRtpMP4APay:rtpmp4apay0: timestamp = 2616710116
/GstPipeline:pipeline0/GstRtpMP4APay:rtpmp4apay0: seqnum = 26397
/GstPipeline:pipeline0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtp, media=(string)audio, clock-rate=(int)44100, encoding-name=(string)MP4A-LATM, cpresent=(string)0, config=(string)40002420adca00, payload=(int)97, ssrc=(uint)2324768575, clock-base=(uint)2616710116, seqnum-base=(uint)26397
Now we set environment variables from the udpsink0.GstPad:sink and udpsink1.GstPad:sink, probably ssrc, clock-base, seqnum-base can be omitted:
root@colibri_t20:~# VCAPS="application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z0LAIJZ0AoAt2AoEAAAu3AAK/IDRgALcgAC3HXvfB4RCNQ\\=\\=\\,aN48gA\\=\\=\", payload=(int)96"
root@colibri_t20:~# ACAPS="application/x-rtp, media=(string)audio, clock-rate=(int)44100, encoding-name=(string)MP4A-LATM, cpresent=(string)0, config=(string)40002420adca00, payload=(int)97"
Start receiver as a background process:
root@colibri_t20:~# gst-launch udpsrc port=5000 ! $VCAPS ! rtph264depay ! nv_omx_h264dec ! nv_gl_videosink rendertarget=0 udpsrc port=5001 ! $ACAPS ! rtpmp4adepay ! nv_omx_aacdec ! alsasink device=hw:2,0 &
Sender/Receiver on Localhost
Then start sender with the same command-line as above:
root@colibri_t20:~# gst-launch filesrc location=/home/root/nv_medusa_h264_720_6M_cbr_2p_key60_q90_aac128_44.mp4 ! qtdemux name=demux demux.video_00 ! queue ! rtph264pay pt=96 ! udpsink host=localhost port=5000 demux.audio_00 ! queue ! rtpmp4apay pt=97 ! udpsink host=localhost port=5001
Sending Point-to-Point
Of course it makes much more fun to steam over an actual real network. This time we run the sender on an Ubuntu Desktop 12.04 LTS 64-bit machine as follows:
gst-launch-0.10 filesrc location=nv_medusa_h264_720_6M_cbr_2p_key60_q90_aac128_44.mp4 ! qtdemux name=demux demux.video_00 ! queue ! rtph264pay pt=96 ! udpsink host=192.168.10.2 port=5000 demux.audio_00 ! queue ! rtpmp4apay pt=97 ! udpsink host=192.168.10.2 port=5001
Please note that the Colibri T20 target is assumed to have an assigned IP address of 192.168.10.2.
Sending Multicast
But the real eye catcher is when you stream the same video to multiple Colibri T20 targets!
First make sure to add a corresponding multicast route on the sender side as follows:
sudo route add -net 224.0.0.0 netmask 240.0.0.0 dev eth2
Where eth2 is the Ethernet interface towards your little Colibri T20 cluster.
And then stream just like before but now to a multicast address:
gst-launch-0.10 filesrc location=nv_medusa_h264_720_6M_cbr_2p_key60_q90_aac128_44.mp4 ! qtdemux name=demux demux.video_00 ! queue ! rtph264pay pt=96 ! udpsink host=224.0.0.1 port=5000    demux.audio_00 ! queue ! rtpmp4apay pt=97 ! udpsink host=224.0.0.1 port=5001
In order to get better results when streaming over a slightly congested network one can add an additional jitter buffer stage to the pipeline. But first things first, let's install such a Gstreamer plugin:
root@colibri_t20:~# opkg install gst-plugin-rtpmanager
Installing gst-plugin-rtpmanager (0.10.26-r11.0.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a-vfp/gstreamer/gst-plugin-rtpmanager_0.10.26-r11.0.9_armv7a-vfp.ipk.
Configuring gst-plugin-rtpmanager.
And then use it as follows:
root@colibri_t20:~# gst-launch udpsrc port=5000 ! $VCAPS ! gstrtpjitterbuffer ! rtph264depay ! nv_omx_h264dec ! nv_gl_videosink rendertarget=0 sync=false udpsrc port=5001 ! $ACAPS ! rtpmp4adepay ! nv_omx_aacdec ! alsasink device=hw:2,0
