Azure IoT device SDKs for Linux
The Azure IoT device SDKs are available for multiple platforms & programming languages. The following SDKs are supported by the Toradex Linux images:
  • C#
  • Javascript
  • Java
Below are instructions to quickly evaluate the various Azure IoT device SDKs on Toradex modules flashed with a V2.5 (or later) Linux image. These instructions require that you setup an Azure IoT Hub instance. Additionally, the Azure IoT Hub Device Explorer is used to verify functionality in all the proceeding examples.
C# with Mono
Setup Mono on the Device
Install Mono & related packages:
opkg update
opkg install mono mono-dev ca-certificates
Import trusted certificates:
mono /usr/lib/mono/4.5/mozroots.exe --import --sync
Build C# Example Applications
On your host computer, use the Azure IoT C# Application Development guides to build an example C# application (e.g. DeviceClientHttpSample).
Execute C# Example Application
Transfer the compiled C# example application to the device.
Start the Device Explorer application on your host machine.
Execute the C# example application (i.e. DeviceClientHttpSample.exe) on the device using Mono:
mono DeviceClientHttpSample.exe
Javascript with Node.js
Setup Node.js & the Azure IoT Javascript Libraries on the Device
Install Node.js & related packages:
opkg update
opkg install nodejs nodejs-npm python python-simplejson
Copy all the files from the Azure github samples directory into a directory of your choice. Then, inside this directory, install the required Node packages.
npm install
Configure & Execute Example Node.js Application
Edit the example javascript file(s) (e.g. simple_sample_http.js):
vi simple_sample_device.js
and locate the following line to change [IoT Device Connection String] to your connection string as provided by your IoT hub instance:
var connectionString = '[IoT Device Connection String]';
Execute the sample application using Node.js:
node simple_sample_device.js
Java with OpenJDK
Setup the OpenJDK 7 JRE on the Device
Configure additional package repositories on the device and install the OpenJDK 7 JRE and associated dependencies:
wget -P /etc/opkg/ http://feeds.toradex.com/extra/2.5/conf/all/extra.conf
opkg update
opkg install openjdk-7-jre openssl
wget https://www.geotrust.com/resources/root_certificates/certificates/Equifax_Secure_Certificate_Authority.pem
wget https://cacert.omniroot.com/bc2025.crt
/usr/lib/jvm/java-7-openjdk/jre/bin/keytool -keystore ~/cacerts -importcert -alias equifaxsecureca -file  Equifax_Secure_Certificate_Authority.pem
/usr/lib/jvm/java-7-openjdk/jre/bin/keytool -keystore ~/cacerts -importcert -alias baltimorecybertrustca -file bc2025.crt
/usr/lib/jvm/java-7-openjdk/jre/bin/keytool -list -keystore ~/cacerts
Build Example Java Applications
On your host computer, use the Azure IoT Java Application Development guides to build an example Java application (e.g. send-event.java).
Execute Java Example Application
Transfer the compiled Java example application to the device.
Execute the Java example application (i.e. send-event-X.X.X-with-deps.jar) on the device using the OpenJDK JRE - change [IoT Device Connection String] to the connection string as provided by your IoT hub instance:
java -Djavax.net.ssl.trustStore=~/cacerts -jar send-event-X.X.X-with-deps.jar "[IoT Device Connection String]" "5" "https"
