Basic Linux Commands
This article is a collection of basic Linux commands and procedures relevant to using your embedded system.
Note: This article is meant as an overview to get you started, thus you may find useful to search for more comprehensive tutorials, guides and manuals over the internet.
The following contents will be presented:
  • Use the basic Linux commands touch, cp, cd, ls, mv, mkdir, rm and pwd
  • Basic file read/write using echo, cat and the Vi text editor
  • Search for a file or file contents using file and grep
  • Compress and decompress folders using tar
  • Get the system date and time using the timedatectl, date and hwclock commands
  • Create, run in the background and kill a shell script, using the chmod, ps and kill commands
  • Monitor system performance using the system manager htop
  • Run a script automatically at boot time, by creating a service
  • Change the system password using passwd
  • Download files, using wget
  • Use the opkg package manager to list, install and remove packages
Basic Linux commands
This section aims to introduce you to the basic Linux commands touch, cp, cd, ls, mv, mkdir, rm and pwd, as well as some concepts regarding directory structure.
Note: Whenever you want a quick help for a specific command, use --help option, such as in the example below:
<command> --help
Find out in which directory you are
The pwd (present working directory) command output tells you the full path to the directory you are inside:
# pwd
/home/root
Create an empty file
The touch command creates an empty file:
touch sample_file.txt
Create a new directory
By using the pwd command, you already know the present directory is /home/root. Let's create two directories named dir1 and dir2 inside it:
mkdir dir1 dir2
Directory structure
Note: This step explains the directory structure for a Linux environment. You might skip it once this is a theoretical step. Click the button below to show.
In the Linux environment, there is the notion of absolute or full path and relative path. See the following directory structure:
  • Sample directory structure
There are some notations for describing a directory path:
  • / is the root directory. All absolute paths start with /
  • / is also the directory separator
  • . denotes the current or present directory
  • .. denotes the parent directory, relative to the current directory
  • ~ is the home directory. For the Toradex modules, it is always the /home/root directory.
The full path points to a location in a file system without depending on the current directory. The picture below presents the absolute paths for the previously presented directory structure:
  • Absolute paths
    Absolute paths
The relative path points to a location in a file system relative to the current path. The picture below presents the relative paths for the previously presented directory structure, considering /home/root the present directory:
  • Relative paths
    Relative paths
Change directory
Change to the recently created dir1:
#relative path
cd dir1
#absolute path
cd /home/root/dir1
Go back to the parent directory:
#relative path
cd ..
#from anywhere (three possibilities)
cd
cd ~
cd /home/root
Go to the root directory:
cd /
Please go back to the home directory before proceeding to the next step.
Copy file/directory
Use the cp command to copy files. Let's copy the sample_file.txt around:
#copy with the same name to dir1
cp sample_file.txt dir1
#copy to dir2 and rename file to copy_dir2_file.txt
cp sample_file.txt ./dir1/copy_dir2_file.txt
#make a copy to the same directory using the name copy_file.txt
cp sample_file.txt copy_file.txt
In order to copy a whole directory and its contents, preserving file attributes:
cp -a dir1 dir1_copy
If you want to copy the directory contents inside an already created directory:
mkdir dir1_contents
cp -a dir1/. dir1_contents
Note: Use the ls command in the next step to verify the directories contents.
Check directory contents
Use the ls command to see the directory contents:
ls
ls /home
ls /bin
You can see detailed information about the files and directories inside the one being inspected:
ls -l /bin
ls -lh /bin
Move or rename a file/directory
The mv command can be used to rename or move a file/directory:
mv sample_file.txt renamed.txt
mv dir2 directory2
Delete a file/directory
Use the rm command to delete a file or directory.
Warning: The process is not reversible, so be careful to not delete something important!
#Delete file
rm renamed.txt
#Delete directory
rm -r dir1_copy
#Ask before deleting
rm -ri dir1_contents
This section explains how to read and write to a file directly from command-line and also using a text editor.
Write from command-line
Use the echo command to write to a file from the command-line.
Note: This command will be useful to set/configure hardware features from the command-line, although it is limited for text files editing.
#create or overwrite file
echo "Hello World" > readwrite.txt
#create or append to file
echo "Hello Again" >> readwrite.txt
Read from command-line
Use the cat command to read a file from the command-line.
cat readwrite.txt
#print line numbers, ignoring or not the empty lines
cat -b readwrite.txt
cat -n readwrite.txt
Use the Vi text editor
Note: Vi and also the Vim editor have many features and commands. Search the web if you want to dive deep into learning how to use them.
To create or edit a file using the Vi text editor:
vi readwrite
When you open the application, you are in the normal mode and cannot edit the text. Press the "i" key to enter the "insert" mode. Then you can edit the file as you will.
  • Vi text editor insert mode
After you make some changes, press the "ESC" key to return to the "normal" mode. In this mode you can save changes and exit Vi. To do so, type the following:
:wq
This is the command for write -> quit.
  • Save changes and quit Vi
To go to specific line:
# :<line>, for instance:
:4
To search for a specific text:
# /<text>, for instance
/world
Press the "n" key to browse through the occurrences.
  • Vi text search
    Vi text search
File search
This sections describes how to search for a specific file and how to search a directory for specific file text contents.
Search for a specific file
To search for a specific file, use the find command. The search is made inside a specific directory and all of its children directories:
#find <path> -name "<filename>"
#search for a specific file name
find . -name "readwrite.txt"
#search all files with a specific extension
find / -name "*.txt"
#search all files containing "read" in the name, for the current directory
find . -name "*read*"
#search all files containing "read" in the name, for the user directory
find /home/root/ -name "*read*"
Search files containing some text
To search for a file that has a specific text as content, you can use the grep command. Grep is useful not only for file contents search, but also as a filter to the output of other commands, for instance.
#search for files containing the "hello world" string in the current directory
grep -nre "hello world" ./*
#case insensitive search with absolute path
grep -nrie "hello world" /home/root/*
This section describes how to compress and decompress folders using the tar command. It does not cover all the possibilities, only some of the most commonly used.
Compress
#compress folder and contents
tar -cjvf compressed.tar.bz2 dir1
tar -cvf compressed.tar.gz dir1
#compress only the folder contents (notice that there is a dot after the directory)
tar -cjvf compressed.tar.bz2 -C ./dir1 .
tar -cvf compressed.tar.gz -C ./dir1 .
Decompress
#decompress to current directory
tar -xjvf compressed.tar.bz2
tar -xvf compressed.tar.gz
#decompress to specific directory
Date and time
There are two relevant date/time clocks in Linux: the hardware date/time, usually referred to as real-time clock (RTC) and the system date/time. While the command timedatectl takes care of synchronizing both of them, usually the date command is used to get the system time, due to its simpler output.
The hwclock command is commonly used in systems that don't have a program such as timedatectl to synchronize the system and hardware clocks.
Timedatectl get clocks
Get the clock times and system configuration:
# timedatectl
Local time: Thu 2017-01-12 13:34:00 BRST
Universal time: Thu 2017-01-12 15:34:00 UTC
RTC time: Thu 2017-01-12 13:34:01
Time zone: America/Sao_Paulo (BRST, -0200)
Network time on: yes
NTP synchronized: no
RTC in local TZ: yes
Timedatectl set clocks
Set the system clock and synchronize changes with the hardware clock:
timedatectl set-ntp false
timedatectl set-time "2017-01-12 13:40:11"
Timedatectl change system clock time zone
Change the time zone:
#list available time zones
timedatectl list-timezones
#change time zone
timedatectl set-timezone America/Sao_Paulo
Date get system clock
Get the system date/time:
# date
Thu Jan 12 13:56:43 BRST 2017
Note: Hwclock usage will not be presented. For hwclock and also more date and timedatectl usage, please use the option --help, as in hwclock --help.
Shell script
In this chapter you will learn how to create a shell script, run it in the background and kill it. A simple script that prints a string to the terminal every 5 seconds will be used as an example.
Create the script
Create a file named print.sh using the vi editor, with the following contents:
print.sh
#!/bin/sh while true do echo "Hello world!" sleep 5 done
Warning: The line #1/bin/sh is not a commented line! It tells that the application used to execute the script is /bin/sh, therefore you must not erase this line.
Make it executable
Before running it, you have to make the file executable:
chmod +x print.sh
Run the script
Run the script in the foreground:
./print.sh
#or
/home/root/print.sh
Note: Press CTRL+C to stop the script, or any command-line application, from running. Sometimes there are applications that don't exit on CTRL+C such as the vi text editor, but in general it works.
Run in the background
To run the script in the background, just add the "&" character to the end of the line:
./print.sh &
#Notice that you can use the terminal, but CTRL+C won't stop the script from running:
date
ls -l
pwd
Find the script PID
Use the command ps to get a snapshot of all the processes running. Combine it with the grep command to search for a specific task/application:
#list all processes
ps aux
#find only the processes containing "print" in the name
ps aux | grep print
The second output column will print the process ID (PID).
Kill the script
Use kill to stop the script
kill <PID>
See the figure below for reference regarding the previous steps:
  • Find specific process PID
    Run in the background and kill
Note: For this specific case, you could use the fg command to bring the process to the foreground and then use CTRL+C to stop it.
./print.sh &
fg
<CTRL+C>
Note: Behind the kill command, there is the concept of Unix/Linux signals. You may want to search in the web for more information.
System resources monitoring
Htop is an interactive process viewer for Unix systems. It is not the only option available (there is also top) but it was chosen for this how-to because of its user-friendly interface.
Run htop
To run htop:
htop
You should see a screen similar to the one presented in the figure below:
  • Htop overview
    Htop overview
It presents system status and statistics, such as: CPU and RAM usage (the pre-built images have swap disabled by default); system tasks; load average and; uptime. Below the overall status, all of the system tasks are listed, as well as their individual resources usage and other relevant information.
Note: To exit htop press F10.
kill the print.sh script
As an exampĺe of htop functionality, run the stress command in the background to see the CPU usage go up:
./print.sh &
stress -c 1 &
htop
  • CPU usage increased by the stress command
Use the arrow keys to browse through the processes until you find the stress task. You can also use the search functionality pressing F3 or use your mouse to click on the process line:
  • Using htop to kill process
Select SIGTERM and press ENTER to kill the process.
Note: When using the kill system call without parameters, as in the previous step, it sends a SIGTERM to the process.
Startup script
In this section, a service that runs a script at system startup will be created.
Create the script file
Create the file /etc/systemd/system/print.service with the following contents. You can use the vi text editor, previously presented:
[Unit] Description=Start the print.sh script After=multi-user.target [Service] Type=simple ExecStart=/home/root/print.sh [Install] WantedBy=multi-user.target
Enable the service
Reload the configurations and enable the service at startup:
systemctl daemon-reload
systemctl enable print.service
Run and test
Start the script manually for the first time and see its status. Notice that the script doesn't print directly to the terminal, since a new shell session is created by the service.
systemctl start print.service
systemctl status print.service
  • Print script running
Reboot the system
Reboot the system and verify that the script started:
reboot
ps aux | grep print.sh
This section describes how to change the login password.
Single Step: Passwd
Use the command passwd to change the system password:
# passwd
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
Download files
This section shows how to download files from the web using wget.
Warning: Your embedded system must have internet access.
Single step: Download
Use the wget command to download a file from the web:
wget -c http://docs.toradex.com/102075-colibri-imx6-datasheet.pdf
The file will be downloaded in the present directory.
Package manager (OPKG)
OPKG is the package manager for the Ångström distribution. This section shows how to list, install and remove packages.
Update
First of all, update the packages list:
opkg update
List available packages
List the available packages and filter your search using grep:
opkg list
opkg list | grep libpython
Note: The Python programming language has many packages available. If you filter using python instead of libpython, there will be many results to browse through
Install package
To install a package:
opkg install libpython2.7-1.0
