Build U-Boot and Linux Kernel from Source Code
Summary
This article describes how-to build U-Boot and Linux directly without using a higher level build system such as OpenEmbedded. This mostly makes sense during U-Boot or Linux development.
We provide OpenEmbedded recipes which build U-Boot and Linux as part of a complete image, hence if you plan to build a complete image follow the OpenEmbedded (core) article. This article also includes download and build of the software described further down.
Source Code
The source code of U-Boot boot loader and Linux kernel can be found on our Git server at git.toradex.com.
git clone -b <git-branch> git://git.toradex.com/u-boot-toradex.git
git clone -b <git-branch> git://git.toradex.com/linux-toradex.git
Note: Should your company firewall/gateway inhibit the git protocol, you can use HTTP or HTTPS instead (e.g. git clone https://git.toradex.com/u-boot-toradex.git).
The required git branch, U-Boot configuration and U-Boot/Linux binaries to be used depend on module type and image version.
Image Versions
Tegra Based Modules (Apalis/Colibri Txx)
Valid values for <board> are either apalis_t30, apalis-tk1, colibri_t20 or colibri_t30.
Tegra U-Boot Versions
Image Version U-Boot Git Branch U-Boot Configuration U-Boot Binary
V2.0 / V2.1 / V2.2 colibri <board>_config u-boot.bin
V2.3 beta 2 colibri <board>_config u-boot.bin
V2.3 beta 3 colibri (T20)
2014.10-toradex (T30)
<board>_defconfig u-boot.bin (T20)
u-boot-dtb-tegra.bin (T30)
V2.4 / V2.5 / V2.6 2015.04-toradex <board>_defconfig u-boot-dtb-tegra.bin
V2.7 2016.11-toradex <board>_defconfig u-boot-dtb-tegra.bin
Tegra T20/T30 Linux Kernel Versions
Image Version Kernel git branch Kernel Configuration Device Tree Kernel Binary
V2.0 / V2.1 / V2.2 colibri <board>_defconfig - arch/arm/boot/uImage
V2.3 beta 2 tegra <board>_defconfig - arch/arm/boot/uImage
V2.3 beta 3 tegra <board>_defconfig - arch/arm/boot/uImage
V2.4 / V2.5 / V2.6 / V2.7 tegra <board>_defconfig - arch/arm/boot/zImage (T20)
arch/arm/boot/uImage (T30)
Tegra K1 Linux Kernel Versions
V2.6 / V2.7 toradex_tk1_l4t_r21.5 <board>_defconfig tegra124-apalis-eval.dtb arch/arm/boot/uImage
Vybrid Based Modules (Colibri VFxx)
Vybrid U-Boot Versions
V2.1 colibri_vf colibri_vf_config u-boot.nand
V2.2 / V2.3 beta 1 2014.04-toradex colibri_vf_config u-boot-nand.imx
V2.3 beta 3 2014.10-toradex colibri_vf_defconfig u-boot-nand.imx
V2.3 beta 5 2014.10-toradex colibri_vf_defconfig u-boot-nand.imx
V2.4 / V2.5 / V2.6 2015.04-toradex colibri_vf_defconfig u-boot-nand.imx
V2.7 2016.11-toradex colibri_vf_defconfig u-boot-nand.imx
Note concerning U-Boot Binary: The recovery mode aka serial downloader uses the U-Boot Binary u-boot.imx. (e.g. using our update.sh script's -d argument which in turn uses the imx_uart utility).
Vybrid Linux Kernel Versions
V2.1 colibri_vf colibri_vf_defconfig - arch/arm/boot/uImage
V2.2 / V2.3 beta 1 colibri_vf colibri_vf_defconfig - arch/arm/boot/uImage
V2.3 beta 3 colibri_vf colibri_vf_defconfig - arch/arm/boot/zImage
V2.3 beta 5 toradex_vf_3.18 colibri_vf_defconfig vf500-colibri-eval-v3.dtb
vf610-colibri-eval-v3.dtb
V2.4 beta 1 toradex_vf_4.0 colibri_vf_defconfig vf500-colibri-eval-v3.dtb
V2.5 toradex_vf_4.1 colibri_vf_defconfig vf500-colibri-eval-v3.dtb
V2.6 / V2.7 toradex_vf_4.4 colibri_vf_defconfig vf500-colibri-eval-v3.dtb
i.MX 6 Based Modules (Apalis/Colibri iMX6)
Valid values for <board> are either apalis_imx6 or colibri_imx6.
Note: Starting with image V2.7 we use U-Boot together with an SPL to boot from eMMC. The SPL gets loaded by the bootrom into the SoC's SRAM, executes and initializes the DDR RAM according to module type, then it loads U-Boot to DDR and executes it. The Recovery Mode still uses a conventional U-Boot. On Apalis the recovery U-Boot is built for the IT modules RAM requirements which works well on both IT and non IT versions.
Note: For images older than V2.7, when building U-Boot for Apalis iMX6, be sure to use to distinguish between the IT (apalis_imx6_it) and the non-IT (apalis_imx6) versions of the module when configuring the U-Boot sources.
Note: For images older than V2.4, the U-Boot values are apalis_imx6q1g, apalis_imx6q2g, colibri_imx6s256m.
iMX6 U-Boot Versions
V2.2 toradex_imx6 <board>_config u-boot.imx
V2.3 2014.04-toradex <board>_config u-boot.imx
V2.4 / V2.5 / V2.6 2015.04-toradex <board>_defconfig u-boot.imx
apalis_imx6_nospl_it_defconfig
colibri_imx6_nospl_defconfig
SPL, u-boot.img
u-boot.imx
u-boot.imx
iMX6 Linux Kernel Versions
Image Version Kernel Git Branch Kernel Configuration Device Tree Kernel Binary
V2.2 toradex_imx6 <board>_defconfig - arch/arm/boot/uImage
V2.3 toradex_imx_3.10.17_1.0.0_ga <board>_defconfig imx6q-apalis-eval.dtb
imx6q-apalis-eval_v1_0.dtb
imx6dl-colibri-eval-v3.dtb
V2.4 toradex_imx_3.10.17_1.0.0_ga <board>_defconfig imx6q-apalis-eval.dtb
V2.5 toradex_imx_3.14.28_1.0.0_ga <board>_defconfig imx6q-apalis-eval.dtb
imx6q-apalis-ixora.dtb
imx6q-apalis_v1_0-eval.dtb
imx6q-apalis_v1_0-ixora.dtb
V2.6 toradex_imx_3.14.52_1.1.0_ga <board>_defconfig imx6q-apalis-eval.dtb
imx6dl-colibri-cam-eval-v3.dtb
V2.7 toradex_4.1-2.0.x-imx <board>_defconfig imx6q-apalis-eval.dtb
i.MX 7 Based Modules (Colibri iMX7)
iMX7 U-Boot Versions
V2.6 2015.04-toradex colibri_imx7_defconfig u-boot-nand.imx
V2.7 2016.11-toradex colibri_imx7_defconfig u-boot-nand.imx
iMX7 Linux Kernel Versions
V2.6 Alpha 1 toradex_imx_3.14.52_1.1.0_ga colibri_imx7_defconfig imx7d-colibri.dtb
imx7s-colibri.dtb
V2.6 Beta 2 toradex_imx_4.1.15_1.0.0_ga colibri_imx7_defconfig imx7d-colibri-eval-v3.dtb
imx7s-colibri-eval-v3.dtb
V2.7 toradex_4.1-2.0.x-imx colibri_imx7_defconfig imx7d-colibri-eval-v3.dtb
Toolchain
Toolchain for Hard Float Calling Convention
Beginning with image 2.7b2, as part of our OpenEmbedded Morty update we transitioned to using version 6.2 of the gcc compiler. Linaro releases well tested binary toolchains which can be used to cross compile software for our modules (choose gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf.tar.xz):
https://releases.linaro.org/components/toolchain/binaries/6.2-2016.11/arm-linux-gnueabihf/
Beginning with image V2.6, as part of our OpenEmbedded Jethro update we transitioned to using version 5.2 of the gcc compiler. Linaro releases well tested binary toolchains which can be used to cross compile software for our modules (choose gcc-linaro-5.2-2015.11-2-x86_64_arm-linux-gnueabihf.tar.xz):
https://releases.linaro.org/components/toolchain/binaries/5.2-2015.11-2/arm-linux-gnueabihf/
Beginning with image V2.0, we transitioned to using the hard-float ABI:
http://releases.linaro.org/14.11/components/toolchain/binaries/
Note: Since the 14.11 release Linaro only provides x86_64 toolchains. If you use 32-bit Linux on your host machine (check using uname -m), you can still download the older 14.09 release which is still 32-bit:
http://releases.linaro.org/14.09/components/toolchain/binaries/
To install the toolchain on your host machine, unpack the tar.xz file:
cd
wget -c https://releases.linaro.org/components/toolchain/binaries/5.2-2015.11-2/arm-linux-gnueabihf/gcc-linaro-5.2-2015.11-2-x86_64_arm-linux-gnueabihf.tar.xz
tar xvf gcc-linaro-5.2-2015.11-2-x86_64_arm-linux-gnueabihf.tar.xz
ln -s gcc-linaro-5.2-2015.11-2-x86_64_arm-linux-gnueabihf gcc-linaro
The U-Boot and Linux makefiles use the environment variables ARCH/CROSS_COMPILE to configure and call the compiler correctly. Therefore, these environment variables must be exported in any shell instance that will run configure/compile commands to build U-Boot or Linux for the target module.
export ARCH=arm
export PATH=~/gcc-linaro/bin/:$PATH
export CROSS_COMPILE=arm-linux-gnueabihf-
Alternatively, if you did an OpenEmbedded build, you can use the toolchain generated as part of the build by entering the following:
export ARCH=arm
export PATH=~/oe-core/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:~/oe-core/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi/:$PATH
export CROSS_COMPILE=arm-angstrom-linux-gnueabi-
Note: In BSP releases prior to V2.6.1 tmp-glibc was actually known as out-(e)glibc.
You can put those commands into a file and source that file to export it more easily:
echo "export ARCH=arm" >> ~/export_compiler
echo "export PATH=~/gcc-linaro/bin/:$PATH" >> ~/export_compiler
echo "export CROSS_COMPILE=arm-linux-gnueabihf-" >> ~/export_compiler
source ~/export_compiler
Linux Image / Flashing Tools
The following instructions expect the latest Linux image to be extracted on your host machine.
The latest Linux images are available at: http://files.toradex.com/Colibri/Linux/Images
As an example we'll use Colibri_T20_LinuxImageV2.3_20150320.tar.bz2 which will create a directory Colibri_T20_LinuxImageV2.3.
To download and extract the image:
cd
wget http://files.toradex.com/Colibri/Linux/Images/Colibri_T20_LinuxImageV2.3_20150320.tar.bz2
sudo tar xjvf Colibri_T20_LinuxImageV2.3_20150320.tar.bz2
DTC
U-Boot compilation for some modules needs a device tree compiler (DTC) of version 1.3 or higher to be installed and executable. Ubuntu 12.04 LTS (Precise Pangolin) and later provide a version which is recent enough:
sudo apt-get install device-tree-compiler
To check the version:
$ dtc -v
Version: DTC 1.3.0
If you need to build a newer version, you can get the latest version (DTC 1.4.1 at the time of writing) from source:
git clone git://git.kernel.org/pub/scm/utils/dtc/dtc.git -b v1.4.1
cd dtc/
make
export PATH=$HOME/dtc/:$PATH
Alternatively, one can use the tools built with an OpenEmbedded build. See the toolchain chapter above.
U-Boot Tools
The uImage target of the Linux kernel compilation needs a recent mkimage tool which is actually built during U-Boot compilation as explained further below. Ensure that one is included in PATH:
export PATH=$PATH:$HOME/u-boot-toradex/tools
Alternatively, one can simply install the Fedora package uboot-tools:
sudo dnf install uboot-tools
respectively the Debian/Ubuntu package u-boot-tools:
sudo apt-get install u-boot-tools
Other Build Host Tools
You need some basic build tools to compile the kernel. Most are likely part of your distro's standard install.
For Fedora:
sudo dnf install bc git ncurses-devel lzop make
For Debian/Ubuntu:
sudo apt-get install bc git libncurses5-dev lzop make
U-Boot
For detailed information about which branch, configuration or binary to use, please consult the image version tables provided at the top of the article.
Source
Obtain the U-Boot source code using Git:
cd
git clone -b 2016.11-toradex git://git.toradex.com/u-boot-toradex.git
cd u-boot-toradex
Note: The 2016.11-toradex branch is used as an example. For detailed information about which branch to use, please consult the image version tables provided at the top of the article.
Configuration
Our latest board configurations are called as follows:
Tegra based modules
  • apalis_t30_defconfig
  • apalis-tk1_defconfig
  • colibri_t20_defconfig
  • colibri_t30_defconfig
Vybrid based modules
All Vybrid based modules share their configuration.
  • colibri_vf_defconfig
i.MX 6 based modules
  • apalis_imx6_defconfig
  • apalis_imx6_nospl_it_defconfig
  • colibri_imx6_defconfig
  • colibri_imx6_nospl_defconfig
i.MX 7 based modules
  • colibri_imx7_defconfig
For detailed information about which configuration to use, please consult the image version tables provided at the top of the article.
Ensure the environment is configured for cross compilation as explained in the toolchain chapter. Then choose one of those configurations and load it:
make colibri_t20_config
Compilation
The following is the procedure to compile the boot loader.
make -j3 2>&1 | tee build.log
When using the cross compiler built by a OpenEmbedded build of our BSP V2.5 or later, the compiler might have an error during linking
arm-angstrom-linux-gnueabi-ld.bfd: cannot find -lgcc
make[2]: *** [examples/standalone/hello_world] Error 1
make[1]: *** [examples/standalone] Error 2
make: *** [examples] Error 2
The new cross compiler does not have a hard-coded default sysroot and hence needs the sysroot to be specified explicitly:
make CC='arm-angstrom-linux-gnueabi-gcc  --sysroot=${HOME}/oe-core/build/out-glibc/sysroots/colibri-vf'
Update
Colibri T20
Image V2.3 & Older
The following procedure is to flash just the new boot loader (assumes target is already in recovery mode):
cd ~/Colibri_T20_LinuxImageV2.3/colibri-t20_bin
cp ~/u-boot-toradex/u-boot.bin ./u-boot-custom.bin
ln -fs u-boot-custom.bin u-boot.bin
cd ..
./update.sh -r 512 -u -v V1_2
Note: This example performs an update for the Colibri T20 512MB V1_2. Enter the update parameters according to the Colibri T20 version.
Image V2.4 & Newer
Refer to the Tegra based modules section below for the T20 U-Boot update procedure of V2.4+ images.
Tegra based modules (T20: Image V2.4+)
Replace the existing u-boot-dtb-tegra.bin in the extracted BSP package.
cd ~/Apalis_T30_LinuxImageV2.3/apalis-t30_bin
cp ~/u-boot-toradex/u-boot-dtb-tegra.bin ./u-boot-dtb-tegra-custom.bin
ln -fs u-boot-dtb-tegra-custom.bin u-boot-dtb-tegra.bin
cd ..
Prepare an SD card as described in the Flashing Embedded Linux to Tegra Modules article.
Boot the module to the U-Boot prompt and update U-Boot:
run setupdate
run update_uboot
Note: Refer to the Txx Recovery Mode article if the module is not able to boot into U-Boot.
After the update, reset or power cycle to execute the new U-Boot.
Vybrid, i.MX 6 & i.MX 7 Based Modules
Prepare an SD card as described in the articles below (according to the module of interest):
Flashing Embedded Linux to iMX6 Modules
Flashing Embedded Linux to iMX7 Modules
Flashing Embedded Linux to Vybrid Modules
Replace the existing U-Boot binary in the first partition of your SD card.
eMMC Based Modules (i.MX 6)
Starting with image V2.7 use SPL & u-boot.img to replace SPL and u-boot.imx-spl on the update SD card.
For older images use u-boot.imx to replace u-boot.imx, or if you built for a Apalis iMX6 IT replace u-boot.imx-it or u-boot-it.imx.
Raw NAND Based Systems (Vybrid and i.MX 7)
Use u-boot-nand.imx for raw NAND based systems (Vybrid and i.MX 7).
cp ~/u-boot-toradex/u-boot.imx /media/<path-to-partition-1>/<board>/
run setupdate
run update_uboot
Note: Refer to the Flashing Embedded Linux articles above if the module is not able to boot into U-Boot.
Note: This does not reset the U-Boot environment to the new default values.
Note: If the module fails to boot Linux after updating U-Boot, consider resetting the U-Boot environment.
To reset the environment to the updated default environment, enter the following from the command line of the updated U-Boot:
env default -a
saveenv
Note: Images V2.6 and older: On the Colibri iMX6DL the command patch_ddr_size must be executed after flashing U-Boot which is already taken care of by the update_uboot command given above.
Linux Kernel
Kernel Source
Obtain the kernel source code using Git:
git clone -b tegra git://git.toradex.com/linux-toradex.git
cd linux-toradex
Note: The tegra branch is used as an example. For detailed information about which branch to use, please consult the image version tables provided at the top of the article.
Our kernel tree provides default kernel configurations for our modules:
Tegra Based Modules
Set the default configuration:
make colibri_t20_defconfig
At this point one may alter the kernel configuration by either editing .config directly (e.g. setting CONFIG_* to either =y or =m aka as module) or use one of the kernel configuration utilities included, e.g.
make nconfig
Kernel Compilation
Depending on the module, different kernel image types are used. Furthermore, some kernels require a device tree to describe the system's hardware (see Device Tree Customization for details).
Our kernel configurations build some drivers as kernel modules.
To assure module compatibility the kernel refuses to load modules with a 'vermagic' string which does not match its own, on top of that the modules are stored under a directory named after the version string.
Thus one usually needs to compile and deploy the kernel modules together with the kernel in order to use them.
Tegra T20/T30 Based Modules (Colibri T20, Apalis/Colibri T30)
To compile the kernel:
make -j3 uImage 2>&1 | tee build.log
Using a GCC 4.8 or newer toolchain (e.g. from oe_sysroot) with the gold linker may cause the following issue:
arm-angstrom-linux-gnueabi-ld: error: arch/arm/boot/compressed/piggy.gzip.o: unknown CPU architecture
arm-angstrom-linux-gnueabi-ld: error: arch/arm/boot/compressed/lib1funcs.o: unknown CPU architecture
This is a known issue with older kernel versions and the gold linker (see this message by the gold creator). The recommended solution is to just revert to using the regular bfd linker as follows:
make -j3 uImage LD=${CROSS_COMPILE}ld.bfd | tee build.log
Tegra K1 Based Modules (Apalis TK1)
Valid device trees:
  • tegra124-apalis-eval.dtb
To compile the kernel & device tree:
make -j3 uImage LOADADDR=0x80008000 2>&1 | tee build.log
make tegra124-apalis-eval.dtb
Vybrid Based Modules (Colibri VFXX)
Since V2.3 Beta 3, the boot loader expects the kernel to be located within the root file system and in the zImage format.
Since V2.3 Beta 5 (i.e. branch colibri_vf_3.18) a device tree must additionally be built from the kernel sources.
Since V2.6 Beta 2, the boot loader expects the kernel/dtb to be located in their own static UBI volue and in the zImage format.
Valid device trees:
  • vf500-colibri-eval-v3.dtb
  • vf610-colibri-eval-v3.dtb
make -j3 zImage | tee build.log
make vf610-colibri-eval-v3.dtb
The Linux kernel for our Vybrid based modules can show linking issues when using the gold linker (which is the default linker of the toolchain created by the Ångström/OpenEmbedded distribution):
arm-angstrom-linux-gnueabi-ld: --pic-veneer: unknown option
arm-angstrom-linux-gnueabi-ld: use the --help option for usage information
make -j3 zImage LD=${CROSS_COMPILE}ld.bfd | tee build.log
Starting with Apalis iMX6 Image V2.3 Beta 1 and for all Colibri iMX6 kernels some additional parameters are required to compile the kernel plus a device tree is built from the kernel sources.
Valid device trees:
  • imx6q-apalis-eval.dtb
  • imx6q-apalis-eval_v1_0.dtb
  • imx6q-apalis_v1_0-eval.dtb
  • imx6q-apalis_v1_0-ixora.dtb
  • imx6dl-colibri-eval-v3.dtb
  • imx6dl-colibri-cam-eval-v3.dtb
make -j3 uImage LOADADDR=10008000 2>&1 | tee build.log
make imx6q-apalis-eval.dtb
i.MX 7 Based Modules (Colibri iMX7S/iMX7D)
Valid device trees:
  • imx7s-colibri-eval-v3.dtb
  • imx7d-colibri-eval-v3.dtb
make -j3 zImage 2>&1 | tee build.log
make imx7d-colibri-eval-v3.dtb
The Linux kernel for our i.MX7 based modules can show linking issues when using the gold linker (which is the default linker of the toolchain created by the Ångström/OpenEmbedded distribution):
Kernel Module Compilation, all Modules
To compile the kernel modules as configured in .config. (e.g. in .config - all CONFIG_* with =m):
make -j3 modules
Kernel Update
Colibri T20
Image V2.3 & Older
To flash just the new kernel (assumes the target is already in recovery mode):
cp ~/linux-toradex/arch/arm/boot/uImage ./uImage-custom
ln -fs uImage-custom uImage
cd ..
./update.sh -k -r 512 -v V1_2
Image V2.4 & Newer
Replace the existing zImage in the extracted BSP package:
cd ~/Colibri_T20_LinuxImageV2.4/rootfs/boot
cp ~/linux-toradex/arch/arm/boot/zImage ./zImage-custom
ln -fs /boot/zImage-custom zImage
cd ../..
Prepare an SD card as described in at: Flashing Embedded Linux to Tegra Modules
Boot the module to the U-Boot prompt and update the whole root file system which contains the new kernel in its /boot folder:
run setupdate
run update_rootfs
After the update, reset or power cycle to boot the updated kernel.
Image V2.6 Beta 2 & Newer
Prepare an SD card as described in at: Flashing Embedded Linux to Tegra Modules Then, copy the Kernel directly onto the SD card:
cp ~/linux-toradex/arch/arm/boot/zImage /media/<path-to-partition-1>/colibri-t20/
Boot the module to the U-Boot prompt and update the kernel in its UBI volume:
run setupdate
run prepare_ubi
run update_kernel
Vybrid Based Modules (V2.5 and older)
Replace the existing zImage & device trees in the extracted BSP package:
cd ~/Colibri_VF_LinuxImageV2.3/rootfs/boot
cp ~/linux-toradex/arch/arm/boot/dts/vf500-colibri-eval-v3.dtb ./vf500-custom.dtb
cp ~/linux-toradex/arch/arm/boot/dts/vf610-colibri-eval-v3.dtb ./vf610-custom.dtb
ln -fs /boot/vf500-custom.dtb vf500-colibri-eval-v3.dtb
ln -fs /boot/vf610-custom.dtb vf610-colibri-eval-v3.dtb
cd ../..
Prepare an SD card as described in Flashing Embedded Linux to Vybrid Modules.
run setupdate
run update_rootfs
i.MX 7 and Vybrid Based Modules (V2.6 and newer)
Prepare the SD card as described in Flashing Embedded Linux to Vybrid Modules resp. Flashing Embedded Linux to iMX7 Modules. Then, copy the Kernel and device tree directly onto the SD card (replace <board> with colibri-vf or colibri-imx7):
cp ~/linux-toradex/arch/arm/boot/zImage /media/<path-to-partition-1>/<board>/
cp ~/linux-toradex/arch/arm/boot/dts/vf500-colibri-eval-v3.dtb /media/<path-to-partition-1>/<board>/
cp ~/linux-toradex/arch/arm/boot/dts/vf610-colibri-eval-v3.dtb /media/<path-to-partition-1>/<board>/
run setupdate
run prepare_ubi
run update_fdt
run update_kernel
T30, TK1 & i.MX 6 Based Modules
Prepare an SD card as described in:
Replace the existing uImage and, if applicable, the device tree in the first partition of your SD card (replace <board> with apalis-t30, apalis-tk1, colibri-t30, apalis-imx6, or colibri-imx6).
cp ~/linux-toradex/arch/arm/boot/uImage /media/<path-to-partition-1>/<board>/
cp ~/linux-toradex/arch/arm/boot/dts/imx6q-apalis-eval.dtb /media/<path-to-partition-1>/<board>/
Boot the module to the U-Boot prompt and update the kernel and, if applicable, the device tree:
run setupdate
run update_kernel
run update_fdt
Kernel Module Deployment
If kernel modules were compiled, they may be deployed as follows:
sudo -E make INSTALL_MOD_PATH=<path-to-rootfs>/ modules_install
Where <path-to-rootfs>/ either points to:
  • the rootfs folder of the previously extracted update package in which case one has to remember to re-generate and re-flash the root file system image afterwards
  • directly to a NFS rootfs location
  • a temporary folder, after which the kernel modules must be separately installed on the target as follows:
    cd <path-to-rootfs>/
    tar cjvf kernel-modules.tar.bz2 lib/modules/*
    #copy the file to the target
    #extract on the target as follows:
    cd /
    tar xjvf kernel-modules.tar.bz2
    Alternatively in one command copying through ssh (using scp for the whole installation folder does not work well since the module tree contains a symlink to the kernel sources):
    tar -cf - . | ssh root@192.168.10.70 'cd / && tar -xf -'
Note: The kernel and any kernel modules must to be deployed as matching versions.
Note: Run depmod on the target after deploying new or changed kernel modules.
