CANLib-SJ1000 API
Library to interface with a SJA1000 Stand-alone CAN Controller.
Data Structures
struct  _CAN_MESSAGE_EXT
Macros
#define  STANDARD  0x00
#define  EXTENDED  0x01
#define  CAN_VER_MAJ  3
Version Info.
#define  CAN_VER_MIN  3
#define  CAN_VER_BUILD  1
Functions
void  CANGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
DWORD  InitSJA1000 (DWORD device, DWORD base, DWORD interruptGPIO, DWORD waterMark, DWORD bufferSize)
void  DeInitSJA1000 (DWORD device)
void  CANReInitialise (DWORD device)
BOOL  CanWriteDescriptor (DWORD device, DWORD descr, DWORD mask)
DWORD  CanReadDescriptor (DWORD device)
DWORD  CanReadMask (DWORD device)
BOOL  CanReset (DWORD device)
BOOL  CanSetBaudrate (DWORD device, DWORD baud)
BOOL  CanTransmitMessage (DWORD device, CAN_MESSAGE_EXT *msg)
DWORD  CANReceiveMessages (DWORD device, CAN_MESSAGE_EXT *msg, DWORD numberOfMsg, DWORD timeout)
DWORD  GetCanStatus (DWORD device)
void  PrintMessage (CAN_MESSAGE_EXT *msg)
Version Info.
Typedef Documentation
Structure for extended frame types (29 Bit adress-range). Set "frametype" to "STANDARD" or "EXTENDED". The RTR (Remote-Frame) flag and data length code are now in seperate variables for better hardware independence !
Function Documentation
void CANGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Returns the library version.
Parameters:
[out] VersionMajor Returns the major version number. Set this parameter to NULL if not required.
[out] VersionMinor Returns the minor version number. Set this parameter to NULL if not required.
[out] Build Returns the build number. Set this parameter to NULL if not required.
Return values:
NA
DWORD CanReadDescriptor ( DWORD  device )
Read the Acceptance Code
Parameters:
[in] device CAN Device ID
Return values:
Acceptance Code
DWORD CanReadMask ( DWORD  device )
Read the Mask
Parameters:
Return values:
Mask
DWORD CANReceiveMessages ( DWORD  device,
CAN_MESSAGE_EXT msg,
DWORD  numberOfMsg,
DWORD  timeout
Receive CAN messages
Parameters:
[out] msg pointer to CAN_MESSAGE_EXT array sufficient to hold numberOfMsg messages
[in] numberOfMsg Number of messages to wait for
[in] timeout Timeout value in milliseconds, use INFINITE to wait forever
Return values:
Number messages received, 0 = timeout
void CANReInitialise ( DWORD  device )
Reinitialise the CAN Controller/n Clears any unserviced interrupts.
Parameters:
Return values:
NA
BOOL CanReset ( DWORD  device )
Reset the CanChip and clear all buffers
Parameters:
Return values:
TRUE,: Success, FALSE: Error
BOOL CanSetBaudrate ( DWORD  device,
DWORD  baud
Set the Baudrate./n 1000, 800, 500, 250, 125, 100, 50, 20, 10 kBaud./n All other settings set the baud to 125 kBaud
Parameters:
[in] baud Baudrate
Return values:
BOOL CanTransmitMessage ( DWORD  device,
CAN_MESSAGE_EXT msg
Send a CAN Message
Parameters:
[in] msg Pointer to a CAN message structure
Return values:
BOOL CanWriteDescriptor ( DWORD  device,
DWORD  descr,
DWORD  mask
Write the Acceptance Code and Mask Registers./n Library is running in dual mode (AFM =0)./n For more information see the SJA1000 documentation.
Parameters:
[in] descr 32 bit acceptance code
[in] mask 32 bit acceptance mask
Return values:
void DeInitSJA1000 ( DWORD  device )
Release CAN Controller
Parameters:
Return values:
NA
DWORD GetCanStatus ( DWORD  device )
Return the CAN Status
Parameters:
Return values:
0 = OK/n Test with CAN_ERROR and CAN_OVERRUN_HW Constants
DWORD InitSJA1000 ( DWORD  device,
DWORD  base,
DWORD  waterMark,
DWORD  bufferSize
Initialise CAN Controller
Parameters:
[in] base SJA1000 Chip Base Address
[in] interruptGPIO GPIO Number of the interrupt from the SJA1000
[in] waterMark Number of messages received before the library signals reception of messages.
[in] bufferSize Size of the receive buffer in CAN_MESSAGE_EXT messages
Return values:
0 = Success
1 = SoC not supported
-1 = Could not create ISR_CoM struct
-2 = Could not map Chip Base Address
-4 = Could not create Mutex
-5 = Could not enter reset mode
-6 = Could not enter normal mode
-7 = Could not create receive buffer
-8 = Could not create Interrupt Service Thread
-9 = Could not initialise GPIO
void PrintMessage ( CAN_MESSAGE_EXT msg )
Print the contents of the supplied CAN_MESSAGE_EXT message
Parameters:
[in] msg Pointer to a CAN_MESSAGE_EXT instance
Return values:
NA
