Chiptronic Resistive Touch Display 7"
Tags
Welcome to the product page for the Chiptronic Resistive Touch Display 7".
Chiptronic Resistive Touch Display is an alternative display option to the EDT display. It was developed to be 100% hardware compatible with the EDT Display.
This page contains a variety of information related to the Chiptronic Resistive Touch Display 7" and is intended to provide a single point of access for all information you need. Cables are included with the display and allow an easy connection to Toradex carrier boards supporting the Unified Display Interface.
Getting Started
Have a look at the following article: Installing Chiptronic Resistive Touch Display.
Main Features
The Chiptronic Resistive Touch Display 7" provides the following features:
  • Display 7" with 800x480px
  • 18-bit RGB
  • 4-Wire Resistive Touch
  • Unified TFT Interface from EDT for easy connection to Toradex carrier boards
  • 250mm FFC cable to connect to a carrier board
  • No special drivers required
Datasheets
Product Datasheet:
Related Products
Compatible Carrier Boards
Compatible Modules
Windows
All Tegra and NXP Toradex modules.
Linux
All NXP Toradex modules.
