Clear command
The Clear command is a CommandPrompt command. It removes an additional configuration entry from the Config Block. If an additional Configuration entry has been set and saved to the Config Block, it can be removed by calling the clear command. After removing the additional Configuration entry, the Bootloader will use the predefined default configuration.
Syntax: To remove an additional configuration entry for a specific item, type: clear
Example: Removing an additional configuration entry for the dbg item.
>clear dbg
