Cloud Rds Lib API
Contains function declarations to be used to access MySQL Server. Target Modules are Colibri Modules [PXAxxx, Tegra T20, Tegra T30], WinCE 6.0 / 7.0 . More...
Data Structures
struct  mysql
Macros
#define  MYSQL_ERROR_STRING_LENGTH  256
#define  MYSQL_INSTANCE_ENDPOINT_LENGTH  64
#define  MYSQL_USER_NAME_LENGTH  64
#define  MYSQL_USER_PASSWORD_LENGTH  64
#define  MYSQL_QUERY_STRING_LENGTH  256
#define  FILENAME_BUFFER_SIZE  128
#define  DATA_SEND_BUFFER_SIZE  1024
#define  DATA_RECEIVE_BUFFER_SIZE  1024
Typedefs
typedef struct mysql MYSQL
Functions
BOOL  MySqlOpen (MYSQL *mysqlAccount, const CHAR *sqlInstanceEndpoint, const CHAR *sqlUserName, const CHAR *sqlUserPassword)
BOOL  MySqlConnect (MYSQL mysqlAccount, WORD mysqlPortNumber)
BOOL  MySqlConnectWithSsl (MYSQL mysqlAccount, WORD mysqlPortNumber)
BOOL  MySqlRowQuery (MYSQL mysqlAccount, const CHAR *mysqlQuery, const CHAR *resultFilePath, DWORD *columnsInTable)
BOOL  MySqlClose (MYSQL *mysqlAccount)
BOOL  MySqlQuit (MYSQL mysqlAccount)
BOOL  MySqlInitDb (MYSQL mysqlAccount, const CHAR *schemaName)
BOOL  MySqlListFields (MYSQL mysqlAccount, const CHAR *tableName, const CHAR *resultFilePath, DWORD *columnsInTable)
BOOL  MySqlCreateDb (MYSQL mysqlAccount, const CHAR *createDbStatement)
BOOL  MySqlDropDb (MYSQL mysqlAccount, const CHAR *schemaName)
BOOL  MySqlPing (MYSQL mysqlAccount)
BOOL  MySqlUpdateQuery (MYSQL mysqlAccount, const CHAR *updateQuery)
BOOL  MySqlInsertQuery (MYSQL mysqlAccount, const CHAR *insertQuery)
BOOL  MySqlDeleteQuery (MYSQL mysqlAccount, const CHAR *deleteQuery)
DWORD  MySqlAffectedRows (MYSQL mysqlAccount)
BOOL  MySqlAlterQuery (MYSQL mysqlAccount, const CHAR *alterQuery)
BOOL  MySqlGetNumberOfRows (MYSQL mysqlAccount, const CHAR *tableName, DWORD *numberOfRows)
BOOL  MySqlListTables (MYSQL mysqlAccount, const CHAR *dbInstanceName, const CHAR *filePath)
void  MySqlClearError (MYSQL mysqlAccount)
BOOL  MySqlCreateViewQuery (MYSQL mysqlAccount, const CHAR *viewQuery)
BOOL  MySqlPrepareStatementQuery (MYSQL mysqlAccount, const CHAR *prepareQuery, DWORD *statementId, DWORD *numberOfParamters)
BOOL  MySqlPrepareSendLongData (MYSQL mysqlAccount, DWORD statementId, DWORD parameterId, const CHAR *dataForPrepareQuery)
BOOL  MySqlStatementExecute (MYSQL mysqlAccount, DWORD statementId, DWORD numberOfParameters, DWORD optionFlags)
BOOL  MySqlPrepareStatementClose (MYSQL mysqlAccount, DWORD statementId)
BOOL  MySqlPrepareStatementReset (MYSQL mysqlAccount, DWORD statementId)
BOOL  MySqlSetMultiStatementOption (MYSQL mysqlAccount, BOOL multiStatementOn)
BOOL  MySqlStatementFetch (MYSQL mysqlAccount, DWORD statementId)
Detailed Description
Contains function declarations to be used to access MySQL Server. Target Modules are Colibri Modules [PXAxxx, Tegra T20, Tergra T30], WinCE 6.0 / 7.0 .
Author:
Rev:
Date:
2014-01-08 10:00:00 +0530 (Wed, 08 Jan 2014)
Function Documentation
DWORD MySqlAffectedRows ( MYSQL mysqlAccount )
Returns the number of rows changed, deleted, or inserted
Parameters
[in] mysqlAccount Handle returned by call to MySqlOpen()
Return values
Number of rows affected Contains valid value only after successful calls to MySqlUpdate(), MySqlInsert() or MySqlDelete()
BOOL MySqlAlterQuery ( MYSQL mysqlAccount,
const CHAR *  alterQuery
Add, Delete or Modify columns in the table
Parameters
[in] alterQuery MySQL ALTER query statement For example: "ALTER TABLE mysqldb.TestDbTable ADD Column3 int" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUE Success
FALSE See WSAGetLastError() and GetLastError()
void MySqlClearError ( MYSQL mysqlAccount )
Clears the MySQL error number and error string
Parameters
Return values
BOOL MySqlClose ( MYSQL mysqlAccount )
Close the handle for the MySQL connection
Parameters
Return values
TRUE Success
BOOL MySqlConnect ( MYSQL mysqlAccount,
Opens a connection to the Amazon RDS MySQL instance
Parameters
[in] mysqlPortNumber Port number on which to communicate with the Amazon RDS MySQL instance If specified as 0, default MySQL port number of 3306 will be used
Return values
TRUE Success
FALSE See GetLastError() and WSAGetLastError()
BOOL MySqlConnectWithSsl ( MYSQL mysqlAccount,
Open a conenction to the Amazon RDS MySQL instance using SSL
Parameters
Return values
TRUE Success
BOOL MySqlCreateDb ( MYSQL mysqlAccount,
const CHAR *  createDbStatement
Create a new schema/database
Parameters
[in] createDbStatement MySQL CREATE_DATABASE statement Example: "CREATE TABLE mysqldb.TestDbTable(Column1 int primary key auto_increment, Column2 int)" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
Return values
TRUE Success
BOOL MySqlCreateViewQuery ( MYSQL mysqlAccount,
const CHAR *  viewQuery
Create views for the database table
Parameters
[in] viewQuery MySQL View query statement Example: CREATE VIEW view_name AS SELECT column_name(s) FROM table_name WHERE condition
Return values
TRUE Success
FALSE See WSAGetLastError() and GetLastError() To be implemented
BOOL MySqlDeleteQuery ( MYSQL mysqlAccount,
const CHAR *  deleteQuery
Delete data in the table
Parameters
[in] deleteQuery MySQL DELETE query statement For example: "DELETE FROM mysqldb.TestDbTable WHERE Column1 = 900" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUE Success
BOOL MySqlDropDb ( MYSQL mysqlAccount,
const CHAR *  schemaName
Drop a schema/database
Parameters
[in] schemaName Name of the schema/database to drop Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
Return values
TRUE Success
BOOL MySqlGetNumberOfRows ( MYSQL mysqlAccount,
const CHAR *  tableName,
DWORD *  numberOfRows
Get the number of records in the table
Parameters
[in] tableName Table name for which number of records has to be retrieved Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
[out] numberOfRows Number of records in the table
Return values
TRUE Success
BOOL MySqlInitDb ( MYSQL mysqlAccount,
Change the default schema of the connection
Parameters
[in] schemaName Name of the schema to change to
Return values
TRUE Success
BOOL MySqlInsertQuery ( MYSQL mysqlAccount,
const CHAR *  insertQuery
Insert data in the table
Parameters
[in] insertQuery MySQL INSERT query statement For example: "INSERT INTO mysqldb.TestDbTable (Column1, Column2) VALUES(900, 1000)" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUE Success
BOOL MySqlListFields ( MYSQL mysqlAccount,
const CHAR *  resultFilePath,
DWORD *  columnsInTable
Get the column definitions of a table
Parameters
[in] tableName Table name for which column definition has to be retrieved Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
[in] resultFilePath Pointer to the local file path string in which result will be stored
[out] columnsInTable Number of columns in the table
Return values
TRUE Success
FALSE See WSAGetLastError() and GetLastError() Data will be in the following format: Field Type Null Key Default Extra
BOOL MySqlListTables ( MYSQL mysqlAccount,
const CHAR *  dbInstanceName,
const CHAR *  filePath
List tables in the database
Parameters
[in] dbInstanceName Name of the MySQL database instance
[in] filePath Pointer to the local file path string in which result will be stored
Return values
TRUE Success
BOOL MySqlOpen ( MYSQL mysqlAccount,
const CHAR *  sqlInstanceEndpoint,
const CHAR *  sqlUserName,
const CHAR *  sqlUserPassword
Opens a handle for the MySQL connection
Parameters
[out] mysqlAccount Amazon RDS MySQL instance account handle
[in] sqlInstanceEndpoint Endpoint address of the Amazon RDS MySQL instance
[in] sqlUserName User name of the Amazon RDS MySQL instance
[in] sqlUserPassword Password for the Amazon RDS MySQL instance
Return values
TRUE Success
BOOL MySqlPing ( MYSQL mysqlAccount )
Check if the server connection is alive
Parameters
Return values
TRUE Success
BOOL MySqlPrepareSendLongData ( MYSQL mysqlAccount,
DWORD  statementId,
DWORD  parameterId,
const CHAR *  dataForPrepareQuery
Send data for a prepared statement
Parameters
[in] statementId Statement Id returned from a previous call to MySqlPrepareQuery()
[in] parameterId Parameter Id for the data
[in] dataForPrepareQuery Data for the prepare query
Return values
TRUE Success
FALSE See WSAGetLastError() and GetLastError() Must be called before MySqlPrepareStatementExecute() To be implemented
BOOL MySqlPrepareStatementClose ( MYSQL mysqlAccount,
DWORD  statementId
Deallocates a prepare statement query
Parameters
[in] statementId Statement Id returned by call to MySqlPrepareQuery()
Return values
TRUE Success
BOOL MySqlPrepareStatementQuery ( MYSQL mysqlAccount,
const CHAR *  prepareQuery,
DWORD *  statementId,
DWORD *  numberOfParamters
Create a prepared statement
Parameters
[in] preparQuery MySQL prepare query statement
[out] statementId Statement ID use to identify the prepare statement
[out] numberOfParameters Number of Parameters
Return values
TRUE Success
BOOL MySqlPrepareStatementReset ( MYSQL mysqlAccount,
DWORD  statementId
Reset the data of a prepared statement which was accumulated with MySqlPrepareSendLongData()
Parameters
Return values
TRUE Success
BOOL MySqlQuit ( MYSQL mysqlAccount )
Close the connection to the Amazon RDS MySQL instance
Parameters
Return values
TRUE Success
BOOL MySqlRowQuery ( MYSQL mysqlAccount,
const CHAR *  mysqlQuery,
Query the rows of Amazon RDS MySQL instance
Parameters
[in] mysqlQuery MySQL SELECT Query statement For example: "SELECT * FROM mysqldb.TestDbTable" where mysqldb is the schema/database name and TestDbTable is the MySQL table name
[in] resultFilePath Pointer to the local file path string in which result of MySQL query will be stored
Return values
TRUE Success
BOOL MySqlSetMultiStatementOption ( MYSQL mysqlAccount,
Set Multi statement operation
Parameters
[in] multiStatementOn TRUE: Multi statements ON, FALSE: Multi statements OFF
Return values
TRUE Success
BOOL MySqlStatementExecute ( MYSQL mysqlAccount,
DWORD  statementId,
DWORD  optionFlags
Execute a statement query
Parameters
[in] numberOfParameters Number of parameters returned by call to MySqlPrepareQuery()
[in] optionFlags Option flags for prepare statment execution
Return values
TRUE Success
BOOL MySqlStatementFetch ( MYSQL mysqlAccount,
DWORD  statementId
Fetch a row from a existing resultset after a COM_STMT_EXECUTE.
Parameters
[in] statementId Statement Id of a stored procedure
Return values
TRUE Success
BOOL MySqlUpdateQuery ( MYSQL mysqlAccount,
const CHAR *  updateQuery
Update data in the table
Parameters
[in] updateQuery MySQL UPDATE query statement For example: "UPDATE mysqldb.TestDbTable SET Column2 = 1001 WHERE Column1 = 900" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUE Success
