Cloud Sqs Lib API
Contains function declarations to be used to access AWS Cloud SQS Services Colibri Modules [PXAxxx, Tegra T20], WinCE 6.0 / 7.0 . More...
Macros
#define  AWS_SQS_ACCESS_ID_MAX_LENGTH  20
AWS Account ID string Length.
#define  AWS_SQS_SECRET_KEY_MAX_LENGTH  40
AWS Account Secret Kay String Length.
#define  AWS_SQS_OWNER_ID_MAX_LENGTH  12
AWS Account Owner ID String Length.
#define  AWS_SQS_SIGNATURE_HASH_LENGTH  32
#define  AWS_SQS_SIGNATURE_STRING_LENGTH  44
#define  SQS_QUEUE_NAME_MAX_LENGTH  80
#define  SQS_MAX_TIME_STRING_LENGTH  24
#define  SQS_MESSAGE_ID_LENGTH  100
#define  SQS_MESSAGE_DELAY_SECONDS_MAX  900
#define  SQS_MESSAGE_BODY_MAX_LENGTH  (64 * 1024)
#define  SQS_RECIEPT_HANDLE_MAX_LENGTH  1024
#define  SQS_ATTRIBUTE_NAME_BUFFER_SIZE  24
#define  SQS_HTTP_RESPONSE_DATA_BUFFER_SMALL  (2 * 1024)
#define  SQS_HTTP_RESPONSE_DATA_BUFFER_LARGE  (4 * 1024)
#define  SQS_HTTP_ARGUMENT_BUFFER_SMALL  (2 * 1024)
#define  SQS_HTTP_ARGUMENT_BUFFER_LARGE  (4 * 1024)
#define  SQS_STRING_TO_SIGN_BUFFER_SMALL  (2 * 1024)
#define  SQS_STRING_TO_SIGN_BUFFER_LARGE  (4 * 1024)
#define  URL_ENCODED_RECEIPT_HANDLE_BUFFER  (4 * 1024)
#define  SQS_HANDLE_MEMORY_ALLOCATION  (4 * 5)
#define  QUEUE_ATTRIBUTE_VISIBILITY_TIMEOUT  1
#define  QUEUE_ATTRIBUTE_MAXIMUM_MESSAGE_SIZE  2
#define  QUEUE_ATTRIBUTE_MESSAGE_RETENTION_PERIOD  3
#define  QUEUE_ATTRIBUTE_DELAY_SECONDS  4
Functions
BOOL  SqsOpenQueue (char *accessID, char *secretKey, char *path, char *accountOwnerID, char *queueName, HSQS *sqsQueue)
BOOL  SqsCloseQueue (HSQS *sqsQueue)
BOOL  SqsSendMessage (HSQS sqsQueue, char *message, DWORD delaySeconds, char *messageID, DWORD messageIDSize)
BOOL  SqsReceiveMessage (HSQS sqsQueue, char *attributeName, BYTE maxNumberOfMessages, DWORD visibilityTimeout, char *message, char *messageID, char *recieptHandle)
BOOL  SqsDeleteQueue (HSQS sqsQueue)
BOOL  SqsCreateQueue (HSQS sqsQueue)
BOOL  SqsGetQueueUrl (HSQS sqsQueue, char *dataOut, DWORD dataOutSize)
BOOL  SqsListQueues (HSQS sqsQueue, char *queueNamePrefix, char *filePath)
BOOL  SqsFindQueue (const char *filePath, char *dataOut, DWORD dataOutSize, DWORD *pointerToNextTopic, DWORD fileSize)
BOOL  SqsGetQueueAttributes (HSQS sqsQueue, char *dataOut, DWORD dataOutSize)
BOOL  SqsSetQueueAttributes (HSQS sqsQueue, DWORD attributeName, int attributeValue)
BOOL  SqsDeleteMessage (HSQS sqsQueue, char *receiptHandle)
BOOL  SqsChangeMessageVisibility (HSQS sqsQueue, char *receiptHandle, DWORD visibilityTimeoutValue)
Detailed Description
Author
Author:
agp
Version
Rev:
1154
Date
Date:
2012-11-08 19:56:19 +0530 (Thu, 08 Nov 2012)
Function Documentation
BOOL SqsChangeMessageVisibility ( HSQS  sqsQueue,
char *  receiptHandle,
Changes Message's Visibility Timeout attribute
Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue()
[in] receiptHandle Pointer to the string returned by call to SqsReceiveMessage()
[in] visibilityTimeoutValue New value for timeout, Range [0 - 900] Seconds
Return values
TRUE Success
FALSE See GetLastError()
BOOL SqsCloseQueue ( HSQS *  sqsQueue )
Deletes already opened SQS Queue Handle
Parameters
Return values
TRUE Success
BOOL SqsCreateQueue ( HSQS  sqsQueue )
Creates a Queue
Parameters
Return values
TRUE Success
BOOL SqsDeleteMessage ( HSQS  sqsQueue,
Deletes a Message from a Queue
Parameters
Return values
TRUE Success
BOOL SqsDeleteQueue ( HSQS  sqsQueue )
Deletes the Queue
Parameters
Return values
TRUE Success
BOOL SqsFindQueue ( const char *  filePath,
char *  dataOut,
DWORD  dataOutSize,
DWORD *  pointerToNextTopic,
DWORD  fileSize
Finds one by one Queue details stored in a local file as a result of function call to SnsListQueues()
File must be initialized by calling SqsListQueues()
Parameters
[in] filePath Local file path in which queue list data is saved
[out] dataOut Pointer to the allocated memory to store returned queue detail, user need to allocate memory
[in] dataOutSize Size of the allocated memory pointed by dataOut
[in,out] pointerToNextTopic Points to next location of detail, to find 1st in the list put NULL
[in] fileSize Size of the file in bytes, pointed by filePath
Return values
TRUE Success
BOOL SqsGetQueueAttributes ( HSQS  sqsQueue,
char *  dataOut,
DWORD  dataOutSize
Gets Queue Attributes
Parameters
[out] dataOut Pointer to the allocated memory to hold Queue attributes data returned by function, user need to allocate memory
Return values
TRUE Success
BOOL SqsGetQueueUrl ( HSQS  sqsQueue,
char *  dataOut,
DWORD  dataOutSize
Gets Queue Url
Parameters
[out] dataOut Pointer to the allocated memory to hold Queue string returned by the function, user need to allocate memory
[in] dataOutSize Size of the allocated memory for dataOut
Return values
TRUE Success
BOOL SqsListQueues ( HSQS  sqsQueue,
char *  queueNamePrefix,
char *  filePath
Lists all Queues in a local file starting with prefix mentioned
Queues are stores in a local file
Parameters
[in] queueNamePrefix Prefix example "test" to get a list of all queues starting with test or
"t" to get list of all queue starting with letter t
[in] filePath Local file path in which queue list data will be saved
Return values
TRUE Success
BOOL SqsOpenQueue ( char *  accessID,
char *  secretKey,
char *  path,
char *  accountOwnerID,
char *  queueName,
HSQS *  sqsQueue
Opens Handle for SQS Queue, the returned sqsQueue Handle is required as an input parameter to every Sqs function call
Parameters
[in] accessID AWS Access ID [20 Characters]
[in] secretKey AWS Secret Key [40 Characters]
[in] path AWS SQS path
[in] accountOwnerID 12 digit unique ID number like, AWS Access ID
[in] queueName Queue names must be constructed using only uppercase/lowercase ASCII letters,
numbers, underscore, hyphen, and must be between 1 and 80 characters long.
[out] sqsQueue Handle to hold various sqs related parameters.
Return values
TRUE Success
BOOL SqsReceiveMessage ( HSQS  sqsQueue,
char *  attributeName,
char *  message,
char *  messageID,
char *  recieptHandle
Receives message from an existing Queue
Parameters
[in] attributeName Valid String values: All | SenderId | SentTimestamp | ApproximateReceiveCount | ApproximateFirstReceiveTimestamp
[in] maxNumberOfMessages Maximum number of messages to return, 1 to 10(maximum)
[in] visibilityTimeout The duration (in seconds) that the received messages are hidden
from subsequent retrieve requests after being retrieved by a SqsReceiveMessage() request.
[out] message Pointer to the received Message as string (64KB maximum)
[out] messageID Pointer to the received Message's ID as string, maximum length = 100
[out] recieptHandle Pointer to the recieptHandle as string, it is required by SnsDeleteMessage() call. Maximum length = 1024
Return values
TRUE Success
FALSE See GetLastError() AttributeName, visibilityTimeout, maxNumberOfMessages - working in default mode only for now (kept it for future use)
Put NULL for these input parameters
BOOL SqsSendMessage ( HSQS  sqsQueue,
char *  message,
DWORD  delaySeconds,
char *  messageID,
DWORD  messageIDSize
Sends a message to the Queue
Parameters
[in] message The message you want to send to the queue. Maximum length is 64KB
[in] delaySeconds Number of seconds to delay the message
Messages with a positive delay seconds becomes available for processing after the delay time has elapsed
[out] messageID Successful call to this function will put message ID string on the memory pointed by this pointer, user need to allocate memory
[in] messageIDSize Size of the memory allocated for messageID
Return values
TRUE Success
BOOL SqsSetQueueAttributes ( HSQS  sqsQueue,
int  attributeValue
Sets Queue Attribute
Parameters
[in] attributeName Valid values can be from 1 to 4, user should use macros QUEUE_ATTRIBUTE_XXXXXXXXX
[in] attributeValue Value associated with attributeName
Return values
TRUE Success
