CoMExpress Connector
Article updated at 23 Sep 2012
For Robin Carrierboards
The single 220-pin 0.5mm pitch carrier board connectors are 5H/8H plug in connectors with a board-to-board stack height of 5.0mm/8.0mm. A potential source for this plug-in board-to-board connector is:
  • AMP/Tyco HARD TRAY ASSY FH 0.5 BTB CONNECTOR 220POS PLUG 5H WITH GROUND PLATE (5.0mm stack height): 3-1827253-6
  • AMP/Tyco HARD TRAY ASSY FH 0.5 BTB CONNECTOR 220POS PLUG 8H WITH GROUND PLATE (8.0mm stack height): 3-6318491-6
In case of high lead times for Robin Carrierboard connectors, the ones for Woodpecker may be ordered and separated for production.
For Woodpecker Carrierboards
  • AMP/Tyco HARD TRAY ASSY FH 0.5 BTB CONNECTOR 440POS PLUG 5H WITH GROUND PLATE (5.0mm stack height): 3-1827233-6
  • AMP/Tyco HARD TRAY ASSY FH 0.5 BTB CONNECTOR 440POS PLUG 8H WITH GROUND PLATE (8.0mm stack height): 3-5353652-6
Connector suppliers
The following suppliers can ship the Connector which must be used on the Baseboard for Woodpecker and Robin
  • Mouser
  • TTI
  • Avnet
  • Spoerle
  • OnlineComponents.com (e.g. http://www.onlinecomponents.com/buy/AMP-TYCO/3-6318491-6/)
Ordering the connector at Tyco is also possible.
