CoProc Lib API
Library to provide access to the ARM Coprocessor registers. More...
Macros
##define CPL_VER_MAJ   2 CoprocLib Major Library Version. More...
 #define CPL_VER_MIN   2 CoprocLib Minor Library Version. More...
 #define CPL_VER_BUILD   0 CoprocLib Library Build Version. More...
 #define PXA   1 #define TEG   2 #define TYPE_PXA270   0x11 #define TYPE_MONAHANS   0x02 #define TYPE_PXA320   0x02 #define TYPE_PXA300XT   0x07 #define TYPE_PXA300   0x08 #define TYPE_PXA310   0x09 #define TYPE_TEGRA2   0x411FC09 #define TYPE_TEGRA3   0x412FC09 #define MODULE_FAMILY_COLIBRI   0 #define MODULE_FAMILY_APALIS   1
Functions
DWORD getCLKCFG ()
void setCLKCFG (DWORD val)
DWORD getPWRMODE ()
void setPWRMODE (DWORD val)
DWORD getCPUID ()
DWORD getPROCID ()
DWORD getL2Enabled ()
void CPLGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
DWORD GetSoCType ()
DWORD getModuleFamily ()
Detailed Description
Author:
kia
Rev:
2101
Date:
2014-03-10 14:27:38 +0100 (Mo, 10 Mrz 2014)
Target Platforms:
Colibri PXAxxx, T20, T30 & Apalis T30
#define PXA   1
#define TEG   2
Function Documentation
void CPLGetLibVersion(DWORD * pVerMaj,
  DWORD * pVerMin,
  DWORD * pBuild
Get the revision of this CoprocLib
Parameters
[out]majorlibrary version. Set this parameter to NULL if not required.
[out]minorlibrary version. Set this parameter to NULL if not required.
[out]librarybuild number. Set this parameter to NULL if not required.
DWORD getCLKCFG( )
Get Core Clock Configuration (Coprocessor 14, cr6) [for PXA only]
On other CPUs the function also returns cp14.cr6, but this register has a different meaning.
See ARM documentation for details.
Returns
CLKCFG. (content of cp14.cr6)
DWORD getCPUID( )
Request extended CPUID (Coprocessor 15, register c0)
Returns
value read from coprocessor 15 register c0.
Refer to the ARM documentation for details.
DWORD getL2Enabled( )
Request whether L2 cache is enabled or disabled
Return values
true,:L2 cache is enabled
false,:L2 cache is disabled
DWORD getModuleFamily( )
Request module family type (Colibri / Apalis)
Returns
CPU_TYPE: MODULE_FAMILY_COLIBRI or MODULE_FAMILY_APALIS
See defines at the beginning of coproclib.h for details.
DWORD getPROCID( )
Detect the CPU type this code is running on
Returns
CPU ID. See defines at the beginning of coproclib.h for details.
DWORD getPWRMODE( )
Get PWRMODE (Coprocessor 14, cr7) [for PXA only]
On other CPUs the function also returns cp14.cr7, but this register has a different meaning.
Returns
PWRMODE. (content of cp14.cr7)
DWORD GetSoCType( )
Request SoC family type (PXA / Tegra)
Returns
CPU_TYPE: SOC family i.e PXA or Tegra
void setCLKCFG(DWORD val)
Set Core Clock Configuration (Coprocessor 14, cr6) [for PXA only]
On other CPUs the function also sets cp14.cr6, but this register has a different meaning.
Parameters
[in]CLKCFG.Value to store into cp14.cr6
void setPWRMODE(DWORD val)
Set PWRMODE (Coprocessor 14, cr7) [for PXA only]
On other CPUs the function also sets cp14.cr7, but this register has a different meaning.
Parameters
[in]PWRMODE.Value to store into cp14.cr7
