Customized Robin
For customized Robin modules (E.g. no Ethernet chip, more RAM, …), Toradex charges a minimum of 750 Euros for setting up the assembly machine and other costs related to logistics. This charge applies for every production lot.
Please keep in mind that a customized module have some disadvantages compared to a standard Robin:
  • minimum lot size 500 pieces.
  • Toradex will not take special modules or components at stock. This leads to higher lead times for the modules.
  • If special components run end of life, additional costs for new evaluation.
That means, in the most cases it is better to use an already existing Robin variant.
However there are some special cases in which a customized module makes sense. If you need more information please contact us.
