DMA Library API
Library for DMA handling, including channel allocation and DMA transfer control.
Data Structures
struct  DMA_GLOBALSMemory mapped DMA Globals structure - sorted by DMA channel. More...
Macros
#define  DMA_VER_MAJ  1
#define  DMA_VER_MIN  3
#define  DMA_VER_BUILD  1
#define  DMA_MAX_CHAN  32
number of available DMA channels More...
#define  DMA_USAGE_LEN  32
maximum string length for a descriptive text (DMA channel usage) More...
#define  DMA_SHARED_FILENAME  (TEXT("ColibriDmaGlobals"))
Memory mapped filename used by the DMALib for interprocess sharing of DMA data structures. More...
#define  PERIPH_SSP1RX  (13)
#define  PERIPH_SSP1TX  (14)
#define  PERIPH_SSP2RX  (15)
#define  PERIPH_SSP2TX  (16)
#define  PERIPH_SSP3RX  (66)
#define  PERIPH_SSP3TX  (67)
#define  PERIPH_SSP4RX  (71)
#define  PERIPH_SSP4TX  (72)
#define  PERIPH_CIF1  (68)
#define  PERIPH_CIF2  (69)
#define  PERIPH_CIF3  (70)
#define  DCMD_INCSRCADDR  (1 << 31)
Source Address Increment. More...
#define  DCMD_INCTRGADDR  (1 << 30)
Target Address Increment. More...
#define  DCMD_FLOWSRC  (1 << 29)
Source Flow Control. More...
#define  DCMD_FLOWTRG  (1 << 28)
Target Flow Control. More...
#define  DCMD_CIF_DMA  (1 << 27)
Create a PXA3xx CIF descriptor. More...
#define  DCMD_CMPEN  (1 << 25)
Descriptor Compare Enable. More...
#define  DCMD_ADDRMODE  (1 << 23)
Addressing Mode. More...
#define  DCMD_STARTIRQEN  (1 << 22)
Start Interrupt Enable. More...
#define  DCMD_ENDIRQEN  (1 << 21)
End Interrupt Enable. More...
#define  DCMD_FLYBYS  (1 << 20)
Fly-By Source (PXA270 only) More...
#define  DCMD_FLYBYT  (1 << 19)
Fly-By Target (PXA270 only) More...
#define  DCMD_BSIZE8  (1 << 16)
#define  DCMD_BSIZE16  (2 << 16)
#define  DCMD_BSIZE32  (3 << 16)
#define  DCMD_BWIDTH8  (1 << 14)
#define  DCMD_BWIDTH16  (2 << 14)
#define  DCMD_BWIDTH32  (3 << 14)
#define  DCMD_LENGTH  0x01fff
Length of Transfer in Bytes (MASK) More...
#define  DCSR_RUN  (1 << 31)
Run Bit (read / write) More...
#define  DCSR_NODESC  (1 << 30)
No-Descriptor Fetch (read / write) More...
#define  DCSR_STOPIRQEN  (1 << 29)
Stop Interrupt Enable (when the descriptor is done) (read / write) More...
#define  DCSR_EORIRQEN  (1 << 28)
End-of-Receive Interrupt Enable. More...
#define  DCSR_EORJMPENT  (1 << 27)
Jump to next Descriptor on End-of-Receive. More...
#define  DCSR_EORSTOPEN  (1 << 26)
Stop Channel on End-of-Receive. More...
#define  DCSR_SETCMPST  (1 << 25)
Set Descriptor Compare Status. More...
#define  DCSR_CLRCMPST  (1 << 24)
Clear Descriptor Compare Status. More...
#define  DCSR_CMPST  (1 << 10)
#define  DCSR_EORINT  (1 << 9)
End of Receive. More...
#define  DCSR_REQPEND  (1 << 8)
Request Pending (read-only) More...
#define  DCSR_RASINTR  (1 << 4)
Request after Channel Stops. More...
#define  DCSR_STOPINTR  (1 << 3)
Stop State (read-only) More...
#define  DCSR_ENDINTR  (1 << 2)
End Interrupt (read / write) More...
#define  DCSR_STARTINTR  (1 << 1)
Start Interrupt (read / write) More...
#define  DCSR_BUSERRINTR  (1 << 0)
Bus Error Interrupt (read / write) More...
#define  DRCMR_MAPVLD  (1 << 7)
Valid Channel mapped. More...
#define  DDADR_STOP  (1 << 0)
Enumerations
enum   DMA_PERIPH_ID {
  DMA_PERIPH_DREQ0 = 0, DMA_PERIPH_DREQ1 = 1, DMA_PERIPH_SSP_4_RX = 2, DMA_PERIPH_SSP_4_TX = 3,
  DMA_PERIPH_BTUART_RX = 4, DMA_PERIPH_BTUART_TX = 5, DMA_PERIPH_FFUART_RX = 6, DMA_PERIPH_FFUART_TX = 7,
  DMA_PERIPH_AC97_MIC = 8, DMA_PERIPH_AC97_MODEM_RX = 9, DMA_PERIPH_AC97_MODEM_TX = 10, DMA_PERIPH_AC97_AUDIO_RX = 11,
  DMA_PERIPH_AC97_AUDIO_TX = 12, DMA_PERIPH_SSP_1_RX = 13, DMA_PERIPH_SSP_1_TX = 14, DMA_PERIPH_SSP_2_RX = 15,
  DMA_PERIPH_SSP_2_TX = 16, DMA_PERIPH_STUART_RX = 19, DMA_PERIPH_STUART_TX = 20, DMA_PERIPH_MMC_RX = 21,
  DMA_PERIPH_MMC_TX = 22, DMA_PERIPH_USB_ENDPOINT_0 = 24, DMA_PERIPH_USB_ENDPOINT_A = 25, DMA_PERIPH_USB_ENDPOINT_B = 26,
  DMA_PERIPH_USB_ENDPOINT_C = 27, DMA_PERIPH_USB_ENDPOINT_D = 28, DMA_PERIPH_USB_ENDPOINT_E = 29, DMA_PERIPH_USB_ENDPOINT_F = 30,
  DMA_PERIPH_USB_ENDPOINT_G = 31, DMA_PERIPH_USB_ENDPOINT_H = 32, DMA_PERIPH_USB_ENDPOINT_I = 33, DMA_PERIPH_USB_ENDPOINT_J = 34,
  DMA_PERIPH_USB_ENDPOINT_K = 35, DMA_PERIPH_USB_ENDPOINT_L = 36, DMA_PERIPH_USB_ENDPOINT_M = 37, DMA_PERIPH_USB_ENDPOINT_N = 38,
  DMA_PERIPH_USB_ENDPOINT_P = 39, DMA_PERIPH_USB_ENDPOINT_Q = 40, DMA_PERIPH_USB_ENDPOINT_R = 41, DMA_PERIPH_USB_ENDPOINT_S = 42,
  DMA_PERIPH_USB_ENDPOINT_T = 43, DMA_PERIPH_USB_ENDPOINT_U = 44, DMA_PERIPH_USB_ENDPOINT_V = 45, DMA_PERIPH_USB_ENDPOINT_W = 46,
  DMA_PERIPH_USB_ENDPOINT_X = 47, DMA_PERIPH_BASEBAND_1_RX = 48, DMA_PERIPH_BASEBAND_1_TX = 49, DMA_PERIPH_BASEBAND_2_RX = 50,
  DMA_PERIPH_BASEBAND_2_TX = 51, DMA_PERIPH_BASEBAND_3_RX = 52, DMA_PERIPH_BASEBAND_3_TX = 53, DMA_PERIPH_BASEBAND_4_RX = 54,
  DMA_PERIPH_BASEBAND_4_TX = 55, DMA_PERIPH_BASEBAND_5_RX = 56, DMA_PERIPH_BASEBAND_5_TX = 57, DMA_PERIPH_BASEBAND_6_RX = 58,
  DMA_PERIPH_BASEBAND_6_TX = 59, DMA_PERIPH_BASEBAND_7_RX = 60, DMA_PERIPH_BASEBAND_7_TX = 61, DMA_PERIPH_USIM_RX = 62,
  DMA_PERIPH_USIM_TX = 63, DMA_PERIPH_SSP_3_RX = 66, DMA_PERIPH_SSP_3_TX = 67, DMA_PERIPH_TPM_RX = 71,
  DMA_PERIPH_TPM_TX_1 = 72, DMA_PERIPH_TPM_TX_2 = 73, DMA_PERIPH_DREQ2 = 74, DMA_PERIPH_USIM_2_RX = 91,
  DMA_PERIPH_USIM_2_TX = 92, DMA_PERIPH_MMC_2_RX = 93, DMA_PERIPH_MMC_2_TX = 94, DMA_PERIPH_AC97_SURROUND_TX = 95,
  DMA_PERIPH_CENTRE_LFE_TX = 96, DMA_PERIPH_NAND_DATA = 97, DMA_PERIPH_NAND_CMD = 99, DMA_PERIPH_MMC_3_RX = 100,
  DMA_PERIPH_MMC_3_TX = 101, DMA_PERIPH_MEM2MEM = 255, DMA_PERIPH_FREE = -1
DMA peripheral device DRCMR IDs. More...
enum   DMA_CHANNEL_PRIORITY { DMA_PRIORITY_HIGH = 0, DMA_PRIORITY_MEDIUM, DMA_PRIORITY_LOW, DMA_PRIORITY_LOWEST }
DMAC Channel Allocation Priority. More...
Functions
void  DMAGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
Initialisation. More...
void  DMAInit (void)
Initializes the DMA Library. More...
void  DMADeInit (void)
De-Initializes the DMA Library. More...
DWORD  DMAAllocChannel (DWORD periph)
DMA Channel Management. More...
DWORD  DMAAllocChannelEx (DWORD periph, DWORD priority)
void  DMAReleaseChannel (DWORD chan)
void  DMAReleaseDevice (DWORD periph)
void  DMASetChannelUsage (DWORD chan, CHAR *szChanUsage, DWORD cBytes)
DWORD  DMAGetChannelUsage (DWORD chan, CHAR *szChanUsage, DWORD cBytes)
DMA Preparation
BOOL  DMACreateTransferDescriptors (DWORD sadr, DWORD tadr, DWORD len, DWORD flags, BOOL loop, MEM_T *pMem)
BOOL  DMADestroyTransferDescriptors (MEM_T *pMem)
BOOL  DMAAllocBuffer (MEM_T *pMem, DWORD size)
BOOL  DMAFreeBuffer (MEM_T *pMem)
DMA Real Time Control
DWORD  DMAStartTransferEx (DWORD chan, MEM_T *pMem, DWORD flags, BOOL block)
void  DMAStartShortTransfer (DWORD chan, DWORD sadr, DWORD tadr, DWORD len, DWORD cmd, DWORD csr)
DWORD  DMAStartShortTransferEx (DWORD chan, DWORD sadr, DWORD tadr, DWORD len, DWORD cmd, DWORD csr, BOOL block)
void  _DMAStartTransfer (DWORD chan, MEM_T *pMem, DWORD flags)
void  DMAWaitTransferEnd (DWORD chan)
void  DMAStopTransfer (DWORD chan)
BOOL  DMAGetTrgSrcAdd (DWORD chan, DWORD *dtadr, DWORD *dsadr)
Get current Target and Source address.
. More...
DWORD  DMAGetLen (DWORD chan)
Addressing Mode.
End of Receive.
Enumerator
DMA_PRIORITY_HIGH
DMA_PRIORITY_MEDIUM
DMA_PRIORITY_LOW
DMA_PRIORITY_LOWEST
Enumerator
DMA_PERIPH_DREQ0
DMA_PERIPH_DREQ1
DMA_PERIPH_SSP_4_RX
DMA_PERIPH_SSP_4_TX
DMA_PERIPH_AC97_MIC
DMA_PERIPH_SSP_1_RX
DMA_PERIPH_SSP_1_TX
DMA_PERIPH_SSP_2_RX
DMA_PERIPH_SSP_2_TX
DMA_PERIPH_MMC_RX
DMA_PERIPH_MMC_TX
DMA_PERIPH_USIM_RX
DMA_PERIPH_USIM_TX
DMA_PERIPH_SSP_3_RX
DMA_PERIPH_SSP_3_TX
DMA_PERIPH_TPM_RX
DMA_PERIPH_TPM_TX_1
DMA_PERIPH_TPM_TX_2
DMA_PERIPH_DREQ2
DMA_PERIPH_MMC_2_RX
DMA_PERIPH_MMC_2_TX
DMA_PERIPH_NAND_CMD
DMA_PERIPH_MMC_3_RX
DMA_PERIPH_MMC_3_TX
DMA_PERIPH_MEM2MEM
DMA_PERIPH_FREE
Function Documentation
void _DMAStartTransfer ( DWORD  chan,
MEM_T *  pMem,
DWORD  flags
Start a DMA transfer which was previously setup using DMACreateTransferDescriptors().
Needed to be renamed because in Wince 6.0 we have a naming conflict with a CEDDK function!!
Parameters
[in] chan DMA channel number
[in] pMem Physical and virtual address of the descriptor
[in] flags Flags for the DMA Control/Status Register
BOOL DMAAllocBuffer ( MEM_T *  pMem,
DWORD  size
Allocate physical memory that can be used as source or target for DMA transfers.
Parameters
[out] pMem Physical and virual address of the allocated memory
[in] size Required memory size in bytes
Return values
TRUE Success
FALSE Error occured
DWORD DMAAllocChannel ( DWORD  periph )
Searches for a free channel and allocates it.
Parameters
[in] periph DMA peripheral device DRCMR ID
Return values
-1 No free channel found.
>=0 Allocated DMA channel number
Deprecated:
Obsolete fuction!
DWORD DMAAllocChannelEx ( DWORD  periph,
DWORD  priority
Searches for a free channel with specific priority and allocates it.
Parameters
[in] priority Requested Priority. See DMA_CHANNEL_PRIORITY
Return values
-1 No free channel found for the requested priority.
>=0 Allocated DMA channel number.
BOOL DMACreateTransferDescriptors ( DWORD  sadr,
DWORD  tadr,
DWORD  len,
DWORD  flags,
BOOL  loop,
MEM_T *  pMem
Create DMA Transfer descriptor.
NOTE: TransferDescriptors in RAM are only required for transfers of 8kB or more.
Parameters
[in] sadr Source address
[in] tadr Target address
[in] len Length of Transfer in Bytes, see also DMA Command Registers
[in] flags Flags for the DMA Command Registers
[in] loop TRUE: DMA descriptor chain is a loop
[out] pMem Physical and virtual address of the descriptor
Return values
TRUE Success
FALSE Error occured
void DMADeInit ( void  )
BOOL DMADestroyTransferDescriptors ( MEM_T *  pMem )
Release memory reserved for the transfer descriptor.
Parameters
[in,out] pMem Physical and virtual address of the descriptor
Return values
TRUE Success
FALSE Error occured
BOOL DMAFreeBuffer ( MEM_T *  pMem )
Free the physical memory that was allocated by DMAAllocBuffer()
Parameters
[in,out] pMem Physical and virtual address of the allocated memory
Return values
TRUE Success
FALSE Error occured
DWORD DMAGetChannelUsage ( DWORD  chan,
CHAR *  szChanUsage,
DWORD  cBytes
Get the descriptive text for what a DMA channel is used for.
Parameters
[out] szChanUsage Descriptive Text (Zero-terminated ASCII string)
[in] cBytes Maximum allowed String Length in Bytes
Return values
DWORD Actually returned string length.
DWORD DMAGetLen ( DWORD  chan )
Get number of bytes already transferred.
Parameters
Return values
DWORD Number of bytes already transferred.
void DMAGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Initialisation.
Returns the library Version.
Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required.
[out] pVerMin Returns the minor version number. Set this parameter to NULL if not required.
[out] pBuild Returns the build number. Set this parameter to NULL if not required.
BOOL DMAGetTrgSrcAdd ( DWORD  chan,
DWORD *  dtadr,
DWORD *  dsadr
Parameters
[out] dtadr Target address
[out] dsadr Source address
Return values
TRUE Success
FALSE Error occured
void DMAInit ( void  )
void DMAReleaseChannel ( DWORD  chan )
Release/free DMA Channel
Parameters
[in] chan DMA channel number. Remarks: ATTENTION! Parameter changed to channel number.
Used to be peripheral device ID which is inappropriate.
See new Function: DMAReleaseDevice.
void DMAReleaseDevice ( DWORD  periph )
Releases Device allocated DMA Channel.
Parameters
void DMASetChannelUsage ( DWORD  chan,
CHAR *  szChanUsage,
DWORD  cBytes
Set a descriptive text for what a DMA channel is used for.
Parameters
[in] szChanUsage Descriptive Text (Zero-terminated ASCII string)
[in] cBytes String Length in Bytes
void DMAStartShortTransfer ( DWORD  chan,
DWORD  sadr,
DWORD  tadr,
DWORD  len,
DWORD  cmd,
DWORD  csr
Start DMA transfer non descriptor mode.
NOTE: This can only be used for transfers < 8kB
Parameters
[in] len Length of Transfer in bytes (max. 8191)
[in] cmd Flags for the DMA Command Registers
[in] csr Flags for the DMA Control/Status Register
DWORD DMAStartShortTransferEx ( DWORD  chan,
DWORD  sadr,
DWORD  tadr,
DWORD  len,
DWORD  cmd,
DWORD  csr,
BOOL  block
Start DMA transfer non-descriptor mode.
NOTE: This can only be used for transfers < 8Kb
Parameters
[in] block TRUE: function returns after DMA is finished
FALSE: function returns immediately
Return values
TRUE Success
FALSE Timeout detected
DWORD DMAStartTransferEx ( DWORD  chan,
MEM_T *  pMem,
DWORD  flags,
BOOL  block
Parameters
[in] block TRUE=function returns after DMA is finished
FALSE= function returns immediately
Return values
TRUE Success
void DMAStopTransfer ( DWORD  chan )
Early stop DMA transfer
Parameters
void DMAWaitTransferEnd ( DWORD  chan )
Wait until DMA transfer is finished
Parameters
