Electron Framework
Electron is a framework for creating native applications using web technologies like JavaScript, HTML, and CSS. More info here.
Electron Install
Update the system package manager and install some required dependencies and packages:
opkg update
opkg install libxss1 libcups2 nodejs nodejs-npm git
Execute the command “npm init” inside a folder called “electron” to create the package.json file. That will be the repository for the following install. Keep pressing “enter” so "npm init" keeps the default configuration:
mkdir electron
cd electron
npm init
version: (1.0.0)
description:
entry point: (index.js)
test command:
git repository:
keywords:
author:
license: (ISC)
About to write to /home/root/electron/package.json:
"name": "electron",
"version": "1.0.0",
"description": "",
"main": "index.js",
"scripts": {
"test": "echo \"Error: no test specified\" && exit 1"
"author": "",
"license": "ISC"
Install the pre-built Electron package:
npm install electron-prebuilt
Run Samples
Clone the repository of samples inside a folder:
mkdir Samples
cd Samples
git clone https://github.com/hokein/electron-sample-apps.git
To execute a sample, enter a specific sample directory and execute the command, for instance:
cd electron-sample-apps
cd frameless-window
~/electron/node_modules/.bin/electron .
The videos below present some demos created in Electron:
