First Steps with Capacitive Touch Display 7 Inch Parallel
This article provides information on how to start working with the Capacitive Touch Display 7 Inch Parallel, which includes how to set up the hardware (wiring) and install the necessary drivers for a touch demo.
Getting Started
Connections on Ixora, Aster
This topic provides pin connection details in regards to connecting the Capacitive Touch Display 7 Inch Parallel to any of our carrier boards. Please refer to the below images for connecting the display to our Ixora Carrier Board(V1.1 and above, for V1.0 the Capacitive Touch Adapter is needed) & Aster Carrier Board. At present these carrier boards support a Capacitive Touch Interface Connector with our Capacitive Touch Display 7 Inch Parallel.
Connections on Iris, Viola, Colibri Evautation Board, Apalis Evaluation board
For other carrier boards or evaluation boards like Iris, Viola, Colibri Evaluation Board, Apalis Evaluation board, one can use the Capacitive Touch Adapter as capacitive touch connector not yet available. All connection details are available in the Capacitive Touch Adapter datasheet.
WinCE
Multi-Touch Driver Installation
Modules (Colibri / Apalis) T20 VF50 VF61 T30 iMX6 iMX7 PXA
Windows Embedded CE 6.0 (CE6) [1] ok ok ok -- -- -- [3]
Windows Embedded Compact 7 (CE7) [2] ok ok ok ok ok ok --
Windows Embedded Compact 2013 (CE8) [2] -- ok ok ok ok ok --
Download touch demo application for the respective OS below:
OS: WCE6 WEC7 WEC2013
TouchDemo -- here here
Note :
[1] Supports single-touch and gestures.
[2] Supports multi-touch, single-touch, and gestures.
[3] The installer can be installed on WinCE6 PXA modules. The Hwadapt application doesn't support PXAs. It would need porting to the legacy library to make it work for PXA. Please refer to the Capacitive Multi-Touch Solution Source Code for more information about the Hwadapt application.
Registry Settings
Registry Settings: After installing the multi-touch driver, current settings in the registry can be viewed, exported, and edited with the help of registry editor on the module:
Start->Programs->ColibriTool->RegEdit
Display Settings: Click here.
Display Rotation: Click here.
Multi-Touch Hardware Adaption: The current hardware adaption (connection to the carrier board) is stored at:
[HKEY_LOCAL_MACHINE\Software\Toradex\MultiTchHwAdapt]
Information about the registry settings of the hardware adaption can be found on Capacitive Multi-Touch Solution.
Troubleshooting Touch Panel
After the hardware setup, driver installation, and registry settings are completed, the following steps and tools will help to bring up the device:
  • The display should show the Windows CE desktop without any border, flicker, etc. Click here for more details including, checking the documents for general functionality, multi-touch hardware adaption application.
  • In rare cases, if you experience I2C failures of Vybrid Modules with connected touch, reducing pull-up resistor value may be of valuable help. 1.8K pull-up can give the better result.
Colibri iMX7
Reset and Interrupt lines:
  • In case of any issue with reset or interrupt lines, use GPIO Config Tool to monitor and control reset & interrupt pins (SODIMM or MXM3 pin).
I2C Bus (SDA, SCL signals):
  • In case of any issue, run the I2C demo tool to scan the I2C addresses which is part of the package in the Toradex CE libraries and code samples. The tool shows the I2C addresses of all devices on the I2C bus. One of these addresses should be the address of the touch controller. (Please note that the shown addresses are the addresses of the devices on the I2C bus and not the address set in the registry.)
  • Please check if the Reset pin is in its inactive state (level is 1) so that the touch controller of the display can run.
Embedded Linux
Starting with our Embedded Linux BSPs 2.7b4 the Capacitive Touch Display 7 Inch Parallel without Capacitive Touch Adapter is supported in single-touch mode. However, while the lower stack (driver and X-Server) supports multi-touch, the desktop environment doesn't make use of it. Also, there is no gesture engine inside the driver or X server itself.
To configure the correct display resolution refer to the Display Output, Resolution and Timings (Linux) article.
Connection with Capacitive Touch Interface Connector
On Colibri modules with device tree enabled Kernels the Atmel Maxtouch controller needs to be enabled in the device tree (set device tree property status to okay, see Device Tree Customization).
On Apalis modules the Atmel Maxtouch kernel module (atmel_mxt_ts.ko) need to be loaded.
Connection with Capacitive Touch Adapter
Due to different wiring this needs further customisations of the device tree.
