Flash Memory
The Toradex modules uses Flash memory for its persistent memory storage. Depending on the type of module, different Flash types are used:
  • Apalis iMX6: eMMC MLC NAND Flash
  • Apalis T30: eMMC MLC NAND Flash
  • Colibri iMX6: eMMC MLC NAND Flash
  • Colibri PXA270: MLC NOR Flash with 100k write cycles
  • Colibri PXA3xx: SLC NAND Flash with 100k write cycles
  • Colibri T20: SLC NAND Flash with 60k write cycles
  • Colibri T30: eMMC MLC NAND Flash
  • Colibri VF50/VF61: SLC NAND Flash with 100k write cycles
Toradex Flash Handling
The Toradex BSP incorporates the following features for the flash handling:
  • Flash wear levelling
  • Error detection and correction
  • Bad block management
For eMMC this functions are done by the eMMC chip itself.
Win CE Flash Layout and File System
The Flash Memory stores different type of data. Detailed information can be found in a separate article about the Flash Layout.
We are using a transaction safe file system (TFAT) for the user file storage part in the flash memory . See Flash file system.
