Flat Panel Type (Woodpecker, Robin)
Tags
For driving flat panels connected to the LVDS channel of the Woodpecker or Robin Module, the correct settings has to be chosen in the Video BIOS.
Custom Flat Panel Settings
If the available default flat panel settings do not meet the requirements, custom settings can be done with the IEGD Tool.
Available Default Settings
The default Video BIOS delivered with the module contains already some standard Flat Panel settings.
AMI
For choosing a default setting, go to the following setup menu in the BIOS setup:
BIOS SETUP menu -> Chipset -> North Bridge Configuration -> Boot Display Configuration -> Flat Panel Type
AWARD
BIOS SETUP menu -> Advanced Chipset Features -> LCD Panel Type
Flat panel types
Panel ID Horizontal Vertical Refresh Based on Compatible to
1 640 480 60 Hz VGA Timings
2 800 600 60 Hz VESA Standards
3 1024 768 60 Hz VESA Standards
4 640 480 60 Hz 8.4" NEC Panel
5 800 480 60 Hz 9" NEC Panel
6 1024 600 60 Hz 5.61" TMD Panel
7 1024 768 60 Hz 15" Samsung Panel
8 1280 768 60 Hz Generic timing
9 1280 768 60 Hz 7.2" Sharp Panel
10 1280 800 60 Hz 15.4" Samsung Panel Kontron NVKU LF LVDS-DVI-Converter
11 1024 768 60 Hz Generic timing
12 1024 768 60 Hz Generic timing
13 1024 768 60 Hz Generic timing
14 1280 800 60 Hz Generic timing
15 1280 600 60 Hz Generic timing
16 1366 768 60 Hz 11.1" TMD Panel
