Freq Lib API
Library to manage system clocks frequencies. More...
Data Structures
struct  FRQPXAClocks struct  FRQTEGClocks
Macros
#define  FRQ_VER_MAJ  2
#define  FRQ_VER_MIN  3
#define  FRQ_VER_BUILD  0
#define  TEG_DFS_STATE_STOPPED  2
#define  TEG_DFS_STATE_CLOSED_LOOP  3
#define  CLKCFG_T  1
#define  CLKCFG_F  2
#define  CLKCFG_HT  4
#define  CLKCFG_B  8
#define  MDREFR_APD  (1<<20)
#define  MDREFR_K0DB2  (1<<14)
#define  MDREFR_K1DB2  (1<<17)
#define  MDREFR_K0DB4  (1<<29)
Functions
void  FRQGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL  FRQInit ()
void  FRQDeInit ()
Description: De-initialises the frequency library. More...
BOOL  FRQPXAClocks *pxaClocks)
BOOL  FRQTEGClocks *tegClocks)
DWORD  FRQGetTEGDFSState ()
BOOL  FRQSetPXAFrequencies (MULTCFG multiplierConfig)
DWORD  FRQSetPXA270Voltage (DWORD core_voltage)
BOOL  FRQSetTEGFrequency (tTEGClockIDs tegClockID, DWORD frequency)
BOOL  FRQSetTEGDFSState (DWORD state)
BOOL  TegFrq_Boost (const tTegDfsBusyHint *hints, DWORD numHints, tTegDfsBusyHintSyncMode mode)
void  SetFreq (MULTCFG mp)
MULTCFG  GetFreq (void)
void  CalcSystemFreq (MULTCFG ms, DWORD *pCpuClk, DWORD *pRunClk, DWORD *pSysClk, DWORD *pMemClk, DWORD *pSdramClk, DWORD *pSramClk, DWORD *pLcdClk)
DWORD  SetVoltage (DWORD core_voltage)
Detailed Description
Author
andy.kiser
Rev
2863
Date
2015-06-26 17:18:52 +0200 (Fr, 26 Jun 2015)
Target Platforms:
PXAxxx, Txx
#define CLKCFG_B   8
#define CLKCFG_F   2
#define CLKCFG_HT   4
#define CLKCFG_T   1
PXA Clocks Definitions.
Enumerator
PXACPUClockID
PXARunClockID
PXASysClockID
PXAMemClockID
PXASDRAMClockID
PXASRAMClockID
PXALCDClockID
Tegra Clocks Definitions.
Enumerator
TEGCPUClockID
TEGSysClockID
TEGAVPClockID
TEGAHBClockID
TEGAPBClockID
TEGVIDClockID
TEGEMCClockID
TEGClockIDMax
Function Documentation
void CalcSystemFreq ( MULTCFG  ms,
DWORD *  pCpuClk,
DWORD *  pRunClk,
DWORD *  pSysClk,
DWORD *  pMemClk,
DWORD *  pSdramClk,
DWORD *  pSramClk,
DWORD *  pLcdClk
Calculate the different clocks in HZ
Parameters
[in] ms Multiplier Configuration Structure
[out] pCPUClk CPU Clock Speed (RunMode Clock * XN)
[out] pRunClk RunMode Clock Speed
[out] pSysClk System Clock Speed
[out] pMemClk Memory Clock Speed
[out] pSdramClk SDRAM Clock Speed
[out] pSRamClk SRAM Clock Speed
[out] pLcdClk LCD Clock Speed
void FRQDeInit ( )
void FRQGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Description: Returns the library Version.
Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required.
[out] pVerMin Returns the minor version number. Set this parameter to NULL if not required.
[out] pBuild Returns the build number. Set this parameter to NULL if not required.
BOOL FRQGetPXAClocks ( FRQPXAClocks *  pxaClocks )
Description: Returns the current PXA Clocks Frequencies.
Parameters
in/out] pxaClocks Pointer to FRQPXAClocks structure that will be updated
Return values
TRUE Success
FALSE Failure
BOOL FRQGetTEGClocks ( FRQTEGClocks *  tegClocks )
Description: Returns the current Tegra Clocks Frequencies.
Parameters
in/out] tegClocks Pointer to FRQTEGClocks structure that will be updated
Return values
TRUE Success
FALSE Failure
DWORD FRQGetTEGDFSState ( )
Description: Returns the current state of DFS (Dynamic Frequency Switching).
Return values
2 DFS Stopped
3 DFS Closed Loop
BOOL FRQInit ( )
Description: Initialises the frequency library.
Return values
TRUE Success
FALSE Failure
DWORD FRQSetPXA270Voltage ( DWORD  core_voltage )
Set core voltage.
Parameters
[in] core_voltage Voltage required in mV
Return values
Voltage set in mV Remarks: !!!this is working on PXA270 only!!!
BOOL FRQSetPXAFrequencies ( MULTCFG  multiplierConfig )
Description: Sets the PXA Multiplier Configuration.
Parameters
[in] multiplierConfig Multiplier Configuration Structure
Return values
TRUE Success
FALSE Failure
BOOL FRQSetTEGDFSState ( DWORD  state )
Description: Sets the state of DFS (Dynamic Frequency Switching).
Parameters
[in] state New DFS State (2 = Stopped, 3 = Closed Loop)
Return values
TRUE Success
FALSE Failure
BOOL FRQSetTEGFrequency ( tTEGClockIDs tegClockID,
DWORD  frequency
Description: Sets the given Tegra clock to the given frequency.
Parameters
[in] tegClockID ID of the Tegra Clock to be set
[in] frequency Frequency to set
Return values
TRUE Success
FALSE Failure
MULTCFG GetFreq ( void  )
Get the actual processor frequencies
Return values
void SetFreq ( MULTCFG  mp )
Set the processor frequencies according to mp
Parameters
[in] mp Multiplier Configuration Structure
DWORD SetVoltage ( DWORD  core_voltage )
Set core voltage.
Parameters
[in] core_voltage Voltage in mV
Return values
Set voltage in mV Remarks: !!!this is working on PXA270 only!!!
BOOL TegFrq_Boost ( const tTegDfsBusyHint *  hints,
DWORD  numHints,
Description: Request / Release Minimum Clock Frequencies
Parameters
[in] hints Array of boost informations. Each array element contains
  • Clock name
  • How long will it be boosted (can be infinite)
  • Clock Frequency -> used to turn off boosting
  • finish boost immediately, or gradually See tegra_dma.h for details.
[in] numHints Number of array elments
[in] mode TegDfsBusyHintSyncMode_Async = function returns immediately TegDfsBusyHintSyncMode_Sync = function only returns after boost is active.
Return values
TRUE Success
FALSE Failure
