Get Serial Number
You can use the free [Article not found #100644] to get the Serialnumber and the MAC.
BOOL  GetMACAddress(BYTE* pMAC);
BOOL  GetBoardSerial(DWORD* pSerial);
For more information see the SysInfoLibDemo in our [Article not found #100630].
Colibri Vybrid
On Coibri Vybrid SysInfoLib is not supported. Here is a workaround for Vybrid modules.
#define ID_MAC            0
#define IOCTL_HAL_GETCFGBLOCK    CTL_CODE(FILE_DEVICE_HAL, 2049, METHOD_BUFFERED, FILE_ANY_ACCESS)
typedef struct {
    DWORD tid : 24; // toradex id part
    DWORD cid : 24; // colibri id part
} MACCFG;
MACCFG maccfg;
DWORD id=ID_MAC;
if (!KernelIoControl(IOCTL_HAL_GETCFGBLOCK,&id,sizeof(DWORD),&maccfg,sizeof(MACCFG),NULL))
    return FALSE;
