Disabling Serial Port Debug Console (Linux/U-Boot)
On our Toradex modules the U-Boot boot loader and the Linux kernel use UART_A as serial debug console. The serial console is the primary and most reliable interface to the boot loader and Linux kernel. We do not recommend to use UART_A for any other purpose. Disabling it prevents analysing errors (e.g. crash of the user interface) or controlling the system if in an non-bootable state. However, if your design requires to disable the serial console entirely this article shows what needs to be done.
Note: This article shows how to disable the debug messages on the serial console only. In case you would like to disable debug messages or the virtual console on graphical output (DVI-I, HDMI, LVDS or VGA) please refer the Framebuffer (Linux) article.
Disable U-Boot Console Output on UART_A
Custom U-Boot
The following config options need to be defined in the respective board header file to quiet messages on the serial console:
CONFIG_SILENT_CONSOLE
CONFIG_SYS_DEVICE_NULLDEV
CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC
For enabling silent console append the environment variable 'silent=1' to CONFIG_EXTRA_ENV_SETTINGS in respective board header file.
Please refer to the following article concerning setup/compilation of the same:
Build U-Boot and Linux Kernel from Source Code
Note: Enabling silent console just bypasses the console messages to null. Depending on the module type and U-Boot version you might still be able to interrupt U-Boot by pressing the specified key which allows you to control the U-Boot at run time.
Disable most Log Messages from Linux Kernel
To get less debug messages from the Linux Kernel one can use the "quiet" Kernel parameter.
# setenv defargs '${defargs} quiet'
# saveenv
Disable Linux Kernel Console Output on UART_A
Disable the console from kernel completely by setting the console= option on the kernel command line. This can be achieved by doing it from U-Boot prompt or using U-Boot-envtools under Linux to modify the env variables:
# setenv console null
# saveenv
or
using U-Boot-envtools under Linux:
# fw_setenv console null
# reboot
After this no kernel messages/serial login are available on debug serial port any more. To re-enable the debug serial port console one need to reset the 'console' variable back to respective serial tty(e.g: ttyLP0 on Colirbi VFxx).
# setenv console ttyLP0
# saveenv
or
# fw_setenv console ttyLP0
# reboot
Disable Serial Getty on UART_A
Newer BSPs always start an explicit serial getty on UART_A which can be disabled as follows:
# systemctl disable serial-getty@ttyS0.service
An interesting blog post from Mr. Poettering about the thematic can be found here.
