How to implement Ethernet Client/Server in VC#
Ethernet is a widely-used high performance networking technique for local area networks (LAN). Because of it's easy and inexpensive implementation, it is a very popular and reliable technology.
When invented it had a transmission rate of 2.94Mb/s and could support 256 devices over cable for 1km using CSMA/CD. To match with the high speed network requirements, it was continuously updated so now it supports a maximum data rate up to 10Gbps.
This article demonstrates how data can be sent and received over Ethernet in VC#.
Steps
  • Go to My Device > Program Files > vcsharp_ethernet_client_server_demo and run the application vcsharp_ethernet_client_server_demo.exe.
Configure TCP Client
  • Download any TCP Server application such as Hercules for your development PC .
  • Set the port number and run TCP server.
  • On your WinCE device, run vcsharp_ethernet_client_server_demo application.
  • In TCP Client tab, enter IP address of your development PC and port number for which server is configured and press Connect button.
Image shows the configured TCP client:
Configure TCP Server
  • In TCP Server tab, set port number and press Listen button.
  • Download any TCP client application for your development PC like Hercules or Tera Term."
  • Enter IP adress of your WinCE device and port number for which server is configured and press Connect button.
Image shows the configured TCP server:
Any feedback/question, please send us an email at support.arm@toradex.com.
