How to use Analogue Camera Adapter/Analogue Camera Module on Embedded Linux
This article describes the step-by-step procedure to interface and test the Analogue Camera Adapter (ACA)/Analogue Camera module (ACM) with the Apalis and Colibri evaluation boards or the Ixora carrier board using the parallel camera interface.
References
Test Setup
The following block diagram shows the set up required for the test.
Note:
On the Colibri Evaluation Board V3.2 the pinout of the parallel camera interface connector X22 has been update to maintain compatibility with the Apalis Evaluation Board.
Thus a custom cable will be required to connect the ACM V1.1 with the Colibri Evaluation Board V3.2.
For more details, please refer to the Analogue Camera Module Datasheet, section 6.
The Analogue Camera Adapter (ACA) pinout is compatible with the parallel camera interfaces on the Apalis Evaluation Board and the Colibri Evaluation Board v3.2.
Apalis/Colibri iMX6
The necessary drivers are provided as kernel modules.
On Apalis iMX6 the default device tree contains the needed configuration.
On a Colibri iMX6 the device tree imx6dl-colibri-cam-eval-v3.dtb must be loaded in U-Boot to set the non standard pin muxing and configuration needed as follows:
Colibri iMX6 # setenv fdt_file imx6dl-colibri-cam-eval-v3.dtb
Colibri iMX6 # saveenv
If you use the ADV7180 the input channel is fixed set to A_IN2_3 on the ACM's connector X5. If you use the MAX9526 the input channel is determined by the Auto-Select feature of the chip.
During boot both VDACs are probed. The kernel output looks as follows if a MAX9526 gets detected:
root@colibri-imx6:~# dmesg | grep adv
[    7.772107] adv7180 2-0021: Error applying setting, reverse things back
[    7.877802] adv7180 2-0021: Error applying setting, reverse things back
[    7.887786] adv7180 2-0021: setup pinctrl failed
[    7.894598] adv7180: probe of 2-0021 failed with error -22
root@colibri-imx6:~# dmesg | grep max9526
[    7.538711] max9526 2-0020: cannot get analog voltage
[    7.620635] mxc_v4l2_master_attach: ipu0:/csi1 parallel attached max9526:mxc_v4l2_cap0
Independently of which VADC you use, the following gstreamer pipeline displays the camera input on screen.
root@apalis-imx6:~# gst-launch-1.0 imxv4l2videosrc ! imxipuvideosink use-vsync=true
Since V2.5 Beta 2:
root@apalis_imx6:~# gst-launch tvsrc ! imxv4l2sink
Since V2.4 Beta 1:
root@colibri-imx6:~# gst-launch tvsrc ! mfw_v4lsink
Note: Support for the Analogue Camera Adapter (ACA) was introduced in our Embedded Linux BSP V2.6 Beta 2 demo images.
Apalis T30
For Apalis T30 the kernel modules are included out of the box with the modular camera configuration enabled, which allows switching not only decoders but also their inputs at run time.
The correct order to load modules:
modprobe videobuf2-memops
modprobe videobuf2-dma-nvmap
modprobe max9526
# or modprobe adv7180
# or modprobe adv7280
modprobe tegra_v4l2_camera
To change the decoder on the fly:
rmmod tegra_v4l2_camera
rmmod max9526
# or rmmod adv7180
modprobe adv7180
# or modprobe max9526
  • The following gstreamer pipeline shows a preview window:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer ! nv_gl_eglimagesink
Note:
  • If using the Analogue Camera Adapter (ACA) there is no need to use the software de-interlacing as the ADV7280 has a hardware de-interlacing feature.
  • Support for the Analogue Camera Module (ACA) was introduced in our Embedded Linux BSP V2.5 Beta 3 demo images.
Colibri T20/T30
  • Follow this article to build and re-compile the embedded Linux kernel image.
  • The following kernel configuration options are required to be enabled (e.g. using make nconfig):
Device Drivers --->
    <*> Multimedia support (CONFIG_MEDIA_SUPPORT) --->
        [*] Video capture adapters (CONFIG_VIDEO_CAPTURE_DRIVERS) --->
            Encoders, decoders, sensors and other helper chips  --->
                <M> Analog Devices ADV7180 decoder (CONFIG_VIDEO_ADV7180)
                <M> Analog Devices ADV7280 decoder (CONFIG_VIDEO_ADV7280)
            <*> SoC camera support (CONFIG_SOC_CAMERA)
            <M> max9526 support (CONFIG_SOC_CAMERA_MAX9526)
            <M> Tegra soc_camera host driver (CONFIG_VIDEO_TEGRA)
  • Don't forget to deploy the kernel modules to your root file system as well once built:
sudo -E make INSTALL_MOD_PATH=/<path>/<to>/<your>/rootfs modules_install
  • Restart the target system after flashing the updated embedded Linux kernel image and root file system.
  • Load the kernel modules in the correct order as follows:
modprobe max9526
  • To change the decoder on the fly:
rmmod max9526
# or rmmod adv7180
modprobe adv7180
Note:
  • Support for the Analogue Camera Module (ACA) was introduced in our Embedded Linux BSP V2.5 Beta 3.
Channel Selection
Apalis/Colibri Txx
To switch inputs
  • For ADV7180, Channel 0 - Channel 4
  • For ADV7280, Channel 0 - Channel 4
  • For MAX9526, Channel 0 - Channel 2 (Channel 2 sets the Auto-Select feature)
v4l2-ctl -i 0
v4l2-ctl -i 1
v4l2-ctl -i 2
v4l2-ctl -i 3
v4l2-ctl -i 4
Apalis/Colibri iMX6
The kernel drivers for Apalis/Colibri iMX6 currently do no allow switching the VDACs channels.
  • For ADV7180, fix set to Channel 3
  • For ADV7280, fix set to Channel 0
  • For MAX9526, fix set to the Auto-Select feature
MAX4586 Video Multiplexer
Please note that when using MAX9526, v4l2-ctl -i can only be used to switch the MAX9526 video decoder input channel but not the MAX4586 video multiplexer which connects to video inputs 1 to 4. By default, the second input channel 2 is active, which connects to video input 5. Please refer the block diagram below.
To change the MAX4586 channel a separate I2C user space application is required as below.
//${CROSS_COMPILE}gcc max4586.c -o max4586
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/i2c-dev.h>
int main(int argc, char *argv[])
    char buf[8] = {0};
    char filename[20] ={0};
    int file;
    int adapter_nr = 0; /* probably dynamically determined */
    int addr = 0x37;    /* The I2C address */
    if (argc < 2) {
        printf("usage: %s [i2c-bus] [i2c-addr] [nox-bit]\n", argv[0]);
        printf("\twhere:\n");
        printf("\ti2c-bus: 0 for Colibri T20/T30, 2 for Apalis T30 or Colbri iMX6, 3 for Apalis iMX6\n");
        printf("\ti2c-addr: 0x35 if JP4 placed or 0x37 if JP4 left open\n");
        printf("\tnox-bit: 1 for NO1, 2 for NO2, 4 for NO3 or 8 for NO4\n");
        exit(1);
    } else if (argc == 2) {
        buf[0] = atoi(argv[1]);
    } else if (argc == 3) {
        adapter_nr = atoi(argv[1]);
        buf[0] = atoi(argv[2]);
    } else {
        sscanf(argv[2], "0x%x", &addr);
        buf[0] = atoi(argv[3]);
    //printf("i2c-bus = %d, i2c-addr = 0x%02x, nox-bit = %d\n", adapter_nr, addr, buf[0]);
    //open the device file
    snprintf(filename, 19, "/dev/i2c-%d", adapter_nr);
    file = open(filename, O_RDWR);
    if (file < 0) {
        /* ERROR HANDLING; you can check errno to see what went wrong */
        printf("ERROR HANDLING; you can check errno to see what went wrong\n");
        exit(1);
    //specify device address to communicate
    if (ioctl(file, I2C_SLAVE, addr) < 0) {
        exit(1);
    /* Using I2C Write */
    if (write(file, buf, 1) != 1) {
        /* ERROR HANDLING: i2c transaction failed */
        printf("ERROR HANDLING: i2c transaction failed\n");
        exit(1);
    exit(0);
NOTE: The Analogue Camera Adapter (ACA) is available on the Toradex Webshop.
See also
