How to use Automotive Cluster example on Linux
This article shows the Automotive Cluster demo running on the Qt framework on Toradex computer modules running Linux.
Automotive Cluster Display Demo
The instrument cluster is used to display information of the vehicle systems. This includes gauges for various parameters such as speed, rpm or fuel, as well as indicators, status lights and also acoustic effects.
Steps to Run the Demo
Download the OpenEmbedded repository
The automotive cluster example for Linux is based on OpenEmbedded (core), to build the example you have to follow OpenEmbedded (core) tutorial and change some steps.
The example has been tested with version V2.4, make sure to synchronize the repository with the correct version.
mkdir ~/oe-core
cd ~/oe-core
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.4
repo sync
Add Toradex extra layer
The “meta-toradex-extra” layer contains the Auomotive Cluster example. You need to manually download this layer using:
cd ~/oe-core/stuff
git clone https://github.com/toradex/meta-toradex-extra.git -b ew2015-automotive-cluster
cd ~/oe-core/build
Compiling configuration
Source the “export” file, this will configure all the environment variables required for OpenEmbedded.
. export
At the “oe-core/build” directory we have to change two files before start the build. Change the file “local.conf” to configure the machine and add the automotive cluster package:
vim conf/local.conf
Add the qt-automotive-cluster-demo package as a preinstalled package by using the IMAGE_INSTALL variable:
#MACHINE ??= "qemux86"
#MACHINE ?= "colibri-t20"
MACHINE ?= "colibri-vf"
IMAGE_INSTALL_append = " qt-automotive-cluster-demo "
Change the bblayer.conf to include the “meta-toradex-extra”:
vim conf/bblayer.conf
Add the meta-toradex-extra layer:
# These layers hold machine specific content, aka Board Support Packages
BSPLAYERS ?= " \
  ${TOPDIR}/../stuff/meta-toradex \
  ${TOPDIR}/../stuff/meta-toradex-extra \
Now, run bitbake command to start the build.
bitbake console-trdx-image
Change Aplication Resolution
By default, Automotive Cluster example is configured to use 1024x600, you can change for 800x480 by removing the define in a “meta-toradex-extra” file.
vi meta-toradex-extra/recipes-qt/qt-automotive-cluster-demo/qt-automotive-cluster-demo_0.1.bb
Remove “DEFINES+=RESOLUTION_1024x600”
--EXTRA_QMAKEVARS_PRE += "CONFIG+=no-webcam DEFINES+=RESOLUTION_1024x600"
++EXTRA_QMAKEVARS_PRE += "CONFIG+=no-webcam"
Change Screen Resolutions
You can also change you screen resolution by setting the U-Boot variable (use a serial console to enter the U-Boot prompt):
set vidargs video=dcufb:1024x600
set vidargs video=dcufb:800x480
Use “save” to store this change permanently.
Building the qt user interface
If you want to build the Qt application you have to prepare the QT SDK, configure the Qt Creator and download the source code.
Prepare Qt SDK
To compile the SDK and setup Qt Creator, refer to this article:
How to set up QT Creator to cross compile for embedded Linux
Building the Qt User Interface using Qt Creator
The source code can be downloaded from the git repository QtAutomotiveClusterDemo:
cd ~/QtProjects/
git clone https://github.com/toradex/QtAutomotiveClusterDemo
If you build all the OpenEmbedded root file system the Automotive Cluster application will be started automatic by default. Before the application starts, the init script also exports some Qt specific environment variables.
However, when using Qt Creator one need to configure Qt Creator to set this environment variables accordingly. In the Projects "Run" settings, extend the "Run Environment" with these variables:
QWS_DISPLAY="LinuxFb:/dev/fb:genericcolors"
QWS_KEYBOARD="USB:/dev/input/event-keyboard"
QWS_MOUSE_PROTO="LinuxInput:/dev/input/event-mouse"
To use the touchscreen you have to be sure that your touchscreen driver is enabled and change the Qt environment variable to something like this (see also Resistive Touch Screen (Linux) and Capacitive Multi-Touch Display (Linux)):
QWS_MOUSE_PROTO: tslib:/dev/input/touchscreen0
Furthermore, add the argument "-qws" in the "Run" section in order to run directly on the Framebuffer device.
