How to use Cloud SNS Library
Amazon Simple Notification Service (Amazon SNS)
Amazon Simple Notification Service (Amazon SNS) is a web service that makes it easy to set up, operate, and send notifications from the cloud. It provides developers with a highly scalable, flexible, and cost-effective capability to publish messages from an application and immediately deliver them to subscribers or other applications. It is designed to make web-scale computing easier for developers.
Notes:
  • The number of Topics is limited to 100 per region.
  • Use a small length Topic Name for a fast response time.
  • Use only alphanumeric/underscore/hyphen characters to construct the Topic Name and Display Name. Avoid using special characters.
  • The system time of Colibri Modules should not be deviated by more than 15 Minutes otherwise AWS specific functions will return an error.
For more information, please refer to: http://aws.amazon.com/sns/
Open SNS Handle
Before calling any other function, call SnsOpenTopic() with all the parameter inputs: AWS Access Id, AWS Secret Key, AWS Owner ID, AWS SnS Region / Path,topicName, Topic and Display name(optional).
  • It will return TRUE if successful or FALSE if the call fails. Use GetLastError() to get extended error details.
HSNS NewTopic; //Declare Topic handle
if (!SnsOpenTopic(AWS_ACCOUNT_ACCESS_ID,
AWS_ACCOUNT_SECRET_KEY,
AWS_ACCOUNT_OWNER_ID,
AWS_SQS_USA_EAST_REGION,
“TopicName",
“DisplayName",
&NewTopic))
printf("SnsOpenTopic Fail");
printf(", Error Code: %d\n", GetLastError());
else
printf("SnsOpenTopic Success\n");
NewTopic needs to be passed to all function calls after this point.
Create New Topic
The SnsCreateTopic() function is used to create a new topic. This is the 2nd function to be called after SnsOpenTopic(). It is mandatory to call this function otherwise other calls will automatically fail.
  • The 1st parameter is the NewTopic handle returned from SnsOpenTopic() function call.
if (!SnsCreateTopic(NewTopic))
printf("SnsCreateTopic Fail");
else
printf("SnsCreateTopic Success\n");
List All the Topics in a Region
SnsListTopics() function is used to list all the topics.
  • 1st parameter is the NewTopic handle returned from the SnsOpenTopic() function call.
  • 2nd parameter is the path of the local file in which the list data needs to be stored.
if (!SnsListTopics(NewTopic, "\\listoftopics.txt"))
printf("SnsListTopics Fail");
else
printf("SnsListTopics Success\n");
Find a Topic from List Stored in a Local File
The SnsFindTopic() function is used to find topic details one by one from a list data stored in the local file.
  • 1st parameter is the path of the local file in which list data needs be stored.
  • 2nd parameter is the pointer to the memory in which the function will put the data.
  • 3rd parameter is the size of the memory allocated for the 2nd parameter.
  • 4th parameter is the pointer to a memory location in which the function will put the location for the next topic detail. To find the 1st topic from the list put this variable as zero.
  • 5th parameter is the size of the local file.
DWORD listTopicNextPointer = 0;
char topicData[256] = {0};
memset(topicData, 0, 256);
if (SnsFindTopic("\\listoftopics.txt",
topicData,
BUFFER_SIZE_TOPIC_DATA,
&listTopicNextPointer,
fileSize))
printf("> %s\n", topicData);
To find the next topic, call SnsFindTopic again as below. This time don’t set listTopicNextPointer to zero.
topicData,
fileSize))
Delete a Topic
The SnsDeleteTopic() function is used to delete a topic.
if (!SnsDeleteTopic(NewTopic))
printf("SnsDeleteTopic Fail");
else
printf("SnsDeleteTopic Success\n");
List All the Subscriptions of a Topic in a Region
The SnsListSubscriptions() function is used to list all the subscriptions of a topic.
  • 2nd parameter is the path of the local file in which the list data needs be stored.
if (!SnsListSubscriptions(NewTopic, "\\ListSubscriptionsByTopic.txt"))
printf("SnsListSubscriptions Fail");
else
printf("SnsListSubscriptions Success\n");
Find a Subscription from List Stored in a Local File
The SnsFindSubscriptions() function is used to find subscription details one by one from list data stored in the local file.
  • 1st parameter is the path of the local file in which the list data needs be stored.
  • 4th parameter is the pointer to a memory location in which the function will put the location for the next topic detail. To find the 1st subscription from the list, put this variable as zero.
DWORD listSubscriptionNextPointer = 0;
char subscriptionData[1024] = {0};
memset(subscriptionData, 0, 1024);
if (SnsFindSubscriptions("\\ListSubscriptionsByTopic.txt",
subscriptionData,
1024,
&listSubscriptionNextPointer,
fileSize))
printf("> %s\n", subscriptionData);
To find the next subscription call SnsFindSubscriptions() again as detailed below. This time don’t set listSubscriptionNextPointer to zero.
subscriptionData,
1024,
fileSize))
Subscribe an Endpoint to a Topic
The SnsSubscribe() function is used to subscribe an endpoint to a topic.
  • 2nd parameter is the endpoint. For email endpoint: example@toradex.com. For SMS it should be the phone number with country code.
  • 3rd parameter is the protocol type. For more details please check API documentation at: /windows-ce/knowledge-base/cloud-sns-lib-api#ac8c11fccf90d19565c1b8d2843df47db
// USE MACRO for 3rd parameter
if (!SnsSubscribe(NewTopic, “example@toradex.com", PROTOCOL_TYPE_EMAIL))
printf("SnsSubscribe Fail");
else
printf("SnsSubscribe Success\n");
Unsubscribe a Subscription From a Topic
The SnsUnsubscribe() function is used to unsubscribe an endpoint from a topic.
  • 2nd parameter is the subscription ARN., You can use SnsFindSubscriptions() to get subscription ARN (Amazon Resource Name).
if (!SnsUnsubscribe(NewTopic, "arn:aws:sns:us-east-1:823890622362:USA_NewAlerts-1:e86e12f4-ccb7-4153-acd2-33a2c8e30de5"))
printf("SnsUnsubscribe Fail");
else
printf("SnsUnsubscribe Success\n");
Get Subscription Attributes
The SnsGetSubscriptionAttribtues() function is used to get subscription attributes.
  • 2nd parameter is the subscription ARN, you can use the SnsFindSubscriptions() to get the subscription ARN (Amazon Resource Name).
char subscriptionAttributesData[1024] = {0};
memset(subscriptionAttributesData, 0, 1024);
if (!SnsGetSubscriptionAttribtues(NewTopic, "arn:aws:sns:us-east-1:823890622362:test:81bb4313-b150-48bf-8fd5-cf98a6a85535", subscriptionAttributesData, 1024))
printf("SnsGetSubscriptionAttribtues Fail");
else
printf("%s\n", subscriptionAttributesData);
printf("SnsGetSubscriptionAttribtues Success\n");
Get Topic Attributes
The SnsGetTopicAttributes() function is used to get topic attributes.
  • 2nd parameter is the pointer to the memory in which the attribute data will be returned by the function if successful.
char topicAttributesData[1024] = {0};
memset(topicAttributesData, 0, 1024);
if (!SnsGetTopicAttributes(NewTopic, topicAttributesData, 1024))
printf("SnsGetTopicAttributes Fail");
else
printf("%s\n", topicAttributesData);
printf("SnsGetTopicAttributes Success\n");
Sets a Topic Attribute
The SnsSetTopicAttributes() function is used to set the attribute of a topic.
  • 1st Parameter is the NewTopic handle returned from SnsOpenTopic() function call.
  • 2nd parameter is the attribute type use macros:
#define ATTRIBUTE_TYPE_POLICY 1
#define ATTRIBUTE_TYPE_DISPLAYNAME 2
#define ATTRIBUTE_TYPE_DELIVERYPOLICY 3
  • 3rd parameter is the attribute name/value.
if (!SnsSetTopicAttributes(NewTopic, ATTRIBUTE_TYPE_DISPLAYNAME, “TORADEX"))
printf("SnsSetTopicAttributes Fail");
else
printf("SnsSetTopicAttributes Success\n");
Publish a Message to a Topic
The SnsPublish() function is used to send a message to a topic.
  • 1st Parameter is the NewTopic handle returned from the SnsOpenTopic() function call.
  • 2nd parameter is the Subject (optional - only intended for email endpoints).
  • 3rd parameter is the Message to be sent.
if (!SnsPublish(NewTopic,
"Test",
"Message, sent by Toradex SNS Cloud Library :)"))
printf("SnsPublish Fail");
else
printf("SnsPublish Success\n");
Close Topic
The SnsCloseTopic() function is used to close the handle opened by the call to SnsOpenTopic().
  • Parameter input is the NewTopic handle returned from the SnsOpenTopic() function call.
if (!SnsCloseTopic(&NewTopic))
printf("SnsCloseTopic Fail");
