How to use Monochrome Graphical LCD
LCD is an optical device made up of a number of pixels filled with liquid crystals and placed in front of a light source (or a reflector) to produce images in color or monochrome.
Use Cases:
  • Equipment such as microwave ovens
  • Home automation
  • Automation Controllers
  • Vending machines
  • and many more..
This article demonstrates how to interface monochrome graphical LCD with Iris Carrier Board V1.1A.
Schematic diagram
NOTE: Below mentioned examples can run on Colibri VF50/61 modules, for that you have to use Vybrid GPIO libraries available here.
Demo Applications in C
Demo 1
  • Download GLCD Demo code from here.
  • Build and deploy the solution.
  • Navigate to My Device > Program Files > glcddemo and run the application glcddemo.exe.
Main function code snippet is shown below:
while (TRUE)
        toRepeat = '\0';
        GlcdToradexLogo();                              ///< Display Toradex Logo on GLCD
        Sleep(5000);
        GlcdRobinApalisColibriLogo();                   ///< Display Toradex Modules Logo on GLCD
        GlcdSetPage(GLCD_PAGE6, 0);
        GlcdDisplayString("   Embedded Computer ");     ///< Display string on GLCD
        GlcdSetPage(GLCD_PAGE8, 0);
        GlcdDisplayString("             Modules");
        Sleep(1000);
        printf("Press Enter to continue and 'e' to exit\n");
        scanf_s("%c", &toRepeat);
        if (toRepeat == 'e') break;
Output
Demo 2
This application takes the bitmap image (monochrome, 128x64) as an input and displays it on graphical LCD. We have done a small animation using multiple bmp files.
  • Download demo code from here.
  • Navigate to My Device > Program Files > glcd_imagedemo and run the application glcd_imagedemo.exe.
Output
NOTE: Images used are monochrome single layer bitmap images (.bmp file of 128x64 dimension).
Demo Application in CSharp
  • Go to My Device > Program Files > vcsharp_glcd_demo and run the application vcsharp_glcd_demo.exe.
Output
Following GUI will open that will show the same images displaying on the GLCD at that time.
Any feedback/question, please send us an email at support.arm@toradex.com.
