How to use PWM Library
PWM library is used to generate PWM output on Toradex module.
Use cases:
  • LCD backlight control
  • Servo motor control
  • and many more..
PWM Library
We provide free Windows CE library for PWM including demo source code here.
Download project
Project Module compatibility Language Library Version
PWM PXA / Tegra C Toradex CE Library (Old)
PWM VFxx / iMX6 C Toradex CE Library (New)
PWM PXA / Tegra C# Toradex CE Library (Old)
PWM VFxx / iMX6 C# Toradex CE Library (New)
*NOTE:
  • PWM Channel 1 for PXA3xx (PXA320, PXA310, PXA300) is available on multiplexed GPIO pin of SODIMM Pin 152.
  • On Colibri Evaluation Board V3.1A, SODIMM Pin 152 is available at B7 of X3 (User extension).
  • On Iris Carrier Board V1.1, SODIMM Pin 152 is connected to PWM_D line through a not DNP 0E resistor (R110). Please refer Iris schematic.
  • To access the PWM channel 1 available on the multiplexed GPIO pin, set the alternate function of other GPIO to 0x07 (tristate).
  • On VFxx PWM1/PWM_A and PWM3/PWM_C is using same PWM controller i.e FTM controller 0 and PWM2/PWM_B and PWM4/PWM_D using FTM controller 1 due to this configuring PWM 1 result same configuration for PWM3 similarly for PWM 2 and PWM 4.
Demo application in C
This application demonstrates the use of PWM library to generate PWM signal of user-defined frequency and duty cycle.
Output wave 1000 Hz at 75% duty cycle
Demo application in C#
Output waveform
Calculations
Frequency calculation for Colibri T30:
Frequency (Hz) = 352100/Prescale
Prescale range: 1 - 8192, Period = 256 (Fixed)
Minimum frequency = 42.98 Hz (prescale = 8192)
Maximum frequency = 352.10 kHz (prescale = 1)
Frequency calculation for Colibri T20:
Frequency (Hz) = 188700/Prescale
Minimum frequency = 23.03 Hz (prescale = 8192)
Maximum frequency = 188.70 kHz (prescale = 1)
Frequency calculation for Colibri iMX6x:
Frequency (Hz) = 66000000/(prescale x period)
Prescale range: 1-4096, Period = 1 - 65536
Minimum frequency = 0.245 Hz (prescale = 128, period = 65536)
Maximum frequency = 66 MHz (prescale = 1, period = 1)
Frequency calculation for Colibri VF61:
Frequency (Hz) = 83300000/(prescale x period)
Prescale range: 1, 2, 4, 8, 16, 32, 64, 128, Period = 1 - 65536
Minimum frequency = 9.930 Hz (prescale = 128, period = 65536)
Maximum frequency = 83.3 MHz (prescale = 1, period = 1)
Frequency calculation for Colibri VF50:
Minimum frequency = 7.86 Hz (prescale = 128, period = 65536)
Frequency calculation for PXAxxx:
Frequency (Hz) = 10^9/(76.9 x prescale x period)
Prescale range: 1 - 64, Period = 1 - 1024
Minimum frequency = 198.42 Hz (prescale = 64, period = 1024)
Maximum frequency = 3.25 MHz (prescale = 1, period = 4)
