Img Info Lib API
Library to interact with Image Information.
Data Structures
struct  ROMHDRstruct  TOCentrystruct  FILESentrystruct  COPYentrystruct  VERSIONINFOstruct  BSPVER
Macros
#define  IMG_VER_MAJ  1
Library Version.
#define  IMG_VER_MIN  4
#define  IMG_VER_BUILD  0
#define  VI_MAGIC1  0x01234567
#define  VI_MAGIC2  0x89abcdef
Typedefs
typedef struct ROMHDR ROMHDR
typedef struct TOCentry TOCentry
typedef struct TOCentry LPTOCentry
typedef struct FILESentry FILESentry
typedef struct FILESentry LPFILESentry
typedef struct COPYentry COPYentry
Functions
BOOL  ImgInfoLibInit (void)
BOOL  ImgInfoLibDeInit (void)
BOOL  FindVersionInfo (BSPVER *pBspVer)
BOOL  FindVersionInfoEx (BSPVER *pBspVer, DWORD startAddr, DWORD length)
char *  FindVersionString (char *pStr)
BOOL  GetTOC (DWORD address, ROMHDR *pTOC, DWORD *pTOCOffset)
DWORD  GetIMAGESize (DWORD address)
BOOL  FindIMAGE (BOOL bImage, DWORD *pStart, DWORD *pLen)
BOOL  GetFlashBootloaderInfo (BSPVER *pBspVer, TCHAR *dateStr)
BOOL  GetFlashBootloaderInfoEx (BSPVER *pBspVer, TCHAR *dateStr, DWORD start, DWORD length)
void  GetCurrentImageInfo (BSPVER *pBspVer, TCHAR *dateStr)
void  IMGGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
Library Version.
Typedef Documentation
typedef struct FILESentry * LPFILESentry
typedef struct TOCentry * LPTOCentry
Function Documentation
BOOL FindIMAGE ( BOOL  bImage,
DWORD *  pStart,
DWORD *  pLen
Find the image in the Flash
Parameters:
[in] bImage TRUE: Skip First Sector
[out] pStart Pointer to start of image
[out] pLen Pointer to length of image
Return values:
TRUE Success
FALSE Error
BOOL FindVersionInfo ( BSPVER pBspVer )
Finds the BSP Version starting from 0x00 for 256Kb
Parameters:
[out] pBspVer Pointer to BSP Version Structure
Return values:
TRUE Success
FALSE Error
BOOL FindVersionInfoEx ( BSPVER pBspVer,
DWORD  startAddr,
DWORD  length
Finds the BSP Version, use the supplied start address and length
Parameters:
[in] startAddr Start Address
[in] length Search length
Return values:
TRUE Success
FALSE Error
char* FindVersionString ( char *  pStr )
Finds the given string
Parameters:
[in] pStr Pointer to zero-terminated string to find
Return values:
>0 Pointer to last character of the string
NULL(0) String not found
void GetCurrentImageInfo ( BSPVER pBspVer,
TCHAR *  dateStr
Get the Current Imae Info
Parameters:
[in] pBspVer Pointer to BSP Version
[in] dateStr Date String
BOOL GetFlashBootloaderInfo ( BSPVER pBspVer,
TCHAR *  dateStr
Get the Bootloader info from the flash, search the whole of the flash
Parameters:
Return values:
TRUE Success
FALSE Error
BOOL GetFlashBootloaderInfoEx ( BSPVER pBspVer,
TCHAR *  dateStr,
DWORD  start,
DWORD  length
Parameters:
[in] start Start Address
[in] length Length
Return values:
TRUE Success
FALSE Error
DWORD GetIMAGESize ( DWORD  address )
Get the Image Size
Parameters:
[in] address Starting Address
Return values:
Image Size in bytes
Remarks: We also search at 32KB offset for romhdr (eboot offset
in eboot_formatted.bin)
BOOL GetTOC ( DWORD  address,
ROMHDR pTOC,
DWORD *  pTOCOffset
Get the Table of Contents Pointer
Parameters:
[in] address Starting address
[out] pTOC Pointer to TOC
[out] pTOCOffset Pointer to TOC Offset
Return values:
TRUE Success
FALSE Error
void IMGGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Outputs library version
Parameters:
[out] verMaj Major version number. Set this parameter to NULL if not required
[out] verMin Minor version number. Set this parameter to NULL if not required
[out] build Build number. Set this parameter to NULL if not required
BOOL ImgInfoLibDeInit ( void  )
Frees the Image Information library
Return values:
TRUE Success
FALSE Error
BOOL ImgInfoLibInit ( void  )
Initialise the Image Information Library.
Return values:
TRUE Success
FALSE Error
