Install drivers
In order to install additional drivers for special devices the following steps are necessarily.
  • Install or copy the new driver files into a sub folder called "System" on the Flash file system (for example: \FlashDisk\System).
  • Do the additional registry settings
  • Save the registry after installation.
Remarks: Instead of copying the driver to \FlashDisk\System you can copy the driver DLL to any other location and set the Path in the registry to the DLL properly.
