Internet Time Server
The default Windows CE image implemented on the Colibri modules supports setting the system time from an internet time server. This feature is activated by default.
More Information
This SNTP service is a default feature provided by microsoft. Documentation can be found here:
http://msdn.microsoft.com/en-us/library/aa924011.aspx
Default values
Toradex configures the settings for the SNTP service as follows:
[HKEY_LOCAL_MACHINE\Services\Timesvc]
"Server"         = "swisstime.ethz.ch"
"refresh"        = dword:240C8400 ;get time from server once a week
"recoveryrefresh"= dword:5265C00 ;if failed next try next day
"threshold"      = dword:5265C00
"trustlocalclock"= dword:0
Disabling the SNTP service
In order to disable the SNTP service, configure the timer server to an invalid value, e.g. an empty string
"Server"         =""
